03-28-2015, 20:01 | #16 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | You should root the phone to read out backups of Security and EFS, and also to make Wipe Security via ABD. You can make Wipe Security/EFS via phone's menu. But, if You will not have backups of Security and EFS, You will no able to return the phone into the initial state, if something will go wrong. If You want to risk, do the next: 1. Install the latest Software version (Software). 2. Fully charge phone's battery. 3. Make Wipe Security/EFS via phone's menu: 3.1. Write any firmware (don't root the phone after, this is important!). 3.2. Type *#9090#. 3.3. Type at rigth corner MENU + select "Back". 3.4. Typy at rigth corner MENU + input Q. 3.5. Type at rigth croner MENU + input 0000. Look this video manual: https://www.youtube.com/watch?v=1DtPT2MmNhg. 4. Block battery's proper contact by using a tape, connect the phone to Box via Samsung Micro UART C3300k/C3303k cable and write the IMEI Certificate ("Write Cert" button in the Software). Note, after writing IMEI Certificate, phone's IMEI will be changed to the IMEI from the IMEI Certificate file. BR allumts |
03-28-2015, 20:32 | #17 (permalink) |
Crazy Poster Join Date: Jan 2009 Location: nigeria
Member: 947508 Status: Offline Thanks Meter: 2 | @allumts, thank you for the swift response i really appreciate your help have done virtually all you have explained to me but still have not been able to do a successful wipe of the phone i just did a wipe of the phone with the latest setup of octopus box but still the efs has not been wiped what i see when i read the info is still the original imei of the phone it says successfully wiped but it wasn't successful let me copy the log page for your confirmation. |
03-28-2015, 20:52 | #20 (permalink) |
Member: 947508 Status: Offline Thanks Meter: 2 | Welcome to Octoplus/Octopus Box Samsung software version 1.9.0 ----------------------------------------------------------------------------------- To connect GT-B5512 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N910F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM140 Selected model: SM-N910F Selected file: C:\Users\OLAYINKA\Desktop\oct files\cert files oct\oct sm n910c&f\Cert-SM-N910F_355324060515397.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-N910F Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM58 Mode: Normal Phone model: SM-N910F Firmware compiled date: Oct 15 2014 Firmware compiled time: 16:00:00 Firmware released date: Nov 20 2014 Firmware released time: 15:29:34 Phone IMEI: 354201-06-737559-8 SW version: MPSS.BO.1.0.r10-00108-M9635TAARANAZM-1.7127.4 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM58 Selected model: SM-N910F Detected phone model: SM-N910F Firmware compiled date: Thu Nov 20 17:13:13 KST 2014 PDA version: N910FXXU1ANK5 CSC version: N910FITV1ANK1 SW version: N910FXXU1ANK5 Phone IMEI: 354201067375598 Android version: 4.4.4 (KTU84P) Reading info... Mode: Normal Firmware compiled date: Oct 15 2014 Firmware compiled time: 16:00:00 Firmware released date: Nov 20 2014 Firmware released time: 15:29:34 SW Version: MPSS.BO.1.0.r10-00108-M9635TAARANAZM-1.7127.4 Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-N910F-354201067375598-28-03-2015_20-41- 14-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N910F-354201067375598-28-03-2015_20-41- 15-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Oct 15 2014 Firmware compiled time: 16:00:00 Firmware released date: Nov 20 2014 Firmware released time: 15:29:34 SW Version: MPSS.BO.1.0.r10-00108-M9635TAARANAZM-1.7127.4 Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! |
03-28-2015, 20:55 | #21 (permalink) |
Member: 947508 Status: Offline Thanks Meter: 2 | with this i expect the imei of the phone to have changed to null but after checking the info after the imei still remains unchanged. Platform: Samsung Android Selected port: COM58 Selected model: SM-N910F Reading info, please wait... Detected phone model: SM-N910F Firmware compiled date: Thu Nov 20 17:13:13 KST 2014 PDA version: N910FXXU1ANK5 CSC version: N910FITV1ANK1 SW version: N910FXXU1ANK5 Phone IMEI: 354201067375598 Android version: 4.4.4 (KTU84P) what else can i do |
03-28-2015, 21:07 | #22 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | But you have loocked good the VIDEO above?....this phone is Rotted...if want to try with Wipe procedure of Video you phone must need of NOT to be rotted...read good all steps above then apply procedure and post result...you first of write Cert must need Wiped this Security/Efs..and w/o root... Read good and loock carefully the Video: 1. Install the latest Software version (Software). 2. Fully charge phone's battery. 3. Make Wipe Security/EFS via phone's menu: 3.1. Write any firmware (don't root the phone after, this is important!). 3.2. Type *#9090#. 3.3. Type at rigth corner MENU + select "Back". 3.4. Typy at rigth corner MENU + input Q. 3.5. Type at rigth croner MENU + input 0000. Look this video manual: https://www.youtube.com/watch?v=1DtPT2MmNhg. 4. Block battery's proper contact by using a tape, connect the phone to Box via Samsung Micro UART C3300k/C3303k cable and write the IMEI Certificate ("Write Cert" button in the Software). Note, after writing IMEI Certificate, phone's IMEI will be changed to the IMEI from the IMEI Certificate file. I not understand Why you cannot open new thread?, you have more of 20 post...you can!!! BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
03-28-2015, 21:23 | #23 (permalink) |
Member: 947508 Status: Offline Thanks Meter: 2 | @allumts, Thank you for your time have been able to wipe the phone efs with the video guide you presented to me and have written a new imei to the phone.Thank you and *** bless |
03-29-2015, 15:07 | #25 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,419 | Quote:
03-30-2015, 08:03 | #27 (permalink) | |
03-30-2015, 13:22 | #28 (permalink) |
Freak Poster Join Date: Feb 2015 Location: UK Age: 41
Member: 2353386 Status: Offline Sonork: 100.1644731 Thanks Meter: 10 | SC-03E imei Repaire done but not change Welcome to Octoplus/Octopus Box Samsung software version 1.8.8 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM98 Selected model: SC-03E Mode: Normal Phone model: SC-03E Firmware compiled date: Dec 19 2013 Firmware compiled time: 00:00:00 Firmware released date: Aug 18 2014 Firmware released time: 20:49:20 SW version: M9615A-CEFWMAZM-2.0.146016 Old IMEI: 353986-05-314293-4 New IMEI: 353986-30-439241-1 IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- |
03-30-2015, 13:24 | #29 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,419 | Install the latest Software version (http://octoplusbox.com/en/download/software/), take out SIM card from the phone and make Repair IMEI again. To finish the "Repair IMEI" operation, restart the phone via phone's menu (via "Power ON" button, don't disconnect the battery, this is important). |
03-30-2015, 13:32 | #30 (permalink) |
Member: 2353386 Status: Offline Sonork: 100.1644731 Thanks Meter: 10 | Welcome to Octoplus/Octopus Box Samsung software version 1.9.0 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM98 Selected model: SC-03E Mode: Normal Phone model: SC-03E Firmware compiled date: Dec 19 2013 Firmware compiled time: 00:00:00 Firmware released date: Aug 18 2014 Firmware released time: 20:49:20 SW version: M9615A-CEFWMAZM-2.0.146016 Old IMEI: 353986-05-314293-4 New IMEI: 353986-30-439241-1 IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) same not changed |
