07-12-2014, 14:57 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | N9005, what happen?, 4 devices NO detect, Read please Have 4 devices and all 4 in same condition, always that connect UART cable remain in Search.... I've 6/7 Uart cables Different and all tested also with Octopus with other Devices like N7100 4.3 and more other, so no UART problem. Have tryed with other BOX how Uart Interface but same problem...searchhhh phone.... Devices rootted Pefect and Knox disabled, but no one can unlock, here post Log of 1 of these N9005: Code: To connect SM-N9005 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N9005 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Dec 19 2013 Firmware compiled time: 11:00:00 Firmware released date: Jan 4 2014 Firmware released time: 00:08:59 Phone IMEI: 359093-05-508474-5 SW version: M8974A-AAAANAZM-1.0.180102 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-N9005 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Dec 19 2013 Firmware compiled time: 11:00:00 Firmware released date: Jan 4 2014 Firmware released time: 00:08:59 SW version: M8974A-AAAANAZM-1.0.180102 Old IMEI: 359093-05-508474-5 New IMEI: 357507-05-004345-7 Creating NVM backup Reading NVM done! Connecting to ADB, please waite... Firmware compiled date: Thu Jan 9 23:20:24 KST 2014 PDA version: N9005XXUENA6 CSC version: N9005OXXENA5 SW version: N9005XXUENA2 Phone IMEI: 359093055084745 Phone SN: RF1DA5ZZDDV Android version: 4.4.2 (KOT49H) Cheking Root Erasing old IMEI. It can take some time. Please wait... Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N9005-359093055084745-12-07-2014_12-38-49-.asec file Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. Serching phone... what think i do...tx Br allumts |
07-13-2014, 08:25 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Hello. There can be 2 reasons of the issue - problem with your cable or problem with COM port of your Box. Please try to use other Samsung Micro UART C3300k/C3303k cables with 523-525 kOhm resistor inside. Also try to use another Box as UART interface with cables, which You have. |
07-13-2014, 12:49 | #3 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
- My original Octopus UART cable (RX-AT-170 REXTORE 530K), always worked very very good, - Have build new One how Diagram, (Help in sw Uart Cable Pinout), with 525/30/36K resistor but same - Used my Original Rextore 530k cable few days ago with other devices 4.3 vers. all OK - Have connect only Octopus Card in P-Key Reader and Ns Pro how Interface with S7070 cable, (also this, always working), not ok - Have open Octopus and cecked RJ45 Port, have bypassed this disconnecting this one and soldered other NEW RJ45 but same...now have restored Original RJ45 and Test whith other devices and work, - Have changed many Fw 4.4.2, and in one N9005 have changed only "MODEM" Files becouse whith Original FW Imei/BB Unknown, changing CP(modem), other time Imei and Baseband ok, all others no issue with Fw, - Issue isn't with only 1 piece of N9005 but are 4 and is impossible that 4 over 4 no one is working?...only N9005 other devices No issues.... Loock this game have done also with selecting N9005w8, (are same phones), with Unlock and after Restore "Security BKP", Imei is changed but no Signal: Code: Welcome to Octoplus/Octopus Box Samsung software version 1.6.1 ----------------------------------------------------------------------------------- To connect SM-N900W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N900W8 Mode: Normal Phone model: SM-N900W8 Firmware compiled date: Dec 19 2013 Firmware compiled time: 11:00:00 Firmware released date: Feb 3 2014 Firmware released time: 16:10:34 Incorrect IMEI SW version: M8974A-AAAANAZM-1.0.180102 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N900W8 Warning: Selected model (SM-N900W8) differs from the detected one (SM-N9005)! If you want select (SM-N9005) as (SM-N900W8) model, please check "manual select". Writing security failed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N900W8 Detected phone model: SM-N9005 Firmware compiled date: Wed Feb 12 17:24:44 KST 2014 PDA version: N9005XXUENB4 CSC version: N9005ITVENB1 SW version: N9005XXUENB1 Phone IMEI: Unknown Phone SN: RF1DA5ZZDDV Android version: 4.4.2 (KOT49H) Writing security backup, please wait... Phone will restart now Security write successfully. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N900W8 Reading info, please wait... Detected phone model: SM-N9005 Firmware compiled date: Wed Feb 12 17:24:44 KST 2014 PDA version: N9005XXUENB4 CSC version: N9005ITVENB1 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- To connect SM-N9005 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N9005 Reading info, please wait... Detected phone model: SM-N9005 Firmware compiled date: Wed Feb 12 17:24:44 KST 2014 PDA version: N9005XXUENB4 CSC version: N9005ITVENB1 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N9005 Detected phone model: SM-N9005 Firmware compiled date: Wed Feb 12 17:24:44 KST 2014 PDA version: N9005XXUENB4 CSC version: N9005ITVENB1 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Writing security backup, please wait... Phone will restart now Security write successfully. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N9005 Reading info, please wait... Detected phone model: SM-N9005 Firmware compiled date: Wed Feb 12 17:24:44 KST 2014 PDA version: N9005XXUENB4 CSC version: N9005ITVENB1 SW version: N9005XXUENB1 Phone IMEI: 35909305508XXXX Phone SN: RF1DA5ZZDDV Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N9005 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Dec 19 2013 Firmware compiled time: 11:00:00 Firmware released date: Feb 3 2014 Firmware released time: 16:10:34 Phone IMEI: 359093-05-508XXXX SW version: M8974A-AAAANAZM-1.0.180102 Repairing 3G/4G... Reading nv... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\NV-SM-N9005-35909305508XXX-13-07-2014_12-02-48-.nv file 3G/4G repair successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N9005 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Dec 19 2013 Firmware compiled time: 11:00:00 Firmware released date: Feb 3 2014 Firmware released time: 16:10:34 Phone IMEI: 358588-05-XXX089-9 I've seen only 20% peoples good result but other 80% same issues, have all wrong UART CABLE? You know me that have helped many user but this time i think there's Issues with 4.4.2 Fw... in next update, (these days), put option in sw above or send Test Fw, thanks BR allumts | |
07-14-2014, 12:09 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Quote:
07-14-2014, 12:51 | #6 (permalink) | |
Please can you give me link of Fw that you or other customer have Flashed and Unlock/Repair gave successful?...i Test this fw and this time want try with 523k resistor, (with 525 no work), and if you can put EFS Repair in next Update i think it is very useful. N9005 is International version. Wait for Fw Link 4.4.2, 4.3 no issues, tx Br allumts | |
07-16-2014, 21:41 | #7 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello OCTOPUS SUPPORT, have solved all, Unlock/Imei Repaired at first time with 4.4.2 KK fw, HERE: Code: Welcome to Octoplus/Octopus Box Samsung software version 1.5.7 ----------------------------------------------------------------------------------- To connect SM-N9005 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-N9005 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM7 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Dec 19 2013 Firmware compiled time: 11:00:00 Firmware released date: Feb 3 2014 Firmware released time: 16:10:34 Phone IMEI: 358588-05-XXXXXX-X SW version: M8974A-AAAANAZM-1.0.180102 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-N9005 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Dec 19 2013 Firmware compiled time: 11:00:00 Firmware released date: Feb 3 2014 Firmware released time: 16:10:34 Incorrect IMEI SW version: M8974A-AAAANAZM-1.0.180102 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-N9005 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Dec 19 2013 Firmware compiled time: 11:00:00 Firmware released date: Feb 3 2014 Firmware released time: 16:10:34 Incorrect IMEI SW version: M8974A-AAAANAZM-1.0.180102 Repairing 3G/4G... 3G/4G repair successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-N9005 Mode: Normal Phone model: SM-N9005 Firmware compiled date: Dec 19 2013 Firmware compiled time: 11:00:00 Firmware released date: Feb 3 2014 Firmware released time: 16:10:34 SW version: M8974A-AAAANAZM-1.0.180102 Old IMEI: 35XXXX-05-XXXXXX-9 New IMEI: 35XXXX-05-XXXXXX-9 Creating NVM backup Reading NVM done! Connecting to ADB, please waite... Firmware compiled date: Wed Feb 12 17:24:44 KST 2014 PDA version: N9005XXUENB4 CSC version: N9005ITVENB1 SW version: N9005XXUENB1 Phone IMEI: 35XXXX05XXXXXX9 Phone SN: RF1DA5ZZDDV Android version: 4.4.2 (KOT49H) Cheking Root Erasing old IMEI. It can take some time. Please wait... Reading security backup, please wait... Backup saved as E:\Programmi\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N9005-358588053930899-16-07-2014_21-56-07-.asec file Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. Serching phone... Phone found. Writing new IMEI. Please wait... Please connect phone to USB cable and press OK button. Serching phone... Firmware compiled date: Dec 19 2013 Firmware compiled time: 11:00:00 Firmware released date: Feb 3 2014 Firmware released time: 16:10:34 SW version: M8974A-AAAANAZM-1.0.180102 Found phone on COM7 Repairing NVM for SM-N9005 phone... Repairing 3G/4G... 3G/4G repair successfully IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Code: Welcome to Octoplus/Octopus Box Samsung software version 1.5.7 ----------------------------------------------------------------------------------- To connect SM-N9005 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-N9005 Mode: Normal Phone model: SM-N9005 Firmware compiled date: May 01 2014 Firmware compiled time: 04:00:00 Firmware released date: May 22 2014 Firmware released time: 14:57:31 Incorrect IMEI SW version: M8974A-AAAANAZM-2.0.10055 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-N9005 Mode: Normal Phone model: SM-N9005 Firmware compiled date: May 01 2014 Firmware compiled time: 04:00:00 Firmware released date: May 22 2014 Firmware released time: 14:57:31 SW version: M8974A-AAAANAZM-2.0.10055 Old IMEI: 004400-15-202000-0 New IMEI: 35750X-05-XXXXXX-8 Creating NVM backup Reading NVM done! Connecting to ADB, please waite... Firmware compiled date: Mon Apr 14 17:38:48 KST 2014 PDA version: N9005XXUEND3 CSC version: N9005ITVEND1 SW version: N9005ZHUENE6 Phone IMEI: Unknown Phone SN: RF1D93DXXXX Android version: 4.4.2 (KOT49H) Cheking Root Erasing old IMEI. It can take some time. Please wait... Reading security backup, please wait... Backup saved as E:\Programmi\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N9005-16-07-2014_22-33-35-.asec file Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. Serching phone... Phone found. Writing new IMEI. Please wait... Please connect phone to USB cable and press OK button. Serching phone... Firmware compiled date: May 01 2014 Firmware compiled time: 04:00:00 Firmware released date: May 22 2014 Firmware released time: 14:57:31 SW version: M8974A-AAAANAZM-2.0.10055 Found phone on COM9 Repairing NVM for SM-N9005 phone... Repairing 3G/4G... 3G/4G repair successfully IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) BR allumts |
08-25-2014, 22:48 | #8 (permalink) |
No Life Poster Join Date: Jul 2006 Location: INDIA,TAMILNADU,PATTUKKOTTAI
Member: 304090 Status: Offline Thanks Meter: 210 | @allumts pls clear me.... reason for uart connection problem is firmware or uart cable? if cable then what is the correct resister value? if fw then what's the solution? |
08-26-2014, 06:23 | #9 (permalink) | |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
