01-31-2015, 19:36 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Marruecos Age: 44
Member: 39250 Status: Offline Thanks Meter: 64 | N9005 dont work any Cert for me [Solved] i unlock some N9005 with cert but today i try with N9005 and not work old certi, i try with new certi downloaded from support and not work Welcome to Octoplus/Octopus Box Samsung software version 1.8.2 ------------------------- To connect SM-N9005 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1538 Selected model: SM-N9005 To Unlock of the device, do the next steps: 1. Root the phone. 2. Perform Wipe Security procedure ("Repair Security/Wipe Security" button). 3. Write Certificate ("Write Cert" button). ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1538 Selected model: SM-N9005 Selected file: C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\cert_N9005\Cert-SM-N900-352746069301135 _rf1f83fzpz.cert Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N9005 Firmware compiled date: Mon Feb 17 11:19:32 KST 2014 PDA version: N9005XXUENB5 CSC version: N9005AMNENB6 SW version: N9005XXUENB5 Phone IMEI: Unknown Phone SN: RF8F202JX2F Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1538 Selected model: SM-N9005 Operation was canceled Writing Certificate failed ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1538 Selected model: SM-N9005 Selected file: C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\cert_N9005\Cert-SM-N900_359092050091226.cert Detected phone model: SM-N9005 Firmware compiled date: Mon Feb 17 11:19:32 KST 2014 PDA version: N9005XXUENB5 CSC version: N9005AMNENB6 SW version: N9005XXUENB5 Phone IMEI: Unknown Phone SN: RF8F202JX2F Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes after write certi network OK but after 2min no service any one can give me good certi Last edited by Octopus box; 02-01-2015 at 09:53. |
01-31-2015, 20:31 | #8 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @flechazo, CERT file contains "Signature" of Imei and other parametry. QCN file contains network configuration settings, (how wrote above by Octopus support), and not touch the Imei of the phone. BR allumts |
