05-28-2014, 17:40 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: ::::...I LOVE PAKISTAN...::::
Member: 823250 Status: Offline Sonork: 100.1587800 Thanks Meter: 187 | N9005 problem [Solved] thanx Last edited by Octopus box; 05-29-2014 at 06:22. |
05-28-2014, 19:03 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please post here full software log of all performed operations. To Repair IMEI, do the next: 1. Install the latest Software version (http://octoplusbox.com/en/download/software/). 2. Root the phone and turn on USB Debugging Mode. 3. Select any service IMEI from the Software list. Note, to get network available, You should write service IMEI, not the original one. 4. Press "IMEI A fix" button. Last edited by Octopus box; 05-29-2014 at 06:28. |
05-31-2014, 16:09 | #3 (permalink) | |||
Member: 823250 Status: Offline Sonork: 100.1587800 Thanks Meter: 187 | logsssssssssssssssssssssssssssssssssssssssssss>>>> >>>>>>>> logsssssssssssssssssssssssssssssssssssssssssssssss sssssssssssssssssssss Quote:
[QUOTE]Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\13-05-2014_18-08-53.log" created (5/13/2014 6:08:58 PM). ERROR : 5/13/2014 6:08:59 PM > Access violation at address 008F0BF0 in module 'OctoplusSamsung.exe'. Read of address 00000004 INFO : 5/13/2014 6:09:05 PM > Set up system language English (file: English.ini) INFO : 5/13/2014 6:09:05 PM > Welcome to Octoplus/Octopus Box Samsung software version 1.5.5 INFO : 5/13/2014 6:09:05 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:09:05 PM > To connect GT-I9505 phone you have to perform the following steps: INFO : 5/13/2014 6:09:05 PM > 1. Disconnect USB cable from phone. INFO : 5/13/2014 6:09:05 PM > 2. Go to Menu->Settings->More->About Device. INFO : 5/13/2014 6:09:05 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 5/13/2014 6:09:05 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 5/13/2014 6:09:05 PM > 5. Turn on "USB Debugging" option. INFO : 5/13/2014 6:09:05 PM > 6. Go to dial window. INFO : 5/13/2014 6:09:05 PM > 7. Enter "*#0808#" number. INFO : 5/13/2014 6:09:05 PM > 8. Select "DM+Modem+ADB". INFO : 5/13/2014 6:09:05 PM > 9. Press Home button. INFO : 5/13/2014 6:09:05 PM > 10. Go to dial window. INFO : 5/13/2014 6:09:05 PM > 11. Enter "*#9090#" number. INFO : 5/13/2014 6:09:05 PM > 12. Set "Diag config" to "USB" value. INFO : 5/13/2014 6:09:05 PM > 13. Restart phone. INFO : 5/13/2014 6:09:05 PM > 14. Press "Read Info" in software. INFO : 5/13/2014 6:10:00 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:10:00 PM > To connect SM-N9005 phone you have to perform the following steps: INFO : 5/13/2014 6:10:00 PM > 1. Disconnect USB cable from phone. INFO : 5/13/2014 6:10:00 PM > 2. Go to Menu->Settings->More->About Device. INFO : 5/13/2014 6:10:00 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 5/13/2014 6:10:00 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 5/13/2014 6:10:00 PM > 5. Turn on "USB Debugging" option. INFO : 5/13/2014 6:10:00 PM > 6. Go to dial window. INFO : 5/13/2014 6:10:00 PM > 7. Enter "*#0808#" number. INFO : 5/13/2014 6:10:00 PM > 8. Select "DM+Modem+ADB". INFO : 5/13/2014 6:10:00 PM > 9. Press Home button. INFO : 5/13/2014 6:10:00 PM > 10. Go to dial window. INFO : 5/13/2014 6:10:00 PM > 11. Enter "*#9090#" number. INFO : 5/13/2014 6:10:00 PM > 12. Set "Diag config" to "USB" value. INFO : 5/13/2014 6:10:00 PM > 13. Restart phone. INFO : 5/13/2014 6:10:00 PM > 14. Press "Read Info" in software. INFO : 5/13/2014 6:10:08 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:10:08 PM > Platform: Samsung Android INFO : 5/13/2014 6:10:08 PM > Selected port: COM7 INFO : 5/13/2014 6:10:08 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:10:11 PM > Phone was not found on the selected port! INFO : 5/13/2014 6:10:11 PM > Searching for USB diagnostic port... INFO : 5/13/2014 6:10:11 PM > Connecting to phone on COM6 INFO : 5/13/2014 6:10:11 PM > Mode: Normal INFO : 5/13/2014 6:10:11 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:10:12 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:10:12 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:10:12 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:10:12 PM > Firmware released time: 16:10:34 INFO : 5/13/2014 6:10:12 PM > Phone IMEI: 352991-06-245228-3 INFO : 5/13/2014 6:10:12 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:10:19 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:10:19 PM > Platform: Samsung Android INFO : 5/13/2014 6:10:19 PM > Selected port: COM6 INFO : 5/13/2014 6:10:19 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:10:19 PM > Port is busy INFO : 5/13/2014 6:10:22 PM > Phone was not found on the selected port! INFO : 5/13/2014 6:10:22 PM > Searching for USB diagnostic port... INFO : 5/13/2014 6:10:22 PM > Connecting to phone on COM6 WARN : 5/13/2014 6:10:22 PM > Phone connection failed INFO : 5/13/2014 6:10:22 PM > Connecting to phone on COM7 WARN : 5/13/2014 6:10:22 PM > Phone connection failed WARN : 5/13/2014 6:10:22 PM > No diagnostic ports found! INFO : 5/13/2014 6:10:22 PM > Connecting to phone on COM34 WARN : 5/13/2014 6:10:23 PM > Phone connection failed ERROR : 5/13/2014 6:10:23 PM > Selected action can’t be performed INFO : 5/13/2014 6:10:26 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:10:26 PM > Platform: Samsung Android INFO : 5/13/2014 6:10:26 PM > Selected port: COM7 INFO : 5/13/2014 6:10:26 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:10:57 PM > Mode: Emergency ERROR : 5/13/2014 6:10:57 PM > Unlock for SM-N9005 phone in