04-17-2015, 22:50 | #1 (permalink) |
Junior Member Join Date: Apr 2013 Location: TN
Member: 1922524 Status: Offline Sonork: Daniyyel Thanks Meter: 2 | Octoplus write cert option issue Welcome to Octoplus/Octopus Box Samsung software version 1.9.1 ----------------------------------------------------------------------------------- To connect SM-G900A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-G900A Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-G900A Selected file: C:\Users\Daniyyel\Desktop\Cert-SM-G900F_ 353110060712361_R58F0SFT2T.cert Proper android device not found. Make shure that "USB debug" option on the device is turned on. Certificate has been written successfully Please, restart the phone to apply changes Last edited by Octopus box; 04-18-2015 at 07:07. |
04-18-2015, 07:08 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | 10x for your report, we will check and fix the problem in next Software update. Now try to select SM-G900T and repeat the operation. |
04-20-2015, 07:36 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have prepared and sent You test Software version to PM. Try to write IMEI Certificate by using this Software (via Samsung Micro UART cable) and post here the result. |
