03-23-2018, 17:26 | #76 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1081728 Status: Offline Thanks Meter: 7 | unlock j327t1 unsuccesfully ----------------------------------------------------------------------------------- To connect SM-G900H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Connecting to server.. Username: lps9vkd Authorization.. Checking smart card... Smart card successfully checked. Checking balance.. Your balance: 300 credits. Requesting history.. History not found! Requesting service status.. Service status successfully obtained! Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM3 Modelo seleccionado: SM-J327T1 Operation: Unlock Please, press "OK" button on the phone to allow USB debugging. Proper android device not found. Make shure that "USB debug" option on the device is turned on. La liberación del teléfono ha sido fallada Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM3 Modelo seleccionado: SM-J327T1 Operation: Unlock Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging. Modelo del teléfono detectado: SM-J327T1 Fecha de creación del firmware: Fri Mar 24 13:04:44 KST 2017 PDA version: J327T1UVU1AQCB CSC version: J327T1TMK1AQCB Versión del SW: J327T1UVU1AQCB Phone SN: R28J432NJPL Android version: 7.0 (NRD90M) Sales code: TMK Country: USA HW platform: exynos5 HW Chip: exynos7570 HW Modem: SHANNON305 Security patch level: 2017-03-01 SIM 1 status: absent Codename: j3popeltemtr Connecting to modem port... Found phone on COM376 Leyendo IMEI...OK Intentando a buscar el puerto USB diagnóstico...failed ¡Puertos diagnósticos no encontrados! Type *#0808# and select "DM+ACM+ADB"! La liberación del teléfono ha sido fallada Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM376 Modelo seleccionado: SM-J327T1 Operation: Unlock Can't kill external ADB references. Please, close all programs that use ADB server. Modelo del teléfono detectado: SM-J327T1 Fecha de creación del firmware: Fri Mar 24 13:04:44 KST 2017 PDA version: J327T1UVU1AQCB CSC version: J327T1TMK1AQCB Versión del SW: J327T1UVU1AQCB Phone SN: R28J432NJPL Android version: 7.0 (NRD90M) Sales code: TMK Country: USA HW platform: exynos5 HW Chip: exynos7570 HW Modem: SHANNON305 Security patch level: 2017-03-01 SIM 1 status: absent Codename: j3popeltemtr Connecting to modem port... Found phone on COM390 Leyendo IMEI...OK Intentando a buscar el puerto USB diagnóstico...OK ConectandoOK Leyendo HWID...OK ----------------------------------------------------------------------------------- Connecting to server...OK Checking smart card...OK Username: lps9vkd Authorizing...OK Checking balance...OK Checking operation...OK Your balance: 300 credits. ----------------------------------------------------------------------------------- Sending device information...OK Initializing exploit...OK Liberando el teléfono...OK El teléfono ha sido liberado con éxito To finish the operation, please restart the phone via phone's menu. Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Connecting to server... Username: lps9vkd Authorizing... Checking balance... Your balance: 200 credits. Performed by 2.6.6 Software version. unlock ok by software but invalid sim in my screen. Someone can helpme? |
03-23-2018, 18:29 | #77 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Re-flash the phone and then repeat the operation again. No need credits to repeat the operation with the same device. Post here the result. |
03-23-2018, 23:11 | #78 (permalink) |
Insane Poster Join Date: May 2008
Member: 778123 Status: Offline Thanks Meter: 6 | j327t unlocked I was having trouble unlocking a j327t. I installed a new firmware (j327TTMB1AQF7). performed the unlock again then it worked. it accepted the sim card. You may need to perform the unlock a few times. It happened for me. |
The Following User Says Thank You to leronew For This Useful Post: |
03-24-2018, 05:23 | #79 (permalink) | |
Junior Member Join Date: Mar 2018
Member: 2821762 Status: Offline Thanks Meter: 0 | Quote:
what means re-flash?? so same device we can repeat several time, no credit charge? | |
03-24-2018, 09:37 | #80 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Re-flash, means write another firmware. Yes, can repeat 3 times for the same device and credits will not discharged. |
