09-23-2014, 09:38 | #1 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,767 | Octoplus Samsung Software v1.6.7 - SHV-E270K, GT-I9150 and much more... Octoplus/Octopus Box Samsung Software v1.6.7 is out! Find out more at: www.octoplusbox.com Last edited by GSM_Support; 09-23-2014 at 10:24. |
The Following 23 Users Say Thank You to GSM_Support For This Useful Post: |
09-23-2014, 15:32 | #5 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: punjab Age: 43
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | Quote:
still waiting for samsung bomm update pls team work on it | |
The Following 4,294,967,295 Users Say Thank You to diesel6 For This Useful Post: |
09-24-2014, 01:04 | #9 (permalink) |
Freak Poster Join Date: Jan 2013 Location: Pampanga, Philippines
Member: 1871628 Status: Offline Thanks Meter: 22 | @Octopus Team, Still CA-101 and Micro UART Cable must be used to unlock SHV-E270s? Some parts of the Unlocking Process is Tricky, i mean, we dont know what cable is to be used, it says insert usb cable which is supposed to insert Micro UART Cable (For 3303), please kindly fix this in the instruction manual so unlocking will be much more easier. |
09-24-2014, 08:16 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | @ dindincpr USB cable, means standart Micro USB cable, Micro UART cable - means Samsung Micro UART C3300k/C3303 cable with 523-525 kOhm resistor inside. |
09-24-2014, 19:39 | #12 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: Arica
Member: 1102095 Status: Offline Sonork: 0000 Thanks Meter: 55 | It gets stuck at 3% and no more moves. Quote:
09-24-2014, 23:41 | #14 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 46
Member: 152445 Status: Offline Thanks Meter: 16 | Bienvenido en Octoplus/Octopus Box Samsung software versión 1.6.7 Seleccione el archivo de firmware: GT-I9150 _for_Unlock_and_IMEI_SN_Repair.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9150 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume - " + "Power" keys. Please put the phone into Download Mode and connect USB cable. To put GT-I9150 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume - " + "Power" keys. Found phone on Firmware write started. Escribiendo la sección VC-Firmware... L a sección VC-Firmware ha sido escrita con éxito Escribiendo la sección KERNEL... L a sección KERNEL ha sido escrita con éxito Escribiendo la sección RECOVERY... L a sección RECOVERY ha sido escrita con éxito Escribiendo la sección modem... L a sección modem ha sido escrita con éxito Escribiendo la sección DTS... L a sección DTS ha sido escrita con éxito Escribiendo la sección CSC... L a sección CSC ha sido escrita con éxito Escribiendo la sección system... |
09-25-2014, 01:06 | #15 (permalink) | |
Member: 1871628 Status: Offline Thanks Meter: 22 | Quote:
Unlocking other Samsung Phones requires 2 cable mostly to be used, CA-101 and Micro UART Cable in just one operation. | |
