09-17-2013, 02:51 | #16 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Code: Welcome to Octoplus/Octopus Box Samsung software version 1.3.1 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to dial window. 9. Enter "*#9090#" number. 10. Select "[4] DM over UART(*)". 11. Restart phone. 12. Press "Read Info" in software. Selected firmware file: I9505XXUBMGA_I9505OJVBMGA_I9505XXUBMGA_HOME.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9505 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing SBL1 section... SBL1 section has been written successfully. Writing SBL2 section... SBL2 section has been written successfully. Writing SBL3 section... SBL3 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing PERSDATA section... PERSDATA section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MDM section... MDM section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. |
09-17-2013, 03:01 | #17 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Successfully Unlocked just follow on this Procedure: 1:flash with For_Unlock_GT-I9505 from support 2:type "*#0808#" and select "DM+MODEM+ABD" 3:use usb cable 4:readinfo and press read codes Code: Platform: Samsung Android Selected port: COM3 Selected model: GT-I9505 Mode: Emergency Unlock for GT-I9505 phone in emergency mode can’t be done Selected firmware file: I9505 File for Unlock 4.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9505 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing MDM section... MDM section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Phone IMEI: 357800-05-921121-1 SW Version: M9615A-CEFWTAZM-4.0.17062 Reading phone unlock codes. It can take some time, please wait... Connecting to server... Connect successfully to server Checking smart card... Smart card successfully checked Checking operation... Operation successfully checked NCK unlock code: *#7465625*638*00000000# NSCK unlock code: *#7465625*782*00000000# SPCK unlock code: *#7465625*77*00000000# |
The Following User Says Thank You to chris2007 For This Useful Post: |
