Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 10-24-2014, 21:25   #31 (permalink)
Member: 2279699
Thanks Meter: 41
wait for a few minutes and the phone will work test the cert *#0011# with a sim card on it the problem with is the phone dont have internet but im trigyng to configure know .......
sorry for my bad english
Old 10-24-2014, 22:33   #32 (permalink)
Member: 307625
Thanks Meter: 25
Platform: Samsung Android
Selected port: COM94
Selected model: SM-G900T
Selected file: C:\Users\User\Desktop\CERT\Cert-SM-G900F_
XXXXXX067456427_00000000000.cert
Detected phone model: SM-G900T
Firmware compiled date: Wed Mar 26 13:28:24 KST 2014
PDA version: G900TUVU1ANCH
CSC version: G900TTMB1ANCH
SW version: G900TUVU1ANCH
Phone IMEI: Unknown
Phone SN: RV8F41KPT7K
Android version: 4.4.2 (KOT49H)
Checking Root:
Phone is Rooted.
Checking Certificate file...
Certificate file successfully checked
Writing Certificate...
Phone connected successfully
Writing new phone IMEI...
Checking certificate compatibility...
Certificate is compatible
Phone will restart now
Certificate has been written successfully
Please, restart the phone to apply changes
Old 10-24-2014, 22:40   #33 (permalink)
Member: 2156601
Thanks Meter: 3
my g900t pauses on checking for root. Did yours go through immediately? Because its stuck on checking for root. I already rooted it of course.
Old 10-24-2014, 23:30   #34 (permalink)
topline's Avatar
Member: 85139
Thanks Meter: 68
Detected phone model: SM-G900F
Firmware compiled date: Thu Jul 3 14:08:46 KST 2014
PDA version: G900FXXU1ANG2
CSC version: G900FHUI1ANG3
SW version: G900FXXU1ANG2
Phone IMEI: 354886061759217
Phone SN: R58F70CCKDJ
Checking Root:
Phone is not Rooted.
Writing Certificate failed
g900f help
The Following User Says Thank You to topline For This Useful Post:
Old 10-25-2014, 00:07   #35 (permalink)
Member: 1527885
Plataforma: Samsung Android
Puerto seleccionado: COM19
Modelo seleccionado: SM-G900P
Modelo del teléfono detectado: SM-G900P
Fecha de creación del firmware: Sat Apr 5 20:26:10 KST 2014
PDA version: G900PVPU1AND2
CSC version: G900PSPT1AND2
Versión del SW: G900PVPU1AND2
IMEI del teléfono: 990004476256973
Phone SN: 00000000000
Reading info...
Mode: Normal
Firmware compiled date: Feb 26 2014
Firmware compiled time: G900P.04
Firmware released date: Apr 5 2014
Firmware released time: 12:17:10
SW Version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1
Reading QCN...
Send SPC...
Failed!
Old 10-25-2014, 01:05   #36 (permalink)
mrdnice88347's Avatar
Member: 2157134
Thanks Meter: 8
No way.. A unlock and repair imei.. nice..
Old 10-25-2014, 01:19   #37 (permalink)
Member: 2280259
3 QUESTIONS.
What will happen when 100 phones use the same IMEI, can you reverse back to your original IMEI if u cant read ur own CERT file?
Is this even free or do you need the octupus hardware box with this? Thanks in advance
Old 10-25-2014, 01:22   #38 (permalink)
Member: 2157134
Thanks Meter: 8
Is it selected imei or can I add my own imei..
Old 10-25-2014, 01:42   #39 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 338
Originally Posted by Octopus box View Post
Unlocking via Write Cert will not affect 3G/4G. If 3G/4G was working before Unlock operation - it will remain working.
i m just trying g900f file in to g900i but its saying writing fail
can u plz upload g900i cr file so i can write correct file
Welcome to Octoplus/Octopus Box Samsung software version 1.7.3
To connect GT-I9100G phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#7284#" number.
7. Set "USB" radio button to "PDA" value.
8. Press Home button.
9. Go to dial window.
10. Enter "*#9090#" number.
11. Set "Diag config" to "USB" value.
12. Restart phone.
13. Press "Read Info" in software.
To connect SM-G900I phone you have to perform the following steps:
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Go to dial window.
11. Enter "*#9090#" number.
12. Set "Diag config" to "USB" value.
13. Restart phone.
14. Press "Read Info" in software.
Selected port: COM3
Selected model: SM-G900I
ADB server killed.
Please, press "OK" button on the phone to allow USB debugging..
Detected phone model: SM-G900I
Firmware compiled date: Fri May 30 17:40:14 KST 2014
PDA version: G900IDVU1ANE2
CSC version: G900ITNZ1ANF1
SW version: G900IDVU1ANE1
Phone IMEI: 352919063742832
Phone SN: RF8F80DZY3M
Reading info...
Mode: Normal
Firmware compiled date: May 13 2014
Firmware compiled time: 02:00:00
Firmware released date: May 16 2014
Firmware released time: 17:31:11
SW Version: MPSS.DI.2.0.1.c2.2-00019-M8974AAAAANRZM-1
Reading QCN...
Send SPC...
Reading mobile property...
Mobile property read successfully
Reading feature mask...
Feature mask read successfully
Reading roaming list 0
Reading roaming list 0 read successfully
Reading NV items...
NV items read successfully
Reading NV SIM1 items...
NV SIM1 items read successfully
Reading NV SIM2 items...
NV SIM2 items read successfully
Reading NV items...
Reading EFS...
EFS read successfully
Reading provisioning items...
Provisioning items read successfully
Reading QCN done!
Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung
\BACKUP\QCN-SM-G900I-352919063742832-25-10-2014_12-48-
36-.qcn file
Checking Root:
Selected port: COM3
Reading info...
Mode: Normal
Reading QCN...
Send SPC...
Reading NV items...
Reading NV items...
Reading EFS...
Reading QCN done!
QCN read successfully
Selected port: COM3
Operation was canceled
Selected port: COM3
Selected file: C:\Users\salim\Desktop\g900f\Cert-SM-G900F_
352558067456427_00000000000.cert
ADB server killed.
Checking Root:
Phone is Rooted.
The Following User Says Thank You to MUTUAL For This Useful Post:
Old 10-25-2014, 02:02   #40 (permalink)
F_X
F_X's Avatar
Member: 2273678
Thanks Meter: 293
Hello everyone, I'm new to the forums so please bear with me.
I try to wipe the efs of a SM-G900T, but it doesn't go through.
The program seems to not respond or go irresponsive. Then when I try to write the Cert file it always gives me a fail. It's, of course, due to the EFS still remaining in the phone.
Has anyone been able to successfully wipe the efs on a SM-G900T? Thank you all in advance!
BR,
F_X
Old 10-25-2014, 03:19   #41 (permalink)
Member: 2195006
Thanks Meter: 19
Can i use any of these efs on a g900w8 some guy used tge wrong efs on my phone and i brought it to samsung and they wont warranty my phone.
Old 10-25-2014, 03:37   #42 (permalink)
Member: 2157134
Thanks Meter: 8
my status is
To connect SGH-T599 phone you have to perform the following steps:
7. Set "UART" radio button to "Modem" value.
8. Restart phone.
9. Press "Read Info" in software.
To connect SM-G900T phone you have to perform the following steps:
13. Restart phone.
Selected port: COM10
Phone was not found on the selected port!
Searching for USB diagnostic port...
Connecting to phone on COM9
Mode: Normal
Phone model: SM-G900T
Firmware compiled time: 01:00:00
Firmware released date: Mar 26 2014
Firmware released time: 11:37:24
Phone IMEI: 35342
SW version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1
Selected port: COM9
To Unlock of the device, do the next steps:
1. Root the phone.
2. Perform Wipe Security procedure ("Repair Security/Wipe Security"
button).
3. Write Certificate ("Write Cert" button).
Selected port: COM9
To Repair IMEI of the device, do the next steps:
1. Root the phone.
button).
Selected port: COM9
Mode: Normal
Phone IMEI: 35342
Please, select firmware file first!
Selected port: COM9
Mode: Normal
Phone IMEI: 353424-06-113609-4
Selected port: COM9
Proper android device not found. Make shure that "USB debug" option
on the device is turned on.
Selected port: COM9
Reading info, please wait...
Phone IMEI: 353424
Phone SN: RV8F50E9Q7X
Selected port: COM9
Phone IMEI: 353424
Reading info...
Mode: Normal
Reading QCN...
Send SPC...
Reading NV items...
Reading NV items...
Reading EFS...
Reading QCN done!
Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung
\BACKUP\QCN-SM-G900T-353424061136094-25-10-2014_10-28-
42-.qcn file
Checking Root:
STOPS HERE.............
The Following User Says Thank You to mrdnice88347 For This Useful Post:
Old 10-25-2014, 03:49   #43 (permalink)
Member: 2157134
Thanks Meter: 8
Reading NV items...
Reading NV items...
Reading EFS...
Reading QCN done!
\BACKUP\QCN-SM-G900T-353424061136094-25-10-2014_10-40-
02-.qcn file
Checking Root:
Phone is Rooted.
Reading security backup, please wait...
\BACKUP\Security-SM-G900T-353424061136094-25-10-2014_10-44-
06-.asec file
Wiping EFS...
EFS wipe successfully
Searching for a phone. Please wait...
Reading info...
Mode: Normal
Send SPC...
SPC send successfully
Writing QCN...
Writing NV items...
NV items write successfully
Writing NV SIM1 items...
NV SIM1 items write successfully
Writing NV SIM2 items...
NV SIM2 items write successfully
Wrting EFS...
EFS write successfully
Writing provisioning items...
Provisioning items write successfully.
Writing QCN done
Wipe security successfully complete.
NO IMEI
DISPLAY ERROR
SECURITY ERROR
THIS PHONE HAS BEEN FLASHED WITH UNAUTHOZED SOFTWARE & IS LOCKED.
CALL YOUR MOBILE OPERATOR FOR ADDIIONAL SUPPORT
PLEASE NOTE THAT REPAIR/RETURN FOR THIS ISSUE MAY ADDITIONAL COST
Old 10-25-2014, 04:32   #44 (permalink)
Member: 2157134
Thanks Meter: 8
team need the cert g900t who have urgent ASAP IM DOWN HERE.. MY CART IS EMPTY
Old 10-25-2014, 06:13   #45 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,070
can any one share 900s cert
Page generated in 0.26905 seconds with 8 queries
