04-20-2015, 06:38 | #1 (permalink) |
Insane Poster Join Date: Dec 2014
Member: 2305604 Status: Offline Thanks Meter: 4 | M919 No Network "Help Please" |
04-20-2015, 06:51 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Quote:
Try to do the next: 1. Root the phone. 2. Make Repair EFS. 3. Make Repair IMEI. 4. Make Factory data reset and wipe cache partition. 5. Re-flash the phone with another firmware for SGH-M919. 6. Write different QCN. 7. Insert SIM card, wait 5-7 minutes and try to find and select network manually. | |
04-20-2015, 07:45 | #3 (permalink) |
Member: 2305604 Status: Offline Thanks Meter: 4 | I do everything... and still not network or signal... here is the log... Welcome to Octoplus/Octopus Box Samsung software version 1.9.2 ----------------------------------------------------------------------------------- To connect SGH-M919 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM35 Selected model: SGH-M919 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Aug 06 2014 Firmware compiled time: 06:00:00 Firmware released date: Aug 27 2014 Firmware released time: 22:42:02 Phone IMEI: 351341-72-235378-9 SW version: M9615A-CEFWTAZM-4.0.17173 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM35 Selected model: SGH-M919 To put SGH-M919 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM35 Selected model: SGH-M919 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Aug 06 2014 Firmware compiled time: 06:00:00 Firmware released date: Aug 27 2014 Firmware released time: 22:42:02 Phone IMEI: 351341-72-235378-9 SW version: M9615A-CEFWTAZM-4.0.17173 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM35 Selected model: SGH-M919 ADB server killed. Detected phone model: SGH-M919 Firmware compiled date: Wed Aug 27 21:41:58 KST 2014 PDA version: M919UVUFNH7 CSC version: M919TMBFNH7 SW version: M919UVUFNH7 Phone IMEI: 351341722353789 Phone SN: RF1D478W82J Android version: 4.4.4 (KTU84P) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SGH-M919-351341722353789-20-04-2015_00-03-38-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait 1-2 minutes. 3. Connect phone via UART cable to Box. Connecting to phone, please wait... Found phone on COM8 Phone connected successfully Writing new phone IMEI... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Selected firmware file: M919UVUEMK2_M919TMBEMK2_TMB_Android_4.3.oct Please put the phone into Download Mode and connect USB cable. To put SGH-M919 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing SBL2 section... SBL2 section has been written successfully. Writing SBL3 section... SBL3 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MDM section... MDM section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SGH-M919 Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM8 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SGH-M919 Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM35 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Sep 30 2013 Firmware compiled time: 05:00:00 Firmware released date: Nov 16 2013 Firmware released time: 15:19:25 Phone IMEI: 458261-84-308520-5 SW version: M9615A-CEFWTAZM-4.0.17122 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM35 Selected model: SGH-M919 Reading info... Mode: Normal Firmware compiled date: Sep 30 2013 Firmware compiled time: 05:00:00 Firmware released date: Nov 16 2013 Firmware released time: 15:19:25 SW Version: M9615A-CEFWTAZM-4.0.17122 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes and still not network or signal |
04-20-2015, 07:57 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Write the first Security backup (that has been created by Software in the first process of repairing IMEI) to return the phone to the previous (initial) state and check, whether the network is active. If network in not active, this means, that the problem with network was at the beginning. |
04-20-2015, 08:04 | #5 (permalink) |
Member: 2305604 Status: Offline Thanks Meter: 4 | same... here is the log... not network or signal after this... ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM35 Selected model: SGH-M919 Reading info, please wait... ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SGH-M919 Firmware compiled date: Sat Nov 16 14:29:37 KST 2013 PDA version: M919UVUEMK2 CSC version: M919TMBEMK2 SW version: M919UVUEMK2 Phone IMEI: 458261843085205 Phone SN: RF1D478W82J Android version: 4.3 (JSS15J) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM35 Selected model: SGH-M919 Detected phone model: SGH-M919 Firmware compiled date: Sat Nov 16 14:29:37 KST 2013 PDA version: M919UVUEMK2 CSC version: M919TMBEMK2 SW version: M919UVUEMK2 Phone IMEI: 458261843085205 Phone SN: RF1D478W82J Android version: 4.3 (JSS15J) Writing security backup, please wait... Phone will restart now. Please don't disconnect cable! Security write successfully. not network or signal after this... |
04-20-2015, 08:16 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | This means the problem with network was at the beginning. Try also to make Unlock and write other QCNs. If this will not help, this can be HW issue. |
04-20-2015, 08:27 | #7 (permalink) |
Member: 2305604 Status: Offline Thanks Meter: 4 | this means something?... on SERVICE MODE *#0011# without the GSM card I have a some data on the screen like ServiceMode LTE RRC: ldle, Band4 EmS: 1, EmSS: 6, MeC: ff MCC-MNC : 310 - 260, MeG: ffff Earfcn_dl: 2275, PCI: 0 etc... etc... when I install the GSM car and run the code ServiceMode No Service ?!? ... |
04-20-2015, 08:37 | #8 (permalink) |
Member: 2305604 Status: Offline Thanks Meter: 4 | ... No luck... same problem... Platform: Samsung Android Selected port: COM8 Selected model: SGH-M919 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM35 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Sep 30 2013 Firmware compiled time: 05:00:00 Firmware released date: Nov 16 2013 Firmware released time: 15:19:25 Phone IMEI: 458261-84-308520-5 SW version: M9615A-CEFWTAZM-4.0.17122 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM35 Selected model: SGH-M919 ADB server killed. Detected phone model: SGH-M919 Firmware compiled date: Sat Nov 16 14:29:37 KST 2013 PDA version: M919UVUEMK2 CSC version: M919TMBEMK2 SW version: M919UVUEMK2 Phone IMEI: 458261843085205 Phone SN: RF1D478W82J Android version: 4.3 (JSS15J) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SGH-M919-458261843085205-20-04-2015_01-30-23-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait 1-2 minutes. 3. Connect phone via UART cable to Box. Connecting to phone, please wait... Found phone on COM8 Phone connected successfully Writing new phone IMEI... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SGH-M919 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM8 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SGH-M919 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM35 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Sep 30 2013 Firmware compiled time: 05:00:00 Firmware released date: Nov 16 2013 Firmware released time: 15:19:25 Phone IMEI: 458261-84-308520-5 SW version: M9615A-CEFWTAZM-4.0.17122 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM35 Selected model: SGH-M919 Reading info... Mode: Normal Firmware compiled date: Sep 30 2013 Firmware compiled time: 05:00:00 Firmware released date: Nov 16 2013 Firmware released time: 15:19:25 SW Version: M9615A-CEFWTAZM-4.0.17122 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes |
