04-26-2016, 03:30 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Tanzania
Member: 14229 Status: Offline Thanks Meter: 135 | Please Help how to Fix 3G/4G in Samsung i9505 ver 5.0.1 Anyone with a solution I9505 5.0.1 3G/4G network ???????????????? I have a problem with my i9505. After an upgrade to 5.0.1 3G/4G network is not working, works fine on edge. When I select LTE/WCDMA option from the 'set preferred network type' list I don’t get 3G/4G network. I see that after an update to the latest version which is 5.0.1 , unfortunately 3G/4G is not working. The firmware I have been using to update my I9505 I9505XXUHOA7_OXAHOA7_v5.0.1_Repair_Firmware.zip PDA: I9505XXUHOA7 CSC: I9505OXAHOA7 Modem: I9505XXUHOA7 After going through these steps 1. Write firmware "I9505XXUFNA5_I9505OXAFNA5_I9505XXUFNA5_OXA_4. 4.2" from Support Area. 2. Write modem file "I9505XXUFNA1-MODEM" and GT-I9505_for_Unlock_and_IMEI_repair.oct". 3. Click "Repair 3G/4G" button. I got working connection with H+ immediately. But i need to get connection 3G/4G network on lollipop 5.0.1. Any Idea ????????????????????????? Last edited by calvinpower; 04-26-2016 at 03:40. |
04-26-2016, 10:44 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to make "Repair 3G/4G", then try to find and select Network manually. Also, please make sure, that phone has a correctly configured APN for 3G/4G connection. |
04-26-2016, 16:13 | #4 (permalink) | |
Member: 14229 Status: Offline Thanks Meter: 135 | Quote:
I have done every step above. Works fine on 4.4.2 but when I go to 5.0.1 click "Repair 3G/4G" button nvm fails. | |
04-26-2016, 19:00 | #6 (permalink) |
Member: 14229 Status: Offline Thanks Meter: 135 | Platform: Samsung Android Selected port: COM160 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Repairing 3G/4G... Reading nv... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\NV-GT-I9505-26-04-2016_20-59-09-.nv file Writing NVM failed 3G/4G repair successfully To finish the operation, please restart the phone via phone's menu. Performed by 2.2.4 software version |
04-26-2016, 19:04 | #7 (permalink) |
Member: 14229 Status: Offline Thanks Meter: 135 | Welcome to Octoplus/Octopus Box Samsung software version 2.2.4 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM160 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Repairing 3G/4G... Reading nv... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\NV-GT-I9505-26-04-2016_20-59-09-.nv file Writing NVM failed3G/4G repair successfully To finish the operation, please restart the phone via phone's menu. Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM160 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM160 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Creating NVM backup Reading NVM done! Repairing NVM for GT-I9505 phone... Writing NVM failed NVM repair completed successfully To finish the operation, please restart the phone via phone's menu. Performed by 2.2.4 software version |
04-27-2016, 10:56 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please try to perform "Read Info" operation from "Main" tab of the Software on different COM ports, with enabled "Manual select" option. When phone's info will be read fully and correctly, go to "Repair" tab and press "Repair 3G/4G" button. Post here full Software log of your actions. |
