04-20-2016, 21:37 | #1 (permalink) |
No Life Poster Join Date: Apr 2015
Member: 2385655 Status: Offline Thanks Meter: 99 | n9005 week signal ----------------------------------------------------------------------------------- To connect SM-N9005 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM589 Selected model: SM-N9005 Reading info, please wait... ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N9005 Firmware compiled date: Tue Nov 24 18:44:37 KST 2015 PDA version: N9005XXUGBOK9 CSC version: N9005OJVGBOI1 SW version: N9005XXUGBOD3 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Country: KSA HW platform: msm8974 HW Chip: MSM8974 HW Modem: MSM8974 Codename: hltexx Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM589 Selected model: SM-N9005 Reading info... Phone was not found on the selected port! Writing QCN failed Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM589 Selected model: SM-N9005 Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM589 Selected model: SM-N9005 Reading info, please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N9005 Firmware compiled date: Sat Dec 20 05:17:44 KST 2014 PDA version: N9005XXUGBNL8 CSC version: N9005OXAGBNL8 SW version: N9005XXEGBNL8 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Country: UK & IRE HW platform: msm8974 HW Chip: MSM8974 HW Modem: MSM8974 Codename: hltexx Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM589 Selected model: SM-N9005 Selected file: C:\Documents and Settings\sadiqsajan\My Documents \Downloads\Cert-SM-N9005_357518050231117.cert ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N9005 Firmware compiled date: Sat Dec 20 05:17:44 KST 2014 PDA version: N9005XXUGBNL8 CSC version: N9005OXAGBNL8 SW version: N9005XXEGBNL8 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Country: UK & IRE HW platform: msm8974 HW Chip: MSM8974 HW Modem: MSM8974 Codename: hltexx Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Please Reset MSL first! Writing Certificate failed Performed by 2.2.4 software version |
04-20-2016, 21:40 | #2 (permalink) |
Member: 2385655 Status: Offline Thanks Meter: 99 | n9005 week signal Platform: Samsung Android Selected port: COM589 Selected model: SM-N9005 To Repair IMEI of the device, do the next steps: 1. Root the phone. 2. Perform Wipe Security procedure ("Repair Security/Wipe Security" button). 3. Write Certificate ("Write Cert" button). Performed by 2.2.4 software version Platform: Samsung Android Selected port: COM589 Selected model: SM-N9005 ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N9005 Firmware compiled date: Sat Dec 20 05:17:44 KST 2014 PDA version: N9005XXUGBNL8 CSC version: N9005OXAGBNL8 SW version: N9005XXEGBNL8 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Country: UK & IRE HW platform: msm8974 HW Chip: MSM8974 HW Modem: MSM8974 Codename: hltexx Reading info... Phone was not found on the selected port! Performed by 2.2.4 software version |
04-21-2016, 11:47 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please select "DM+Modem+ADB" option in *#0808# menu, reconnect the phone directly to PC, then try to read its info from "Main" tab of the Software. When phone's info will be read fully and correctly, try to perform necessary operation again. Post here result and full Software log of your actions. |
04-21-2016, 17:02 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please select "DM+Modem+ADB" option in *#0808# menu, reconnect the phone directly to PC, then try to read its info from "Main" tab of the Software. When phone's info will be read fully and correctly, try to perform necessary operation again. Post here result and full Software log of your actions. To repair phone's IMEI You do the next: 1. Perform "Wipe Security" operation. 2. Perform "Write Cert" operation. |