emergency mode can’t be done INFO : 5/13/2014 6:12:22 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:12:22 PM > Platform: Samsung Android INFO : 5/13/2014 6:12:22 PM > Selected port: COM34 INFO : 5/13/2014 6:12:22 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:12:51 PM > Mode: Emergency ERROR : 5/13/2014 6:12:51 PM > Unlock for SM-N9005 phone in emergency mode can’t be done INFO : 5/13/2014 6:12:59 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:12:59 PM > Platform: Samsung Android INFO : 5/13/2014 6:12:59 PM > Selected port: COM7 INFO : 5/13/2014 6:12:59 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:13:30 PM > Mode: Emergency ERROR : 5/13/2014 6:13:30 PM > Unlock for SM-N9005 phone in emergency mode can’t be done INFO : 5/13/2014 6:13:49 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:13:49 PM > Platform: Samsung Android INFO : 5/13/2014 6:13:50 PM > Selected port: COM6 INFO : 5/13/2014 6:13:50 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:13:50 PM > Mode: Normal INFO : 5/13/2014 6:13:50 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:13:50 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:13:50 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:13:50 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:13:50 PM > Firmware released time: 16:10:34 INFO : 5/13/2014 6:13:50 PM > Phone IMEI: 352991-06-245228-3 INFO : 5/13/2014 6:13:50 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:13:51 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:13:51 PM > Platform: Samsung Android INFO : 5/13/2014 6:13:51 PM > Selected port: COM6 INFO : 5/13/2014 6:13:51 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:13:52 PM > Mode: Normal INFO : 5/13/2014 6:13:52 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:13:52 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:13:52 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:13:52 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:13:52 PM > Firmware released time: 16:10:34 INFO : 5/13/2014 6:13:52 PM > Phone IMEI: 352991-06-245228-3 INFO : 5/13/2014 6:13:52 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:13:52 PM > Unlocking phone... INFO : 5/13/2014 6:13:54 PM > Creating NVM backup INFO : 5/13/2014 6:14:57 PM > Reading NVM done! INFO : 5/13/2014 6:14:57 PM > Connecting to ADB, please waite... INFO : 5/13/2014 6:14:58 PM > ADB server killed. INFO : 5/13/2014 6:15:01 PM > Firmware compiled date: Wed Feb 12 17:24:44 KST 2014 INFO : 5/13/2014 6:15:02 PM > PDA version: N9005XXUENB4 INFO : 5/13/2014 6:15:02 PM > CSC version: N9005H3GENB3 INFO : 5/13/2014 6:15:03 PM > SW version: N9005XXUENB1 INFO : 5/13/2014 6:15:04 PM > Phone IMEI: 352991062452283 INFO : 5/13/2014 6:15:05 PM > Phone SN: RF8F30CR9NX INFO : 5/13/2014 6:15:05 PM > Android version: 4.4.2 (KOT49H) INFO : 5/13/2014 6:15:05 PM > Cheking Root INFO : 5/13/2014 6:15:13 PM > Erasing old IMEI. It can take some time. Please wait... INFO : 5/13/2014 6:15:13 PM > Reading security backup, please wait... INFO : 5/13/2014 6:15:23 PM > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N9005-352991062452283-13-05-2014_18-15-13-.asec file WARN : 5/13/2014 6:15:41 PM > Phone will restart now. Please don't disconnect cable! WARN : 5/13/2014 6:17:00 PM > After phone being rebooted and powered on perform the following steps: WARN : 5/13/2014 6:17:00 PM > 1. Disconnect USB cable. WARN : 5/13/2014 6:17:00 PM > 2. Wait for 1-2 minutes. WARN : 5/13/2014 6:17:00 PM > 3. Connect phone via UART cable to the Box. INFO : 5/13/2014 6:17:00 PM > Serching phone... INFO : 5/13/2014 6:17:26 PM > Phone found. INFO : 5/13/2014 6:17:26 PM > Writing new IMEI. Please wait... ERROR : 5/13/2014 6:17:38 PM > Phone unlocking failed INFO : 5/13/2014 6:33:00 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:33:00 PM > Platform: Samsung Android INFO : 5/13/2014 6:33:00 PM > Selected port: COM6 INFO : 5/13/2014 6:33:00 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:33:00 PM > Port is busy INFO : 5/13/2014 6:33:03 PM > Phone was not found on the selected port! INFO : 5/13/2014 6:33:03 PM > Searching for USB diagnostic port... WARN : 5/13/2014 6:33:03 PM > No diagnostic ports found! INFO : 5/13/2014 6:33:03 PM > Connecting to phone on COM34 WARN : 5/13/2014 6:33:03 PM > Phone connection failed ERROR : 5/13/2014 6:33:03 PM > Selected action can’t be performed INFO : 5/13/2014 6:38:42 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:38:42 PM > Platform: Samsung Android INFO : 5/13/2014 6:38:42 PM > Selected port: COM6 INFO : 5/13/2014 6:38:42 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:38:42 PM > Mode: Normal INFO : 5/13/2014 6:38:42 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:38:42 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:38:42 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:38:42 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:38:42 PM > Firmware released time: 16:10:34 INFO : 5/13/2014 6:38:42 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:38:42 PM > Old IMEI: 004400-15-202000-0 INFO : 5/13/2014 6:38:42 PM > New IMEI: 352991-06-245228-3 ERROR : 5/13/2014 6:38:42 PM > Please select service IMEI for this phone model ERROR : 5/13/2014 6:38:42 PM > Write IMEI failed INFO : 5/13/2014 6:38:57 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:38:57 PM > Platform: Samsung Android INFO : 5/13/2014 6:38:57 PM > Selected port: COM6 INFO : 5/13/2014 6:38:57 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:38:57 PM > Mode: Normal INFO : 5/13/2014 6:38:57 