05-02-2015, 20:22 | #32 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2138605 Status: Offline Thanks Meter: 0 | I tested SM-G925T (tmobile s6 edge) this is what i find out: - read Security works well - read efs works well -read info sometimes get error but to fix just unplug and plug back in I dont have a cert to test and write so i need one. The problem with device is cant be unlocked or repaired at the moment. This is due to the tmobile unlock app that comes equiped with phone. (And probably alot more then i understand) Here is what i tried to do and where i am at. Hopefully this helps others make progress on device: - rooted succesfully and installed custom recovery - was able to uninstall device unlock app w root but it still prompts to use the app when it restarts - installed international rom (get stactic wifi so dont do unless you can fix) and it prompts for code, but when i insert correct code it says unsuccesful - tried to write international firmware but it fails. This idea worked on other galaxy by enabling to input code when prompted - tried service codes *#0011# and *#197328650# for work around but older tricks dont work or not available - qpst is not reading the phone Two questions Is their a apk that can be removed aside from device unlock apk that disables it completely as removing device unlock apk doesnt work? Maybe we can adb push an older s5 unlock apk to this device. Is possible to write .oct file from international version with tmobile kernal and modem? Maybe this will prompt for code I have a few of these device to test. But im not rich so no bad ideas lol. |
05-04-2015, 01:54 | #36 (permalink) | |
No Life Poster Join Date: Apr 2012 Location: Black Market Age: 39
Member: 1744748 Status: Offline Thanks Meter: 752 | Quote:
It can be done.. has been done...(g920W , G925W models) and works flawlessly... you need the right tools, files, people and cert... Please octopus help the community.... For T-Mobile (again I haven't done it - Theory only) - Flash the metropcs ROM and try... or buy the unlock code from T-Mobile.. once unlocked you can write the cert... Problem solved.... (imei repair done).... | |
05-05-2015, 10:54 | #40 (permalink) |
No Life Poster Join Date: May 2006 Location: I Love Walking In The Rain Bec
Member: 276151 Status: Offline Sonork: 100.1577032 Thanks Meter: 234 | ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: SM-G900A Reading info, please wait... ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900A Firmware compiled date: Fri Mar 14 13:15:55 KST 2014 PDA version: G900AUCU1ANCE CSC version: G900AATT1ANCE SW version: G900AUCU1ANCE Phone IMEI: 353502060849088 Phone SN: R38F313L2RM Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: SM-G900A Detected phone model: SM-G900A Firmware compiled date: Fri Mar 14 13:15:55 KST 2014 PDA version: G900AUCU1ANCE CSC version: G900AATT1ANCE SW version: G900AUCU1ANCE Phone IMEI: 353502060849088 Phone SN: R38F313L2RM Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Updating languages.. Phone will restart now. Please don't disconnect cable! All hidden languages was succesfully enabled. but languages is not there All hidden how to fix that ? |
