04-24-2016, 06:16 | #1 (permalink) |
No Life Poster Join Date: May 2015 Age: 40
Member: 2394595 Status: Offline Thanks Meter: 24 | n9005 emergancy call only Cert-SM-N9005_357518050231117.cert and bundle of qcn but no luck how ot solved my respected team |
The Following User Says Thank You to GSM WORK For This Useful Post: |
04-24-2016, 19:21 | #3 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | If Write CERT what Network want repair. All Cert N900X are compatible with N9005. Find one Clean and Working Cert file and will see that have any issue... Br allumts |
04-25-2016, 11:01 | #5 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Have just answer: Quote:
Find other Source, go in Main Sales Section and try to find one Clean Cert. Have also said thah ALL N900X are compatible with N9005, so can have very High list of Cert with Same Key - id Loock compatibility here: Certificates files compatibility list | |
04-25-2016, 11:17 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Problem with Network might occur if IMEI of Cert file is blacklisted by Network provider. Try to write different Cert files. If IMEI is "correct" - read out QCN from anotehr SM-N9005, which works correctly in your region, then try to use it for your phone. |
04-25-2016, 13:20 | #8 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Yes, becouse you are Special User. All Cert files available are uploaded in "Octopus Support" Area, if for you not work only one of all uploaded can try to exange with other users. You sure haven't Read compatibility and are searching only N9005 Cert, then this KEY -ID of N9005 is Compatible with ANY Cert N900x, just repeat 3 times, Open above link and Ceck for compatibility. For Lazy User, loock how many Cert are compatible Code: SC-01F 0813 SC-L22 0813 SM-N900 0813 SM-N9000Q 0813 SM-N9002 0813 SM-N9005 0813 SM-N9006 0813 SM-N9008 0813 SM-N9008S 0813 SM-N9008V 0813 SM-N9009 0813 SM-N900A 0813 SM-N900K 0813 SM-N900L 0813 SM-N900P 0813 SM-N900R4 0813 SM-N900S 0813 SM-N900T 0813 SM-N900U 0813 SM-N900V 0813 SM-N900W8 0813 Br allumts |
04-26-2016, 05:13 | #9 (permalink) |
Member: 2394595 Status: Offline Thanks Meter: 24 | Welcome to Octoplus/Octopus Box Samsung software version 2.2.4 ----------------------------------------------------------------------------------- To connect SM-N9005 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N9005 Selected file: C:\Documents and Settings\SIDDIQUI\My Documents \Downloads\Cert-SM-N900-358917050329880.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N9005 Firmware compiled date: Sat Oct 3 16:18:29 KST 2015 PDA version: N9005XXUGBOJ1 CSC version: N9005BTUGBOD2 SW version: N9005XXUGBOI2 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Country: UK & IRE HW platform: msm8974 HW Chip: MSM8974 HW Modem: MSM8974 Codename: hltexx Checking Root: Phone is Rooted. Checking Certificate file... Checking Certificate failed Writing Certificate failed Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N9005 Selected file: C:\Documents and Settings\SIDDIQUI\My Documents \Downloads\Cert-SM-N900-358917050980385.cert Detected phone model: SM-N9005 Firmware compiled date: Sat Oct 3 16:18:29 KST 2015 PDA version: N9005XXUGBOJ1 CSC version: N9005BTUGBOD2 SW version: N9005XXUGBOI2 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Country: UK & IRE HW platform: msm8974 HW Chip: MSM8974 HW Modem: MSM8974 Codename: hltexx Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Please Reset MSL first! Writing Certificate failed Performed by 2.2.4 software version |
04-26-2016, 07:11 | #11 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Use Always "HELP" button in SW and will not have done this question. Loock: Quote:
Post result BR allumts | |