03-24-2018, 13:34 | #81 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2110371 Status: Offline Thanks Meter: 20 | SM-G950U successfully unlocked unlock without stress many regards to the developers Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\24-03-2018_12-17-43.log" created (3/24/2018 12:17:51 PM). INFO : 3/24/2018 12:18:46 PM > Set up system language English (file: English.ini) INFO : 3/24/2018 12:18:46 PM > Welcome to Octoplus Box Samsung software version 2.6.6 INFO : 3/24/2018 12:20:09 PM > ----------------------------------------------------------------------------------- IINFO : 3/24/2018 12:20:42 PM > Connecting to server... INFO : 3/24/2018 12:20:43 PM > Username: billycomm INFO : 3/24/2018 12:20:44 PM > Authorizing... INFO : 3/24/2018 12:20:44 PM > Checking balance... WARN : 3/24/2018 12:20:44 PM > Your balance: 134 credits. INFO : 3/24/2018 12:20:45 PM > Performed by 2.6.6 Software version. INFO : 3/24/2018 12:20:57 PM > ----------------------------------------------------------------------------------- INFO : 3/24/2018 12:20:59 PM > Platform: Samsung Android INFO : 3/24/2018 12:20:59 PM > Selected port: COM594 INFO : 3/24/2018 12:20:59 PM > Selected model: SM-G950U INFO : 3/24/2018 12:20:59 PM > Operation: Unlock INFO : 3/24/2018 12:21:05 PM > Detected phone model: SM-G950U INFO : 3/24/2018 12:21:06 PM > Firmware compiled date: Wed Oct 18 14:20:44 KST 2017 INFO : 3/24/2018 12:21:06 PM > PDA version: G950USQU1AQJ8 INFO : 3/24/2018 12:21:07 PM > CSC version: G950UOYN1AQJ8 INFO : 3/24/2018 12:21:07 PM > SW version: G950USQU1AQJ8 INFO : 3/24/2018 12:21:08 PM > Phone SN: R28J33FNHQM INFO : 3/24/2018 12:21:08 PM > Android version: 7.0 (NRD90M) INFO : 3/24/2018 12:21:09 PM > Sales code: TMB INFO : 3/24/2018 12:21:09 PM > Country: USA INFO : 3/24/2018 12:21:09 PM > HW platform: msm8998 INFO : 3/24/2018 12:21:09 PM > HW Chip: MSM8998 INFO : 3/24/2018 12:21:10 PM > HW Modem: MSM8998 INFO : 3/24/2018 12:21:10 PM > Security patch level: 2017-10-01 INFO : 3/24/2018 12:21:10 PM > SIM 1 status: absent INFO : 3/24/2018 12:21:10 PM > Codename: dreamqltesq INFO : 3/24/2018 12:21:10 PM > Connecting to modem port... INFO : 3/24/2018 12:21:12 PM > Found phone on COM594 INFO : 3/24/2018 12:21:12 PM > Reading IMEI... INFO : 3/24/2018 12:21:18 PM > OK INFO : 3/24/2018 12:21:18 PM > Searching for USB diagnostic port... INFO : 3/24/2018 12:21:19 PM > Reading info... INFO : 3/24/2018 12:21:19 PM > Mode: Normal INFO : 3/24/2018 12:21:19 PM > Firmware compiled date: Aug 22 2017 INFO : 3/24/2018 12:21:19 PM > Firmware compiled time: 07:00:00 INFO : 3/24/2018 12:21:19 PM > Firmware released date: Oct 18 2017 INFO : 3/24/2018 12:21:19 PM > Firmware released time: 11:14:15 INFO : 3/24/2018 12:21:19 PM > SW Version: MPSS.AT.2.0.c2.2-00178-8998_GEN_PACK-1.109403.8 INFO : 3/24/2018 12:21:19 PM > Initializing exploit... INFO : 3/24/2018 12:21:30 PM > OK INFO : 3/24/2018 12:21:30 PM > Reading data... INFO : 3/24/2018 12:22:25 PM > OK INFO : 3/24/2018 12:22:25 PM > ----------------------------------------------------------------------------------- WARN : 3/24/2018 12:22:25 PM > Connecting to server... WARN : 3/24/2018 12:22:26 PM > OK INFO : 3/24/2018 12:22:26 PM > Checking smart card... INFO : 3/24/2018 12:22:31 PM > OK INFO : 3/24/2018 12:22:31 PM > Username: billycomm INFO : 3/24/2018 12:22:32 PM > Authorizing... INFO : 3/24/2018 12:22:32 PM > OK INFO : 3/24/2018 12:22:32 PM > Checking balance... INFO : 3/24/2018 12:22:32 PM > OK INFO : 3/24/2018 12:22:32 PM > Checking operation... INFO : 3/24/2018 12:22:32 PM > OK INFO : 3/24/2018 12:22:32 PM > Your balance: 134 credits. INFO : 3/24/2018 12:22:32 PM > ----------------------------------------------------------------------------------- INFO : 3/24/2018 12:22:33 PM > Sending device information... INFO : 3/24/2018 12:22:33 PM > OK INFO : 3/24/2018 12:22:40 PM > Initializing exploit... INFO : 3/24/2018 12:22:50 PM > Unlocking phone... INFO : 3/24/2018 12:22:52 PM > Phone is successfully unlocked WARN : 3/24/2018 12:22:52 PM > To finish the operation, please restart the phone via phone's menu. INFO : 3/24/2018 12:23:13 PM > Performed by 2.6.6 Software version. INFO : 3/24/2018 12:23:19 PM > ----------------------------------------------------------------------------------- INFO : 3/24/2018 12:23:19 PM > Connecting to server... INFO : 3/24/2018 12:23:20 PM > Username: billycomm INFO : 3/24/2018 12:23:22 PM > Authorizing... INFO : 3/24/2018 12:23:22 PM > Checking balance... WARN : 3/24/2018 12:23:22 PM > Your balance: 34 credits. INFO : 3/24/2018 12:23:23 PM > Performed by 2.6.6 Software version. Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\24-03-2018_12-17-43.log" closed (3/24/2018 12:24:22 PM). Last edited by Octopus box; 03-24-2018 at 15:35. |
