04-24-2016, 16:14 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Into the Unknown
Member: 121461 Status: Offline Thanks Meter: 49 | NEED HELP with S5 G900H NOT Flashing i got the phone like this so i cant say how it got to that state. here is log, not until i unplug it the lines in red show. <ID:0/005> Added!! <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/005> Odin engine v(ID:3.1100).. <ID:0/005> File analysis.. <ID:0/005> SetupConnection.. <ID:0/005> Initialzation.. <ID:0/005> Set PIT file.. <ID:0/005> DO NOT TURN OFF TARGET!! <ID:0/005> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/005> Removed!! I tried writing flash file with Pit but same result PIT_G900HXXU1ANJ2_G900HJDI1ANJ2_JDI_Android_4.4.2. oct Any ideas are welcomed! |
04-24-2016, 23:10 | #3 (permalink) |
Member: 121461 Status: Offline Thanks Meter: 49 | i did post in samsung section. i also posted in octopus section because i tried your software to see if would work. so i am guessing that you will not be able to assist me with that problem. can you assist with this one then http://forum.gsmhosting.com/vbb/f684.../#post11776551 |
04-25-2016, 10:22 | #4 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Explain clear what have tryed of do with this Odin flash and why Flash PIT in STOCK FW? PIT in many Stock Fw is just inside to CSC, so you can corrupt original Partition flashing PIT with Stock fw. Try to flash other FW most recent and w/o PIT if Stock fw. In other Thread have done other Mistake, have Wiped EFS w/o need it, just "Reset Msl" and write Cert. (Read answer for other problem). FIRST OF TOUCH ALL BUTTON, ASK or use "HELP" Button in sw, forever this. | |
04-25-2016, 10:54 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please try to make Factory Reset and Wipe cache partition from Recovery Mode (if phone enters it), then try to reflash the phone with "G900HXXU1BOE2_G900HECO1BOE2_ECO_Android_5.0" firmware from the Support Area. Post here result and full Software log of "Write Firmware" operation. |
