04-14-2015, 15:32 | #1 (permalink) |
Insane Poster Join Date: Jul 2005 Location: Varna, Bulgaria Age: 51
Member: 161384 Status: Offline Sonork: 100.1657922 Thanks Meter: 3 | Needed firmware for Samsung E1230 The first time Octopus patched the FW and said "Wrong TAT connection" Now it is like this: Platform: Samsung Swift Selected model: GT-E1230 Selected port: COM5 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Reading flash memory parameters.. Setting baudrate.. Sending mainloader... Mainloader send successfully Searching patch area, please wait... Firmware already patched. Rebooting phone Connecting... Phone in TAT mode. Reading info, please wait... Wrong TAT connection. Read codes failed Please, provide Octopus type FW for this phone. Probably will need also the EEPROM. |
04-14-2015, 16:01 | #3 (permalink) |
Member: 161384 Status: Offline Sonork: 100.1657922 Thanks Meter: 3 | INFO : 14.4.2015 г/ 16:24:12 > Platform: Samsung Swift INFO : 14.4.2015 г/ 16:24:12 > Selected model: GT-E1230 INFO : 14.4.2015 г/ 16:24:12 > Selected port: COM5 INFO : 14.4.2015 г/ 16:24:12 > Baud rate: 115200 WARN : 14.4.2015 г/ 16:24:12 > Please, connect phone to UART cable, insert battery and press power button for 3 seconds. INFO : 14.4.2015 г/ 16:24:12 > Connecting... INFO : 14.4.2015 г/ 16:24:19 > Phone in TAT mode. INFO : 14.4.2015 г/ 16:24:19 > Reading info, please wait... INFO : 14.4.2015 г/ 16:24:31 > Phone IMEI A: 35873504764899 INFO : 14.4.2015 г/ 16:24:31 > Phone IMEI B: 35873504764899 INFO : 14.4.2015 г/ 16:24:31 > SW version: E1230BVKL INFO : 14.4.2015 г/ 16:24:31 > Phone SN : R21C81LWFV |
04-14-2015, 16:14 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to do the next: 1. Make Read codes again. 2. When Software will write on log "Firmware already patched", fast discinnect the cable from the phone, disconnect the battery, connect phone to UART cable again, insert the battery and press "Power" button for 3 seconds again. |
04-14-2015, 16:19 | #5 (permalink) |
Member: 161384 Status: Offline Sonork: 100.1657922 Thanks Meter: 3 | After following your advices: Platform: Samsung Swift Selected model: GT-E1230 Selected port: COM5 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Reading flash memory parameters.. Setting baudrate.. Sending mainloader... Mainloader send successfully Searching patch area, please wait... Firmware already patched. Rebooting phone Connecting... Phone in TAT mode. Reading info, please wait... Wrong TAT connection. Read codes failed |
04-14-2015, 16:24 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Repeat several times, You should put the phone into TAT mode manually, when Software will write on log "Firmware already patched". Also, try to use another cable. Last edited by Octopus box; 04-14-2015 at 16:37. |
04-14-2015, 16:51 | #7 (permalink) |
Member: 161384 Status: Offline Sonork: 100.1657922 Thanks Meter: 3 | No another cable. In the octopus box set there is just one E210 cable. Also I tried with Samsung E1120 and all operations are OK. Seems the cable is OK. Repeated the procedure several times, but no success. INFO : 14.4.2015 г/ 18:45:01 > Platform: Samsung Swift INFO : 14.4.2015 г/ 18:45:01 > Selected model: GT-E1120 INFO : 14.4.2015 г/ 18:45:01 > Selected port: COM5 INFO : 14.4.2015 г/ 18:45:01 > Baud rate: 115200 WARN : 14.4.2015 г/ 18:45:01 > Please, connect phone to UART cable, insert battery and press power button for 3 seconds. INFO : 14.4.2015 г/ 18:45:01 > Connecting... INFO : 14.4.2015 г/ 18:45:15 > Phone in TAT mode. INFO : 14.4.2015 г/ 18:45:15 > Reading info, please wait... INFO : 14.4.2015 г/ 18:45:29 > Phone IMEI A: 35805403915561 INFO : 14.4.2015 г/ 18:45:29 > SW version: E1120HAIB INFO : 14.4.2015 г/ 18:45:29 > Phone SN : RUTZ615796 INFO : 14.4.2015 г/ 18:45:37 > ----------------------------------------------------------------------------------- INFO : 14.4.2015 г/ 18:45:37 > Platform: Samsung Swift INFO : 14.4.2015 г/ 18:45:37 > Selected model: GT-E1120 INFO : 14.4.2015 г/ 18:45:37 > Selected port: COM5 INFO : 14.4.2015 г/ 18:45:37 > Baud rate: 115200 WARN : 14.4.2015 г/ 18:45:37 > Please, connect phone to UART cable, insert battery and press power button for 3 seconds. INFO : 14.4.2015 г/ 18:45:37 > Connecting... INFO : 14.4.2015 г/ 18:46:17 > Phone in TAT mode. INFO : 14.4.2015 г/ 18:46:17 > Reading info, please wait... INFO : 14.4.2015 г/ 18:46:29 > Phone IMEI A: 35805403915561 INFO : 14.4.2015 г/ 18:46:29 > SW version: E1120HAIB INFO : 14.4.2015 г/ 18:46:29 > Phone SN : RUTZ615796 INFO : 14.4.2015 г/ 18:47:20 > ----------------------------------------------------------------------------------- INFO : 14.4.2015 г/ 18:47:20 > Platform: Samsung Swift INFO : 14.4.2015 г/ 18:47:20 > Selected model: GT-E1230T INFO : 14.4.2015 г/ 18:47:20 > Selected port: COM5 INFO : 14.4.2015 г/ 18:47:20 > Baud rate: 115200 WARN : 14.4.2015 г/ 18:47:20 > Please, connect phone to UART cable, insert battery and press power button for 3 seconds. INFO : 14.4.2015 г/ 18:47:20 > Connecting... INFO : 14.4.2015 г/ 18:47:24 > Phone in TAT mode. INFO : 14.4.2015 г/ 18:47:24 > Reading info, please wait... ERROR : 14.4.2015 г/ 18:47:35 > Wrong TAT connection. INFO : 14.4.2015 г/ 18:47:51 > ----------------------------------------------------------------------------------- INFO : 14.4.2015 г/ 18:47:51 > Platform: Samsung Swift INFO : 14.4.2015 г/ 18:47:51 > Selected model: GT-E1230T INFO : 14.4.2015 г/ 18:47:51 > Selected port: COM5 INFO : 14.4.2015 г/ 18:47:51 > Baud rate: 115200 WARN : 14.4.2015 г/ 18:47:51 > Please, connect phone to UART cable, insert battery and press power button for 3 seconds. INFO : 14.4.2015 г/ 18:47:51 > Connecting... INFO : 14.4.2015 г/ 18:47:56 > Phone in TAT mode. INFO : 14.4.2015 г/ 18:47:56 > Reading info, please wait... ERROR : 14.4.2015 г/ 18:48:07 > Wrong TAT connection. |
04-15-2015, 09:28 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Why You have seleted GT-E1120, GT-E1230T? When You make Unlock or Read codes as another model, this can damage your device! We will try to find firmware for GT-E1230 and, if we find, we will upload it into the Support Area. |
04-15-2015, 11:31 | #10 (permalink) |
Member: 161384 Status: Offline Sonork: 100.1657922 Thanks Meter: 3 | This was a trial with working Sams E1120 just to check the cable. It was not E1230. When I try E1120 I select E1120, when I plug E1230 I select E1230. |
04-15-2015, 11:40 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have uploaded new firmwares for GT-E1230 into the Support Area. Try to reflash the phone and then repeat "Read Codes" operation. |
06-01-2015, 17:37 | #12 (permalink) |
No Life Poster Join Date: Feb 2007 Location: india Age: 47
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | @octopus team can you tall me witch file can i flash with E1230 phone OR witch file is full firmware? i don't see in support area |
07-07-2015, 07:38 | #14 (permalink) |
Freak Poster Join Date: Aug 2012 Location: philippines
Member: 1798750 Status: Offline Sonork: ..::chubbgsm::.. Thanks Meter: 58 | i try to flash the 3 file in support Welcome to Octoplus/Octopus Box Samsung software version 1.9.9 Selected firmware file: E1230XXKHB_E1230OXAKI1.oct ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-E1230 Selected port: COM8 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Reading flash memory parameters.. Setting baudrate.. Sending mainloader... Mainloader send successfully Writing firmware... Writing CLA section... Writing Firmware Failed ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-E1230 Selected port: COM8 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Connecting... Connecting canceled. ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-E1230 Selected port: COM8 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Reading flash memory parameters.. Setting baudrate.. Sending mainloader... Mainloader send successfully Writing firmware... Writing CLA section... Writing Firmware Failed Selected firmware file: E1230XXKHB_E1230OXBKH1.oct ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-E1230 Selected port: COM8 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Reading flash memory parameters.. Setting baudrate.. Sending mainloader... Mainloader send successfully Writing firmware... Writing CLA section... Writing Firmware Failed Selected firmware file: E1230XXKHB_E1230OXCLA1.oct ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-E1230 Selected port: COM8 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Reading flash memory parameters.. Setting baudrate.. Sending mainloader... Mainloader send successfully Writing firmware... Writing CLA section... Writing Firmware Failed the phone now dead.. |
07-07-2015, 08:17 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | What was the problem with the phone before You tried to reflash it? Please fully charge phone's battery, then try to reflash the phone again. If problem will remain - upload *.log and *.logx of "Write Firmware" operation files from "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder and post here download link. We will check where can be the problem. |