The Following 2 Users Say Thank You to billycomm6 For This Useful Post: |
03-27-2018, 05:57 | #82 (permalink) |
Junior Member Join Date: Mar 2015 Location: Cuba
Member: 2356373 Status: Offline Thanks Meter: 2 | Effectively as the support says write another firmware version in this case use J727T1UVU1AQD7 and go back to the unlock procedure and it is unlocked and you do not charge credits. Bienvenido en Octoplus Box Samsung software versión 2.6.6 ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: SM-J727T1 Operation: Read info Reading info, please wait... Modelo del teléfono detectado: SM-J727T1 Fecha de creación del firmware: Tue Apr 18 22:11:39 KST 2017 PDA version: J727T1UVU1AQD7 CSC version: J727T1TMK1AQD7 Versión del SW: J727T1UVU1AQD7 Phone SN: R28K13H3QYX Android version: 7.0 (NRD90M) Sales code: TMK Country: USA HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2017-04-01 SIM 1 status: absent Codename: j7popeltemtr Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: SM-J727T1 Operation: Unlock Modelo del teléfono detectado: SM-J727T1 Fecha de creación del firmware: Tue Apr 18 22:11:39 KST 2017 PDA version: J727T1UVU1AQD7 CSC version: J727T1TMK1AQD7 Versión del SW: J727T1UVU1AQD7 Phone SN: R28K13H3QYX Android version: 7.0 (NRD90M) Sales code: TMK Country: USA HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2017-04-01 SIM 1 status: absent Codename: j7popeltemtr Connecting to modem port... Found phone on COM90 Leyendo IMEI...OK Intentando a buscar el puerto USB diagnóstico...OK ConectandoOK Leyendo HWID...OK ----------------------------------------------------------------------------------- Connecting to server...OK Checking smart card...OK Username: rojasphone Authorizing...OK Checking balance...OK Checking operation...OK Your balance: 568 credits. ----------------------------------------------------------------------------------- Sending device information...OK Initializing exploit...OK Liberando el teléfono...OK El teléfono ha sido liberado con éxito To finish the operation, please restart the phone via phone's menu. Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Connecting to server... Username: rojasphone Authorizing... Checking balance... Your balance: 568 credits. Performed by 2.6.6 Software version. |
The Following 2 Users Say Thank You to yosbanis For This Useful Post: |
04-04-2018, 09:21 | #88 (permalink) |
Freak Poster Join Date: May 2007 Location: cebu city philippines
Member: 505947 Status: Offline Sonork: 100.1658758 Thanks Meter: 8 | Sending device information..OK Checking operation...OK Checking data..OK Reading FRP/Reactivation lock data.. Service is busy! Please try again later! |
04-04-2018, 09:26 | #89 (permalink) |
Freak Poster Join Date: Oct 2015 Location: bogra
Member: 2468982 Status: Offline Sonork: Koler.gaan Thanks Meter: 72 | Samsung S7 Egde Frp Lock reset Via Ocoplus Box V.2.6.6 Platform: Samsung Android Selected port: COM3 Selected model: SM-G935V Operation: Reset FRP - ADB Searching for a phone (waiting for ADB device)... Reading info... Detected phone model: SM-G935F Firmware compiled date: Thu Oct 13 11:53:59 KST 2016 PDA version: G935FXXU1BPIA CSC version: G935FXXU1BPIA SW version: G935VVRU4API3 Phone SN: R38H80EWMEA Android version: 6.0.1 (MMB29M) Sales code: VZW Country: USA HW platform: msm8996 HW Chip: MSM8996 HW Modem: MSM8996 Security patch level: 2016-10-01 SIM 1 status: absent Codename: hero2qltevzw Resetting FRP lock.. FRP lock is successfully reseted! Go to "Menu->Settings->Backup and reset" and make "Factory data reset" Performed by 2.6.6 Software version. No Need ADB Enable Combination File . Just Goo Download Mode And Press Vol Down And Power Then See 4 option . And Then Select Number 4 Option : power On With ADB From Developer Mode . Wow Your Job Is Done !! Enjoy Don't Forget Say Thanks To Koler Gaan |
The Following User Says Thank You to Koler Gaan For This Useful Post: |