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:38:57 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:38:57 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:38:57 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:38:57 PM > Firmware released time: 16:10:34 INFO : 5/13/2014 6:38:57 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:38:57 PM > Old IMEI: 004400-15-202000-0 INFO : 5/13/2014 6:38:57 PM > New IMEI: 352991-06-245228-3 ERROR : 5/13/2014 6:38:57 PM > Please select service IMEI for this phone model ERROR : 5/13/2014 6:38:57 PM > Write IMEI failed INFO : 5/13/2014 6:42:46 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:42:46 PM > Platform: Samsung Android INFO : 5/13/2014 6:42:46 PM > Selected port: COM7 INFO : 5/13/2014 6:42:46 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:42:50 PM > Phone was not found on the selected port! INFO : 5/13/2014 6:42:50 PM > Searching for USB diagnostic port... INFO : 5/13/2014 6:42:50 PM > Connecting to phone on COM6 INFO : 5/13/2014 6:42:50 PM > Mode: Normal INFO : 5/13/2014 6:42:50 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:42:50 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:42:50 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:42:50 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:42:50 PM > Firmware released time: 16:10:34 WARN : 5/13/2014 6:42:50 PM > Incorrect IMEI INFO : 5/13/2014 6:42:50 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:45:04 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:45:04 PM > Platform: Samsung Android INFO : 5/13/2014 6:45:04 PM > Selected port: COM6 INFO : 5/13/2014 6:45:04 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:45:04 PM > Port is busy INFO : 5/13/2014 6:45:07 PM > Phone was not found on the selected port! INFO : 5/13/2014 6:45:07 PM > Searching for USB diagnostic port... INFO : 5/13/2014 6:45:07 PM > Connecting to phone on COM6 WARN : 5/13/2014 6:45:07 PM > Phone connection failed INFO : 5/13/2014 6:45:07 PM > Connecting to phone on COM7 WARN : 5/13/2014 6:45:07 PM > Phone connection failed WARN : 5/13/2014 6:45:07 PM > No diagnostic ports found! INFO : 5/13/2014 6:45:07 PM > Connecting to phone on COM34 WARN : 5/13/2014 6:45:07 PM > Phone connection failed ERROR : 5/13/2014 6:45:07 PM > Selected action can’t be performed INFO : 5/13/2014 6:45:11 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:45:11 PM > Platform: Samsung Android INFO : 5/13/2014 6:45:11 PM > Selected port: COM7 INFO : 5/13/2014 6:45:11 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:45:41 PM > Mode: Emergency ERROR : 5/13/2014 6:45:42 PM > Write IMEI failed INFO : 5/13/2014 6:46:08 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:46:08 PM > Platform: Samsung Android INFO : 5/13/2014 6:46:08 PM > Selected port: COM7 INFO : 5/13/2014 6:46:08 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:46:39 PM > Mode: Emergency ERROR : 5/13/2014 6:46:39 PM > Unlock for SM-N9005 phone in emergency mode can’t be done INFO : 5/13/2014 6:46:53 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:46:53 PM > Platform: Samsung Android INFO : 5/13/2014 6:46:53 PM > Selected port: COM34 INFO : 5/13/2014 6:46:53 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:46:56 PM > Phone was not found on the selected port! INFO : 5/13/2014 6:46:56 PM > Searching for USB diagnostic port... INFO : 5/13/2014 6:46:57 PM > Connecting to phone on COM6 INFO : 5/13/2014 6:46:57 PM > Mode: Normal INFO : 5/13/2014 6:46:57 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:46:57 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:46:57 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:46:57 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:46:57 PM > Firmware released time: 16:10:34 WARN : 5/13/2014 6:46:57 PM > Incorrect IMEI INFO : 5/13/2014 6:46:57 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:47:09 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:47:09 PM > Platform: Samsung Android INFO : 5/13/2014 6:47:09 PM > Selected port: COM6 INFO : 5/13/2014 6:47:09 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:47:09 PM > Mode: Normal INFO : 5/13/2014 6:47:09 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:47:09 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:47:09 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:47:09 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:47:09 PM > Firmware released time: 16:10:34 INFO : 5/13/2014 6:47:09 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:47:09 PM > Old IMEI: 004400-15-202000-0 INFO : 5/13/2014 6:47:09 PM > New IMEI: 004400-15-202000-0 ERROR : 5/13/2014 6:47:09 PM > Please, enter the new IMEI INFO : 5/13/2014 6:47:28 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:47:28 PM > Platform: Samsung Android INFO : 5/13/2014 6:47:28 PM > Selected port: COM6 INFO : 5/13/2014 6:47:29 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:47:29 PM > Mode: Normal INFO : 5/13/2014 6:47:29 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:47:29 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:47:29 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:47:29 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:47:29 PM > Firmware released time: 16:10:34 WARN : 5/13/2014 6:47:29 PM > Incorrect IMEI INFO : 5/13/2014 6:47:29 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:47:34 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:47:34 PM > Platform: Samsung Android INFO : 5/13/2014 6:47:34 PM > Selected port: COM6 INFO : 5/13/2014 6:47:34 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:47:34 PM > Port is busy INFO : 5/13/2014 6:47:36 PM > Phone was not found on the selected port! INFO : 5/13/2014 6:47:36 PM > Searching for USB diagnostic port... INFO : 5/13/2014 6:47:36 PM > Connecting to phone on COM6 WARN : 5/13/2014 6:47:36 PM > Phone connection failed INFO : 5/13/2014 6:47:36 PM > Connecting to phone on COM7 WARN : 5/13/2014 6:47:36 PM > Phone connection failed WARN : 5/13/2014 6:47:36 PM > No diagnostic ports found! INFO : 5/13/2014 6:47:36 PM > Connecting to phone on COM34 WARN : 5/13/2014 6:47:36 PM > Phone connection failed INFO : 5/13/2014 6:47:47 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:47:47 PM > Platform: Samsung Android INFO : 5/13/2014 6:47:47 PM > Selected port: COM6 INFO : 5/13/2014 6:47:47 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:47:47 PM > Mode: Normal INFO : 5/13/2014 6:47:47 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:47:47 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:47:47 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:47:47 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:47:47 PM > Firmware released time: 16:10:34 INFO : 5/13/2014 6:47:47 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:47:47 PM > Old IMEI: 004400-15-202000-0 INFO : 5/13/2014 6:47:47 PM > New IMEI: 352991-06-245228-3 ERROR : 5/13/2014 6:47:47 PM > Please select service IMEI for this phone model ERROR : 5/13/2014 6:47:47 PM > Write IMEI failed INFO : 5/13/2014 6:49:36 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:49:36 PM > Platform: Samsung Android INFO : 5/13/2014 6:49:36 PM > Selected port: COM6 INFO : 5/13/2014 6:49:36 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:49:36 PM > Mode: Normal INFO : 5/13/2014 6:49:36 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:49:36 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:49:36 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:49:36 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:49:36 PM > Firmware released time: 16:10:34 INFO : 5/13/2014 6:49:36 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:49:36 PM > Old IMEI: 004400-15-202000-0 INFO : 5/13/2014 6:49:36 PM > New IMEI: 352991-06-245228-3 ERROR : 5/13/2014 6:49:36 PM > Please select service IMEI for this phone model ERROR : 5/13/2014 6:49:36 PM > Write IMEI failed INFO : 5/13/2014 6:49:57 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:49:57 PM > Platform: Samsung Android INFO : 5/13/2014 6:49:57 PM > Selected port: COM6 INFO : 5/13/2014 6:49:57 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:49:57 PM > Mode: Normal INFO : 5/13/2014 6:49:57 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:49:57 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:49:57 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:49:57 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:49:57 PM > Firmware released time: 16:10:34 WARN : 5/13/2014 6:49:57 PM > Incorrect IMEI INFO : 5/13/2014 6:49:57 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:50:01 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:50:01 PM > Platform: Samsung Android INFO : 5/13/2014 6:50:01 PM > Selected port: COM6 INFO : 5/13/2014 6:50:01 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:50:01 PM > Mode: Normal INFO : 5/13/2014 6:50:02 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:50:02 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:50:02 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:50:02 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:50:02 PM > Firmware released time: 16:10:34 WARN : 5/13/2014 6:50:02 PM > Incorrect IMEI INFO : 5/13/2014 6:50:02 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:50:03 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:50:03 PM > Platform: Samsung Android INFO : 5/13/2014 6:50:03 PM > Selected port: COM6 INFO : 5/13/2014 6:50:03 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:50:03 PM > Mode: Normal INFO : 5/13/2014 6:50:03 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:50:03 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:50:03 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:50:03 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:50:03 PM > Firmware released time: 16:10:34 WARN : 5/13/2014 6:50:03 PM > Incorrect IMEI INFO : 5/13/2014 6:50:03 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:50:06 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:50:06 PM > Platform: Samsung Android INFO : 5/13/2014 6:50:06 PM > Selected port: COM6 INFO : 5/13/2014 6:50:06 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:50:06 PM > Mode: Normal INFO : 5/13/2014 6:50:06 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:50:06 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:50:06 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:50:06 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:50:06 PM > Firmware released time: 16:10:34 WARN : 5/13/2014 6:50:06 PM > Incorrect IMEI INFO : 5/13/2014 6:50:06 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:50:07 PM > Unlocking phone... INFO : 5/13/2014 6:50:18 PM > Creating NVM backup INFO : 5/13/2014 6:51:21 PM > Reading NVM done! INFO : 5/13/2014 6:51:21 PM > Connecting to ADB, please waite... INFO : 5/13/2014 6:51:22 PM > Firmware compiled date: Wed Feb 12 17:24:44 KST 2014 INFO : 5/13/2014 6:51:22 PM > PDA version: N9005XXUENB4 INFO : 5/13/2014 6:51:23 PM > CSC version: N9005H3GENB3 INFO : 5/13/2014 6:51:24 PM > SW version: N9005XXUENB1 INFO : 5/13/2014 6:51:25 PM > Phone IMEI: Unknown INFO : 5/13/2014 6:51:25 PM > Phone SN: RF8F30CR9NX INFO : 5/13/2014 6:51:25 PM > Android version: 4.4.2 (KOT49H) INFO : 5/13/2014 6:51:25 PM > Cheking Root INFO : 5/13/2014 6:51:27 PM > Erasing old IMEI. It can take some time. Please wait... INFO : 5/13/2014 6:51:27 PM > Reading security backup, please wait... INFO : 5/13/2014 6:51:38 PM > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N9005-13-05-2014_18-51-27-.asec file WARN : 5/13/2014 6:52:00 PM > Phone will restart now. Please don't disconnect cable! WARN : 5/13/2014 6:52:45 PM > After phone being rebooted and powered on perform the following steps: WARN : 5/13/2014 6:52:45 PM > 1. Disconnect USB cable. WARN : 5/13/2014 6:52:45 PM > 2. Wait for 1-2 minutes. WARN : 5/13/2014 6:52:45 PM > 3. Connect phone via UART cable to the Box. INFO : 5/13/2014 6:52:45 PM > Serching phone... INFO : 5/13/2014 6:53:39 PM > Phone found. INFO : 5/13/2014 6:53:39 PM > Writing new IMEI. Please wait... WARN : 5/13/2014 6:54:07 PM > Please connect phone to USB cable and press OK button. INFO : 5/13/2014 6:54:07 PM > Serching phone... INFO : 5/13/2014 6:54:18 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:54:18 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:54:18 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:54:18 PM > Firmware released time: 16:10:34 INFO : 5/13/2014 6:54:18 PM > Phone IMEI: 357507-05-000001-0 INFO : 5/13/2014 6:54:18 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:54:18 PM > Found phone on COM6 INFO : 5/13/2014 6:54:19 PM > Repairing NVM for SM-N9005 phone... INFO : 5/13/2014 6:54:23 PM > Repairing 3G/4G... INFO : 5/13/2014 6:54:29 PM > 3G/4G repair successfully INFO : 5/13/2014 6:54:29 PM > Phone is successfully unlocked INFO : 5/13/2014 6:58:12 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 6:58:12 PM > Platform: Samsung Android INFO : 5/13/2014 6:58:12 PM > Selected port: COM6 INFO : 5/13/2014 6:58:12 PM > Selected model: SM-N9005 INFO : 5/13/2014 6:58:12 PM > Mode: Normal INFO : 5/13/2014 6:58:12 PM > Phone model: SM-N9005 INFO : 5/13/2014 6:58:12 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 6:58:12 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 6:58:12 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 6:58:12 PM > Firmware released time: 16:10:34 INFO : 5/13/2014 6:58:12 PM > Phone IMEI: 357507-05-000001-0 INFO : 5/13/2014 6:58:12 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 6:58:12 PM > Unlocking phone... INFO : 5/13/2014 6:58:24 PM > Creating NVM backup INFO : 5/13/2014 6:59:00 PM > Reading NVM done! INFO : 5/13/2014 6:59:00 PM > Connecting to ADB, please waite... INFO : 5/13/2014 6:59:00 PM > Firmware compiled date: Wed Feb 12 17:24:44 KST 2014 INFO : 5/13/2014 6:59:01 PM > PDA version: N9005XXUENB4 INFO : 5/13/2014 6:59:01 PM > CSC version: N9005H3GENB3 INFO : 5/13/2014 6:59:02 PM > SW version: N9005XXUENB1 INFO : 5/13/2014 6:59:03 PM > Phone IMEI: 357507050000010 INFO : 5/13/2014 6:59:03 PM > Phone SN: RF8F30CR9NX INFO : 5/13/2014 6:59:03 PM > Android version: 4.4.2 (KOT49H) INFO : 5/13/2014 6:59:03 PM > Cheking Root INFO : 5/13/2014 6:59:06 PM > Erasing old IMEI. It can take some time. Please wait... INFO : 5/13/2014 6:59:06 PM > Reading security backup, please wait... INFO : 5/13/2014 6:59:16 PM > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N9005-357507050000010-13-05-2014_18-59-06-.asec file WARN : 5/13/2014 6:59:38 PM > Phone will restart now. Please don't disconnect cable! WARN : 5/13/2014 7:00:26 PM > After phone being rebooted and powered on perform the following steps: WARN : 5/13/2014 7:00:26 PM > 1. Disconnect USB cable. WARN : 5/13/2014 7:00:26 PM > 2. Wait for 1-2 minutes. WARN : 5/13/2014 7:00:26 PM > 3. Connect phone via UART cable to the Box. INFO : 5/13/2014 7:00:26 PM > Serching phone... INFO : 5/13/2014 7:09:59 PM > Phone unlocking was canceled INFO : 5/13/2014 7:11:01 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:11:01 PM > Platform: Samsung Android INFO : 5/13/2014 7:11:01 PM > Selected port: COM6 INFO : 5/13/2014 7:11:01 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:11:01 PM > Port is busy INFO : 5/13/2014 7:11:03 PM > Phone was not found on the selected port! INFO : 5/13/2014 7:11:03 PM > Searching for USB diagnostic port... INFO : 5/13/2014 7:11:03 PM > Connecting to phone on COM6 WARN : 5/13/2014 7:11:03 PM > Phone connection failed INFO : 5/13/2014 7:11:03 PM > Connecting to phone on COM7 WARN : 5/13/2014 7:11:03 PM > Phone connection failed WARN : 5/13/2014 7:11:03 PM > No diagnostic ports found! INFO : 5/13/2014 7:11:03 PM > Connecting to phone on COM34 WARN : 5/13/2014 7:11:03 PM > Port is busy INFO : 5/13/2014 7:11:07 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:11:07 PM > Platform: Samsung Android INFO : 5/13/2014 7:11:08 PM > Selected port: COM7 INFO : 5/13/2014 7:11:08 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:11:11 PM > Phone was not found on the selected port! INFO : 5/13/2014 7:11:11 PM > Searching for USB diagnostic port... INFO : 5/13/2014 7:11:11 PM > Connecting to phone on COM6 INFO : 5/13/2014 7:11:11 PM > Mode: Normal INFO : 5/13/2014 7:11:11 PM > Phone model: SM-N9005 INFO : 5/13/2014 7:11:11 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 7:11:11 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 7:11:11 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 7:11:11 PM > Firmware released time: 16:10:34 WARN : 5/13/2014 7:11:11 PM > Incorrect IMEI INFO : 5/13/2014 7:11:11 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 7:11:15 