09-22-2016, 11:14 | #1 (permalink) |
No Life Poster Join Date: Dec 2000 Location: las palmas ,spain
Member: 2800 Status: Offline Thanks Meter: 47 | S6 g920P Tried 0011 for hidden menu but cant get it, i put Q and after 0000 but cant get hidden menu. |
09-22-2016, 11:17 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Please check whether GSM/(E)GPRS/WCDMA GCF is enabled in your phone: 1. Open hidden menu. There are two ways of doing it: 1) Run the following command via ADB: Code: adb shell su -c "am broadcast -a android.provider.Telephony.SECRET_CODE -d android_secret_code://IOTHIDDENMENU" 2) Perform the following actions: 1. Dial *#0011# and in the service menu do the following. 2. Click "Menu" then "Key input" then input Q then press "Ok". 3. Click "Menu" then "Back". 4. Click "Menu" then "Key input" then input 0000 then click "Ok". 2. After these steps Hidden menu should open. In Hidden menu, depending on available options, try to do the following: I.
II.
After these actions go to Settings -> Mobile Networks and Set Network Mode to Automatic, or GSM. |
09-22-2016, 12:08 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | "Domestic Unlock" operation unlocks the phone for usage with local providers of USA. You should use standard "Unlock" operation in your case. |
09-22-2016, 14:38 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Insert SIM card and try to find and select network manually. Also, please post here full Software log of "Unlock" operation. |
09-22-2016, 16:40 | #10 (permalink) |
Member: 2800 Status: Offline Thanks Meter: 47 | INFO : 22/09/2016 12:15:32 > Platform: Samsung Android INFO : 22/09/2016 12:15:32 > Selected port: COM95 INFO : 22/09/2016 12:15:32 > Selected model: SM-G920P WARN : 22/09/2016 12:15:34 > Please, press "OK" button on the phone to allow USB debugging.. WARN : 22/09/2016 12:15:36 > Please, press "OK" button on the phone to allow USB debugging.. INFO : 22/09/2016 12:15:38 > Detected phone model: SM-G920P INFO : 22/09/2016 12:15:38 > Firmware compiled date: Tue Apr 5 16:13:35 KST 2016 INFO : 22/09/2016 12:15:38 > PDA version: G920PVPS3CPD2 INFO : 22/09/2016 12:15:38 > CSC version: G920PSPT3CPD2 INFO : 22/09/2016 12:15:38 > SW version: G920PVPS3CPD2 INFO : 22/09/2016 12:15:38 > Phone SN: 00000000000 INFO : 22/09/2016 12:15:38 > Android version: 6.0.1 (MMB29K) INFO : 22/09/2016 12:15:38 > Sales code: SPR INFO : 22/09/2016 12:15:38 > Country: USA INFO : 22/09/2016 12:15:38 > HW platform: exynos5 INFO : 22/09/2016 12:15:38 > HW Chip: exynos7420 INFO : 22/09/2016 12:15:38 > HW Modem: MDM9635M INFO : 22/09/2016 12:15:38 > Codename: zerofltespr INFO : 22/09/2016 12:15:38 > Checking Root: ERROR : 22/09/2016 12:15:40 > Phone is not Rooted. INFO : 22/09/2016 12:15:40 > Installing service app... INFO : 22/09/2016 12:15:46 > Unlocking phone... INFO : 22/09/2016 12:15:52 > Finalizing... INFO : 22/09/2016 12:15:55 > Phone is successfully unlocked WARN : 22/09/2016 12:15:55 > To finish the operation, please restart the phone via phone's menu. WARN : 22/09/2016 12:15:55 > WARNING! If 'INVALID SIM' message still remains then Root the phone and try again! INFO : 22/09/2016 12:15:56 > Performed by 2.3.6 software version Log file "C:\Archivos de programa\Octoplus\Octoplus_Samsung\LOG\22-09-2016_12-15-07.log" closed (22/09/2016 12:32:23). |
09-22-2016, 16:48 | #12 (permalink) |
Member: 2800 Status: Offline Thanks Meter: 47 | Bienvenido en Octoplus/Octopus Box Samsung software versión 2.3.6 ----------------------------------------------------------------------------------- To connect SM-G920P phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM95 Modelo seleccionado: SM-G920P Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Modelo del teléfono detectado: SM-G920P Fecha de creación del firmware: Tue Apr 5 16:13:35 KST 2016 PDA version: G920PVPS3CPD2 CSC version: G920PSPT3CPD2 Versión del SW: G920PVPS3CPD2 Phone SN: 00000000000 Android version: 6.0.1 (MMB29K) Sales code: SPR Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: MDM9635M Codename: zerofltespr Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-G920P-Unknown-22-09-2016_16-47-13 file Installing service app... Liberando el teléfono... Finalizing... El teléfono ha sido liberado con éxito To finish the operation, please restart the phone via phone's menu. Performed by 2.3.6 software version |
09-22-2016, 17:23 | #15 (permalink) |
Member: 2800 Status: Offline Thanks Meter: 47 | I have tried diferent methods but can get to that menu.Maybe is diferent in version 6.0.1. The 0011,q,0000 is not working i wait 1 min and the menu doesnt appear,also tried cmd and the activating phone from menu. |
