11-27-2017, 11:02 | #93 (permalink) |
Freak Poster Join Date: Oct 2015 Location: bogra
Member: 2468982 Status: Offline Sonork: Koler.gaan Thanks Meter: 72 | Platform: Samsung Android Selected port: COM15 Selected model: SM-G570Y Searching for UART interface.. COM15 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation...OK Searching for UART interface.. COM15 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock (1/4 attempt)..unsuccessful Searching for UART interface.. COM15 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock (2/4 attempt)..success FRP / Reactivation lock is successfully reseted! Performed by 2.6.2 Software version. NTCB :- IF After FRP Reset Phone Have No response Please Connect Charger And Press Voll Down Bottom + Power Bottom (2 Min) Your Phone Screen Show Charging . Enjoy |
The Following User Says Thank You to Koler Gaan For This Useful Post: |
11-27-2017, 19:01 | #96 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Is it permanent unlock ? IS it will be relock after update to new version ? Edit Got answer from here http://forum.gsmhosting.com/vbb/12799449-post49.html |
11-27-2017, 20:46 | #97 (permalink) |
Freak Poster Join Date: Sep 2011 Location: Lebanon
Member: 1657517 Status: Offline Thanks Meter: 74 | 🐙 Octoplus / Octopus Box Samsung v.2.6.2 - G930/935T direct unlock and more! 🐙 Samsung A310F 7.0 Nougat Frp reset done My phone A310f 7.0 mid Iraq sboot failed, then I flash other firmware same CSC,but same problem Frp failed sboot Help me Sent from my iPhone using Tapatalk[/QUOTE] Samsung A310F 7.0 Nougat Frp reset done My phone on 7.0 1st write low ver 6.0.1 (sboot) firmware file Octoplus suport site When write lower version google play store not suport or some problem you face but this no problem 2nd step finish do 3rd step done 2nd click Reset FRP/Reactivation lock “Via UART (eMMC memory chip)” Frp Reset success. 3rd write your correct official firmware file 7.0 Nougat Success all. Thanks Octoplus teams Last edited by Dulaljan; 12-03-2017 at 22:48. Reason: Samsung A310F 7.0 Nougat Frp reset done |
The Following User Says Thank You to Dulaljan For This Useful Post: |
11-27-2017, 22:31 | #98 (permalink) | |
Freak Poster Join Date: Jan 2015 Location: La Habana, Cuba
Member: 2324261 Status: Offline Thanks Meter: 117 | Quote:
Cuajajaja... Where are you from dude? In Cuba the Internet Speed is 2mbps ... and thanks to good, because 2 years ago 56 kbps .. Now... with 2 mbps all process can be done.. remote unlocks also... not necessary superssss speedssss | |
11-28-2017, 00:21 | #99 (permalink) | |
Junior Member Join Date: Apr 2017
Member: 2711105 Status: Offline Thanks Meter: 4 | G935T Samsung 2.6.2 Unlocked Success. I will reply to my before post: I tried one more time with Octoplus Samsung 2.6.2. And G935T was Unlocked Successfully in 15 minutes. Congratulations Octoplus Box Team great Job. This is my Log. Quote:
The Following User Says Thank You to wariomvc For This Useful Post: |
11-28-2017, 11:51 | #100 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Ho Chi Minh Age: 43
Member: 129163 Status: Offline Thanks Meter: 67 | SM-G930T Unlock OK Sending device information...OK Rebooting phone in Download Mode... Searching for a phone. Please wait... Phone found. Firmware write started. Writing Data section... Data section has been written successfully. Searching for a phone. Please wait...OK Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G930T-R28HA3RDKLB-28-11-2017_17-37-00-.asec file Rebooting phone in Download Mode... Searching for a phone. Please wait... Phone found. Firmware write started. Writing Data section... Data section has been written successfully. Searching for a phone. Please wait...OK Initializing..OK Unlocking phone...OK Phone is successfully unlocked |
The Following User Says Thank You to Doantri For This Useful Post: |
11-28-2017, 12:31 | #101 (permalink) | ||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
You do it also?: Quote:
11-29-2017, 13:04 | #104 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Most likely, "Unlock" operation was not performed correctly/completely. Please do the following: 1. Fully charge phone's battery. 2. Install test Software version v.2.6.2.1 from the Support Area. 3. Write first security backup back into the phone to back phone to it's initial state (backup was created automatically during of Unlock process). 4. Repeat the "Unlock" operation again. 5. Post here the result. Connect the phone directly to PC motherboard USB port, don’t use USB hubs, this is important. The unlocking process takes about 10 minutes, please do not disconnect the cable and do not confirm / do not press / reboot any messages that appear on the screen of the phone during the unlocking process. |
11-29-2017, 15:24 | #105 (permalink) |
Freak Poster Join Date: Apr 2017 Location: Ashuganj
Member: 2707726 Status: Offline Sonork: 100.1675740 Thanks Meter: 132 | Samsung GT-I9500 Network Repair Done 1000%. Samsung GT-I9500 Network Repair Done log: Last edited by Octopus box; 11-29-2017 at 15:38. |
The Following User Says Thank You to gsmali40 For This Useful Post: |