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:11:15 PM > Platform: Samsung Android INFO : 5/13/2014 7:11:15 PM > Selected port: COM6 INFO : 5/13/2014 7:11:15 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:11:15 PM > Mode: Normal INFO : 5/13/2014 7:11:15 PM > Phone model: SM-N9005 INFO : 5/13/2014 7:11:15 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 7:11:15 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 7:11:15 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 7:11:15 PM > Firmware released time: 16:10:34 WARN : 5/13/2014 7:11:15 PM > Incorrect IMEI INFO : 5/13/2014 7:11:15 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 7:11:15 PM > Unlocking phone... INFO : 5/13/2014 7:11:21 PM > Creating NVM backup INFO : 5/13/2014 7:12:06 PM > Reading NVM done! INFO : 5/13/2014 7:12:06 PM > Connecting to ADB, please waite... INFO : 5/13/2014 7:12:07 PM > Firmware compiled date: Wed Feb 12 17:24:44 KST 2014 INFO : 5/13/2014 7:12:08 PM > PDA version: N9005XXUENB4 INFO : 5/13/2014 7:12:08 PM > CSC version: N9005H3GENB3 INFO : 5/13/2014 7:12:09 PM > SW version: N9005XXUENB1 INFO : 5/13/2014 7:12:10 PM > Phone IMEI: Unknown INFO : 5/13/2014 7:12:10 PM > Phone SN: RF8F30CR9NX INFO : 5/13/2014 7:12:10 PM > Android version: 4.4.2 (KOT49H) INFO : 5/13/2014 7:12:10 PM > Cheking Root INFO : 5/13/2014 7:12:13 PM > Erasing old IMEI. It can take some time. Please wait... INFO : 5/13/2014 7:12:13 PM > Reading security backup, please wait... INFO : 5/13/2014 7:12:23 PM > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N9005-13-05-2014_19-12-13-.asec file WARN : 5/13/2014 7:12:42 PM > Phone will restart now. Please don't disconnect cable! WARN : 5/13/2014 7:13:24 PM > After phone being rebooted and powered on perform the following steps: WARN : 5/13/2014 7:13:24 PM > 1. Disconnect USB cable. WARN : 5/13/2014 7:13:24 PM > 2. Wait for 1-2 minutes. WARN : 5/13/2014 7:13:24 PM > 3. Connect phone via UART cable to the Box. INFO : 5/13/2014 7:13:24 PM > Serching phone... INFO : 5/13/2014 7:15:33 PM > Phone unlocking was canceled INFO : 5/13/2014 7:21:15 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:21:15 PM > Platform: Samsung Android INFO : 5/13/2014 7:21:15 PM > Selected port: COM7 INFO : 5/13/2014 7:21:15 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:21:25 PM > Mode: Emergency ERROR : 5/13/2014 7:21:25 PM > Unlock for SM-N9005 phone in emergency mode can’t be done INFO : 5/13/2014 7:22:13 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:22:13 PM > Platform: Samsung Android INFO : 5/13/2014 7:22:13 PM > Selected port: COM34 INFO : 5/13/2014 7:22:13 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:22:13 PM > Port is busy INFO : 5/13/2014 7:22:15 PM > Phone was not found on the selected port! INFO : 5/13/2014 7:22:15 PM > Searching for USB diagnostic port... INFO : 5/13/2014 7:22:15 PM > Connecting to phone on COM6 WARN : 5/13/2014 7:22:15 PM > Phone connection failed INFO : 5/13/2014 7:22:15 PM > Connecting to phone on COM7 WARN : 5/13/2014 7:22:15 PM > Phone connection failed WARN : 5/13/2014 7:22:15 PM > No diagnostic ports found! INFO : 5/13/2014 7:22:15 PM > Connecting to phone on COM34 WARN : 5/13/2014 7:22:15 PM > Port is busy ERROR : 5/13/2014 7:22:15 PM > Selected action can’t be performed INFO : 5/13/2014 7:22:19 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:22:19 PM > Platform: Samsung Android INFO : 5/13/2014 7:22:19 PM > Selected port: COM7 INFO : 5/13/2014 7:22:19 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:22:49 PM > Mode: Emergency ERROR : 5/13/2014 7:22:49 PM > Unlock for SM-N9005 phone in emergency mode can’t be done INFO : 5/13/2014 7:22:52 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:22:52 PM > Platform: Samsung Android INFO : 5/13/2014 7:22:52 PM > Selected port: COM7 INFO : 5/13/2014 7:22:52 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:22:56 PM > Phone was not found on the selected port! INFO : 5/13/2014 7:22:56 PM > Searching for USB diagnostic port... INFO : 5/13/2014 7:22:56 PM > Connecting to phone on COM7 INFO : 5/13/2014 7:23:12 PM > Mode: Emergency INFO : 5/13/2014 7:23:59 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:23:59 PM > Platform: Samsung Android INFO : 5/13/2014 7:23:59 PM > Selected port: COM34 INFO : 5/13/2014 7:24:00 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:24:00 PM > Port is busy INFO : 5/13/2014 7:24:02 PM > Phone was not found on the selected port! INFO : 5/13/2014 7:24:02 PM > Searching for USB diagnostic port... INFO : 5/13/2014 7:24:02 PM > Connecting to phone on COM7 WARN : 5/13/2014 7:24:02 PM > Phone connection failed INFO : 5/13/2014 7:24:02 PM > Connecting to phone on COM6 WARN : 5/13/2014 7:24:02 PM > Port is busy WARN : 5/13/2014 7:24:02 PM > No diagnostic ports found! INFO : 5/13/2014 7:24:02 PM > Connecting to phone on COM34 WARN : 5/13/2014 7:24:02 PM > Port is busy INFO : 5/13/2014 7:24:06 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:24:06 PM > Platform: Samsung Android INFO : 5/13/2014 7:24:06 PM > Selected port: COM7 INFO : 5/13/2014 7:24:06 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:24:09 PM > Phone was not found on the selected port! INFO : 5/13/2014 7:24:09 PM > Searching for USB diagnostic port... INFO : 5/13/2014 7:24:09 PM > Connecting to phone on COM7 WARN : 5/13/2014 7:24:09 PM > Phone connection failed INFO : 5/13/2014 7:24:09 PM > Connecting to phone on COM6 WARN : 5/13/2014 7:24:09 PM > Phone connection failed WARN : 5/13/2014 7:24:09 PM > No diagnostic ports found! INFO : 5/13/2014 7:24:09 PM > Connecting to phone on COM34 WARN : 5/13/2014 7:24:09 PM > Port is busy INFO : 5/13/2014 7:24:16 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:24:16 PM > Platform: Samsung Android INFO : 5/13/2014 7:24:16 PM > Selected port: COM7 INFO : 5/13/2014 7:24:16 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:24:28 PM > Mode: Emergency ERROR : 5/13/2014 7:24:28 PM > Unlock for SM-N9005 phone in emergency mode can’t be done INFO : 5/13/2014 7:24:30 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:24:30 PM > Platform: Samsung Android INFO : 5/13/2014 7:24:30 PM > Selected port: COM7 INFO : 5/13/2014 7:24:30 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:24:33 PM > Phone was not found on the selected port! INFO : 5/13/2014 7:24:33 PM > Searching for USB diagnostic port... INFO : 5/13/2014 7:24:33 PM > Connecting to phone on COM7 INFO : 5/13/2014 7:25:03 PM > Mode: Emergency INFO : 5/13/2014 7:25:10 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:25:10 PM > Platform: Samsung Android INFO : 5/13/2014 7:25:10 PM > Selected port: COM7 INFO : 5/13/2014 7:25:10 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:25:10 PM > Port is busy INFO : 5/13/2014 7:25:11 PM > Phone was not found on the selected port! INFO : 5/13/2014 7:25:11 PM > Searching for USB diagnostic port... INFO : 5/13/2014 7:25:11 PM > Connecting to phone on COM7 WARN : 5/13/2014 7:25:11 PM > Phone connection failed INFO : 5/13/2014 7:25:11 PM > Connecting to phone on COM6 WARN : 5/13/2014 7:25:11 PM > Port is busy WARN : 5/13/2014 7:25:11 PM > No diagnostic ports found! INFO : 5/13/2014 7:25:11 PM > Connecting to phone on COM34 WARN : 5/13/2014 7:25:12 PM > Port is busy ERROR : 5/13/2014 7:25:12 PM > Selected action can’t be performed INFO : 5/13/2014 7:25:15 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:25:15 PM > Platform: Samsung Android INFO : 5/13/2014 7:25:15 PM > Selected port: COM34 INFO : 5/13/2014 7:25:15 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:25:15 PM > Port is busy INFO : 5/13/2014 7:25:17 PM > Phone was not found on the selected port! INFO : 5/13/2014 7:25:17 PM > Searching for USB diagnostic port... INFO : 5/13/2014 7:25:17 PM > Connecting to phone on COM7 WARN : 5/13/2014 7:25:18 PM > Phone connection failed INFO : 5/13/2014 7:25:18 PM > Connecting to phone on COM6 WARN : 5/13/2014 7:25:18 PM > Phone connection failed WARN : 5/13/2014 7:25:18 PM > No diagnostic ports found! INFO : 5/13/2014 7:25:18 PM > Connecting to phone on COM34 WARN : 5/13/2014 7:25:18 PM > Port is busy ERROR : 5/13/2014 7:25:18 PM > Selected action can’t be performed INFO : 5/13/2014 7:25:21 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:25:21 PM > Platform: Samsung Android INFO : 5/13/2014 7:25:21 PM > Selected port: COM6 INFO : 5/13/2014 7:25:21 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:25:22 PM > Mode: Normal INFO : 5/13/2014 7:25:22 PM > Phone model: SM-N9005 INFO : 5/13/2014 7:25:22 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 7:25:22 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 7:25:22 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 7:25:22 PM > Firmware released time: 16:10:34 WARN : 5/13/2014 7:25:22 PM > Incorrect IMEI INFO : 5/13/2014 7:25:22 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 7:25:22 PM > Unlocking phone... INFO : 5/13/2014 7:25:37 PM > Creating NVM backup INFO : 5/13/2014 7:26:42 PM > Reading NVM done! INFO : 5/13/2014 7:26:42 PM > Connecting to ADB, please waite... INFO : 5/13/2014 7:26:42 PM > Firmware compiled date: Wed Feb 12 17:24:44 KST 2014 INFO : 5/13/2014 7:26:43 PM > PDA version: N9005XXUENB4 INFO : 5/13/2014 7:26:43 PM > CSC version: N9005H3GENB3 INFO : 5/13/2014 7:26:44 PM > SW version: N9005XXUENB1 INFO : 5/13/2014 7:26:45 PM > Phone IMEI: Unknown INFO : 5/13/2014 7:26:46 PM > Phone SN: RF8F30CR9NX INFO : 5/13/2014 7:26:46 PM > Android version: 4.4.2 (KOT49H) INFO : 5/13/2014 7:26:46 PM > Cheking Root INFO : 5/13/2014 7:26:48 PM > Erasing old IMEI. It can take some time. Please wait... INFO : 5/13/2014 7:26:48 PM > Reading security backup, please wait... INFO : 5/13/2014 7:27:00 PM > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N9005-13-05-2014_19-26-48-.asec file WARN : 5/13/2014 7:27:22 PM > Phone will restart now. Please don't disconnect cable! WARN : 5/13/2014 7:28:14 PM > After phone being rebooted and powered on perform the following steps: WARN : 5/13/2014 7:28:14 PM > 1. Disconnect USB cable. WARN : 5/13/2014 7:28:14 PM > 2. Wait for 1-2 minutes. WARN : 5/13/2014 7:28:14 PM > 3. Connect phone via UART cable to the Box. INFO : 5/13/2014 7:28:14 PM > Serching phone... INFO : 5/13/2014 7:29:06 PM > Phone unlocking was canceled INFO : 5/13/2014 7:29:16 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:29:16 PM > Platform: Samsung Android INFO : 5/13/2014 7:29:16 PM > Selected port: COM6 INFO : 5/13/2014 7:29:16 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:29:16 PM > Port is busy INFO : 5/13/2014 7:29:20 PM > Mode: Emergency INFO : 5/13/2014 7:29:37 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:29:37 PM > Platform: Samsung Android INFO : 5/13/2014 7:29:37 PM > Selected port: COM6 INFO : 5/13/2014 7:29:37 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:29:37 PM > Port is busy INFO : 5/13/2014 7:29:40 PM > Phone was not found on the selected port! INFO : 5/13/2014 7:29:40 PM > Searching for USB diagnostic port... WARN : 5/13/2014 7:29:40 PM > No diagnostic ports found! INFO : 5/13/2014 7:29:40 PM > Connecting to phone on COM34 WARN : 5/13/2014 7:29:40 PM > Port