12-16-2014, 13:49 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try write QCN file, which we have sent You in PM and check network. |
12-17-2014, 08:50 | #3 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | same problem ----------------------------------------------------------------------------------- To connect SM-G7102 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G7102 Reading info... Mode: Normal Firmware compiled date: Aug 06 2014 Firmware compiled time: 02:00:00 Firmware released date: Aug 26 2014 Firmware released time: 20:49:46 SW Version: M8626A-AAAANAZM-1.0.4067 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes |
12-17-2014, 09:05 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Do exactly the next: 1. Make Factory data reset and wipe cache partition. 2. Write the special formware "SM-G7102_for_Unlock_and_Repair_IMEI_4.4.2.oct" from the Support Area. 3. Write service's IMEI A and B. 4. Make Rapair NVM. 5. Write this QCN: https://drive.google.com/open?id=0Bw...bzg&authuser=0. 6. Re-start the phone, insert SIM card, wait 3-5 minutes and try to find and select network manually. 7. Write here the result. Also, look here: http://forum.gsmhosting.com/vbb/f684...olved-1878057/, http://forum.gsmhosting.com/vbb/f684...olved-1878213/, http://forum.gsmhosting.com/vbb/f684.../#post10673317. |
12-17-2014, 10:00 | #5 (permalink) |
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | 1000 thanx problem solved Welcome to Octoplus/Octopus Box Samsung software version 1.7.8 ----------------------------------------------------------------------------------- To connect SM-G7102 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: SM-G7102_for_Unlock_and_Repair_IMEI_ 4.4.2.oct Please put the phone into Download Mode and connect USB cable. To put SM-G7102 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Platform: Samsung Android Selected port: COM20 Selected model: SM-G7102 Mode: Normal Phone model: SM-G7102 Firmware compiled date: Sep 03 2014 Firmware compiled time: 06:00:00 Firmware released date: Sep 19 2014 Firmware released time: 18:10:33 Phone IMEI: 352310-06-126671-1 SW version: M8626A-AAAANAZM-1.0.4072 Creating NVM backup Reading NVM done! Repairing NVM for SM-G7102 phone... NVM repair completed successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Platform: Samsung Android Selected port: COM20 Selected model: SM-G7102 Reading info... Mode: Normal Firmware compiled date: Sep 03 2014 Firmware compiled time: 06:00:00 Firmware released date: Sep 19 2014 Firmware released time: 18:10:33 SW Version: M8626A-AAAANAZM-1.0.4072 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes |
