04-22-2015, 06:12 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What is the problem with your device exactly? What is the state of your phone? Why do You want to write this firmware? What is the problem with writing firmware exactly? Please post here full Software log with "Write Firmware" procedure. |
04-22-2015, 06:15 | #3 (permalink) |
Freak Poster Join Date: Aug 2013 Location: Faisalabad ' Punjab Pakistan
Member: 1994919 Status: Offline Sonork: 100.1670912 Thanks Meter: 120 | Its Not possible Try to write 4.4.2 or 4.4.4 .. you can write 4.3 on Samsung phone once u write 4.4.2 or above ... if not available on support then Download from Sammobile . |
04-22-2015, 11:11 | #4 (permalink) |
No Life Poster Join Date: Dec 2014 Location: u.a.e
Member: 2320256 Status: Offline Sonork: 100.1661545 Thanks Meter: 50 | baseband unknown imei null in download mode came this massage (( rpmb: invalid rpmb data )) i can't downdgrade to 4.3 To connect SM-N900 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: N900XXUCMK2_N900OJVCMJ3_KSA_Saudi_Arabia_Android_4 .3.oct Please put the phone into Download Mode and connect USB cable. To put SM-N900 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed |
04-22-2015, 12:27 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | It is not always possible to downgrade firmware version of the phone. Mr. farhan2010 is right, You should reflash the phone with 4.4.2 firmware, or higher. |
