02-27-2018, 15:16 | #1 (permalink) |
Freak Poster Join Date: Nov 2017
Member: 2776492 Status: Offline Thanks Meter: 43 | n910c samsung account need your attention [Answered] ----------------------------------------------------------------------------------- To connect SM-G6000 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N910C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N910C Reset FRP/ Reactivation lock operation for SM-N910C will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-N910C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.6.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N910C Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.6.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N910C Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.6.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N910C Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.6.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N910C Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging. Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-N910C Firmware compiled date: Fri Oct 30 08:32:39 KST 2015 PDA version: N910CXXU2COJ5 CSC version: N910COJV2COK1 SW version: N910CXXU1COJ5 Phone SN: RF8G11CHEEZ Android version: 5.1.1 (LMY47X) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos5433 HW Modem: DB7450R Security patch level: 2015-11-01 SIM 1 status: absent Codename: treltexx Performed by 2.6.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N910C Reset FRP/ Reactivation lock operation for SM-N910C will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-N910C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.6.5 Software version. already formated with keys,,,also unlock in find yphone samsung,,,but still samsung account enabled,,,i need disable samsung account |
03-01-2018, 08:26 | #4 (permalink) |
Freak Poster Join Date: Jun 2016 Location: Home Age: 27
Member: 2583091 Status: Offline Thanks Meter: 413 | Dude Octopus is only unlocking the FRP only But you can use package disabler pro for bypass with the current android version or downgrade to 4.4.4 and remove it fully(this one is risky). |