is busy ERROR : 5/13/2014 7:29:40 PM > Selected action can’t be performed INFO : 5/13/2014 7:30:07 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:30:07 PM > Platform: Samsung Android INFO : 5/13/2014 7:30:07 PM > Selected port: COM6 INFO : 5/13/2014 7:30:07 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:30:07 PM > Mode: Normal INFO : 5/13/2014 7:30:07 PM > Phone model: SM-N9005 INFO : 5/13/2014 7:30:07 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 7:30:07 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 7:30:07 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 7:30:07 PM > Firmware released time: 16:10:34 WARN : 5/13/2014 7:30:07 PM > Incorrect IMEI INFO : 5/13/2014 7:30:07 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 7:30:13 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:30:13 PM > Platform: Samsung Android INFO : 5/13/2014 7:30:13 PM > Selected port: COM6 INFO : 5/13/2014 7:30:13 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:30:13 PM > Mode: Normal INFO : 5/13/2014 7:30:13 PM > Phone model: SM-N9005 INFO : 5/13/2014 7:30:13 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 7:30:13 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 7:30:13 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 7:30:14 PM > Firmware released time: 16:10:34 WARN : 5/13/2014 7:30:14 PM > Incorrect IMEI INFO : 5/13/2014 7:30:14 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 7:30:14 PM > Unlocking phone... INFO : 5/13/2014 7:30:18 PM > Creating NVM backup INFO : 5/13/2014 7:31:22 PM > Reading NVM done! INFO : 5/13/2014 7:31:22 PM > Connecting to ADB, please waite... INFO : 5/13/2014 7:31:23 PM > Firmware compiled date: Wed Feb 12 17:24:44 KST 2014 INFO : 5/13/2014 7:31:24 PM > PDA version: N9005XXUENB4 INFO : 5/13/2014 7:31:24 PM > CSC version: N9005H3GENB3 INFO : 5/13/2014 7:31:25 PM > SW version: N9005XXUENB1 INFO : 5/13/2014 7:31:26 PM > Phone IMEI: Unknown INFO : 5/13/2014 7:31:27 PM > Phone SN: RF8F30CR9NX INFO : 5/13/2014 7:31:27 PM > Android version: 4.4.2 (KOT49H) INFO : 5/13/2014 7:31:27 PM > Cheking Root INFO : 5/13/2014 7:31:29 PM > Erasing old IMEI. It can take some time. Please wait... INFO : 5/13/2014 7:31:29 PM > Reading security backup, please wait... INFO : 5/13/2014 7:31:40 PM > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N9005-13-05-2014_19-31-29-.asec file WARN : 5/13/2014 7:32:02 PM > Phone will restart now. Please don't disconnect cable! WARN : 5/13/2014 7:33:52 PM > After phone being rebooted and powered on perform the following steps: WARN : 5/13/2014 7:33:52 PM > 1. Disconnect USB cable. WARN : 5/13/2014 7:33:52 PM > 2. Wait for 1-2 minutes. WARN : 5/13/2014 7:33:52 PM > 3. Connect phone via UART cable to the Box. INFO : 5/13/2014 7:33:52 PM > Serching phone... INFO : 5/13/2014 7:38:43 PM > Phone unlocking was canceled INFO : 5/13/2014 7:43:16 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:43:16 PM > Platform: Samsung Android INFO : 5/13/2014 7:43:16 PM > Selected port: COM7 INFO : 5/13/2014 7:43:16 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:43:27 PM > Mode: Emergency ERROR : 5/13/2014 7:43:27 PM > Unlock for SM-N9005 phone in emergency mode can’t be done INFO : 5/13/2014 7:43:42 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:43:42 PM > Platform: Samsung Android INFO : 5/13/2014 7:43:42 PM > Selected port: COM6 INFO : 5/13/2014 7:43:42 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:43:42 PM > Mode: Normal INFO : 5/13/2014 7:43:42 PM > Phone model: SM-N9005 INFO : 5/13/2014 7:43:42 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 7:43:42 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 7:43:42 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 7:43:42 PM > Firmware released time: 16:10:34 WARN : 5/13/2014 7:43:42 PM > Incorrect IMEI INFO : 5/13/2014 7:43:42 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 7:44:05 PM > ----------------------------------------------------------------------------------- INFO : 5/13/2014 7:44:05 PM > Platform: Samsung Android INFO : 5/13/2014 7:44:05 PM > Selected port: COM6 INFO : 5/13/2014 7:44:05 PM > Selected model: SM-N9005 INFO : 5/13/2014 7:44:06 PM > Mode: Normal INFO : 5/13/2014 7:44:06 PM > Phone model: SM-N9005 INFO : 5/13/2014 7:44:06 PM > Firmware compiled date: Dec 19 2013 INFO : 5/13/2014 7:44:06 PM > Firmware compiled time: 11:00:00 INFO : 5/13/2014 7:44:06 PM > Firmware released date: Feb 3 2014 INFO : 5/13/2014 7:44:06 PM > Firmware released time: 16:10:34 WARN : 5/13/2014 7:44:06 PM > Incorrect IMEI INFO : 5/13/2014 7:44:06 PM > SW version: M8974A-AAAANAZM-1.0.180102 INFO : 5/13/2014 7:44:06 PM > Unlocking phone... INFO : 5/13/2014 7:44:08 PM > Creating NVM backup INFO : 5/13/2014 7:45:13 PM > Reading NVM done! INFO : 5/13/2014 7:45:13 PM > Connecting to ADB, please waite... INFO : 5/13/2014 7:45:15 PM > Firmware compiled date: Wed Feb 12 17:24:44 KST 2014 INFO : 5/13/2014 7:45:16 PM > PDA version: N9005XXUENB4 INFO : 5/13/2014 7:45:16 PM > CSC version: N9005H3GENB3 INFO : 5/13/2014 7:45:17 PM > SW version: N9005XXUENB1 INFO : 5/13/2014 7:45:18 PM > Phone IMEI: Unknown INFO | |||
05-31-2014, 16:23 | #4 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If You want to restore phone's original IMEI - write this security backup: Quote:
If You will write this security backup: Quote:
06-02-2014, 19:46 | #5 (permalink) | |
Member: 823250 Status: Offline Sonork: 100.1587800 Thanks Meter: 187 | i m writting security but failed..... INFO : 5/13/2014 2:21:45 PM > Phone IMEI: 352991062452283 Quote:
