04-16-2015, 09:07 | #3 (permalink) |
Freak Poster Join Date: Apr 2015 Location: IN INDIA
Member: 2372600 Status: Offline Sonork: 100.1663659,ICQ-670897523 Thanks Meter: 49 | HI, DO NEXT--- 1.Root your phone manually. 2.Block (stick) batterys proper contact by using tape, accordingly to picture above. 3.Connect powered-on phone to PC via Samsung Micro UART cable. 4.Install necessary driver. 5.Click "Repair Security/Wipe Security" button. 6.Click "Write Cert" button. |
04-16-2015, 11:18 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Do the next: 1. Make Factory data reset and wipe cache partition. 2. Root the phone. 3. Make Wipe Security. 4. Write IMEI Certificate. All Certificates files, which we have, are present in the Support Area (press "Go to Support" button at "Support & Options" tab in the Software) in the folder "Samsung/FOR UNLOCK ANDREPAIR/Certificates/". |
04-17-2015, 10:47 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to wipe EFS via phone's menu. Try to wipe EFS from the phone's menu, do the next: 1. Write any firmware (don't root the phone after, this is important!). 2. Type *#9090#. 3. Type at rigth corner MENU + select "Back". 4. Typy at rigth corner MENU + input Q. 5. Type at rigth croner MENU + input 0000. Look this video manual: https://www.youtube.com/watch?v=1DtPT2MmNhg. Also, look here: http://forum.gsmhosting.com/vbb/f684.../#post10978789. |
04-18-2015, 13:57 | #12 (permalink) |
Insane Poster Join Date: May 2014 Location: ITALIA
Member: 2178402 Status: Offline Thanks Meter: 8 | ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-N910F Selected file: D:\Program Files\Octoplus\Octoplus_Samsung\cert\Cert- sm-n910f_354780061170717.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM22 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Writing Certificate failed |
04-18-2015, 14:20 | #14 (permalink) |
Member: 2178402 Status: Offline Thanks Meter: 8 | yes imei /01 Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N910F Firmware compiled date: Wed Oct 8 14:49:22 KST 2014 PDA version: N910FXXU1ANJ4 CSC version: N910FITV1ANJ2 SW version: N910FXXU1ANJ4 Phone IMEI: 356900063125711 Phone SN: R58FB1R3YHJ Android version: 4.4.4 (KTU84P) Reading info... Mode: Normal Firmware compiled date: Sep 06 2014 Firmware compiled time: 20:00:00 Firmware released date: Oct 8 2014 Firmware released time: 11:40:28 SW Version: MPSS.BO.1.0.r10-00108-M9635TAARANAZM-1.5514.1 Backup saved as D:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-N910F-356900063125711-17-04-2015_09-14- 34-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as D:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N910F-356900063125711-17-04-2015_09-14- 38-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Sep 06 2014 Firmware compiled time: 20:00:00 Firmware released date: Oct 8 2014 Firmware released time: 11:40:28 SW Version: MPSS.BO.1.0.r10-00108-M9635TAARANAZM-1.5514.1 Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! -------------------- |
04-18-2015, 14:31 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Read out phone's info via ADB (press "Read info" button at "Android / EFS manager" tab in the Software) now and post here full Software log with this info. |
