04-17-2015, 17:35 | #1 (permalink) |
Freak Poster Join Date: Apr 2014
Member: 2170693 Status: Offline Thanks Meter: 1 | problem connecting G750A Welcome to Octoplus/Octopus Box Samsung software version 1.9.2 ----------------------------------------------------------------------------------- To connect SM-G750A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM252 Selected model: SM-G750A Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM6 Mode: Emergency |
04-17-2015, 18:01 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Do the next: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Connect the phone directly to PC. 11. Perform "Read Info" operation from the "Main" tab in the Software. Try to perform "Read Info" operation on different COM ports, with enabled "Manual select" option. |
07-30-2015, 10:12 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please contact us to Skype, or Yahoo! Messenger, we will check where might be the problem. Our contacts You can find in our profile. |
