04-19-2016, 04:17 | #1 (permalink) |
Crazy Poster Join Date: Oct 2014 Location: LapuLapu City Cebu,Philippines
Member: 2270870 Status: Offline Thanks Meter: 9 | SCH-W550 Need to Unlock , But Connection Failed When Switching Emergency Mode Need help Need to Unlock , AFter Click Unlock Button Phone is Reading in Normal Mode, When Phone Switching in Emergency Mode By Tools , it says Phone connection failed Heres Screenshot , When Phone Switching Emergency Mode by Tools Like This Mode: Emergency Phone connection failed Connecting to phone on COM3 Phone connection failed Last edited by Toperz; 04-19-2016 at 04:24. |
04-19-2016, 10:26 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,419 | Hello. Try to put the phone into Emergency Mode manually, then re-connect the phone to PC. Try to use different USB ports of PC motherboard for connection. To enter emergency mode, reconnect the battery, press and hold "Volume up" + "Volume down" + "Power ON" buttons. |
04-19-2016, 10:33 | #5 (permalink) |
Member: 2270870 Status: Offline Thanks Meter: 9 | When i apply THese Combinations press and hold "Volume up" + "Volume down" + "Power ON" buttons. Screen Shows THis THen I'll Try to Unlock in That Mode, But same Error in 1st post. |
04-19-2016, 10:39 | #6 (permalink) |
Member: 2270870 Status: Offline Thanks Meter: 9 | i dont understand why the Comport Failed When Switching in Emergency Mode by TOols. But Phone is No Problem in Normal Mode. and Phone is Still Detected in PC |
04-19-2016, 10:55 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,419 | Please power on the phone, then do the next: 1. Enter "System Info Menu" - 4433366368791 combination. 2. Select "SIO Mode" (instead of mode there can be some hieroglyphs). 3. Select "Port Map" menu item 4. Set "Diag Moditor" to "USB CDC" value 5. All the rest items in this menu set up to "NULL DEV" Repeat "Unlock" operation after these steps. |
04-19-2016, 11:23 | #8 (permalink) |
Member: 2270870 Status: Offline Thanks Meter: 9 | Tnx for Give Idea sir , ill Appreciate it.. I'll Try to Follow you Sir Clearly and The Software Instructions, Step By Step But Error is Still. Ill Try Also All Motheboard Port and in Octoplus Box Port , But Same Error THen Unlock , But Same Error Shows in Software. Softwares is Switching in THis Mode After That Softwares Gives error Phone Connecting Failed.. But Phone is Still Detected on PC in That Mode. Last edited by Toperz; 04-19-2016 at 11:31. |
04-19-2016, 12:21 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,419 | Please contact us to Skype, or Yahoo! Messenger, we will try to help You. Our contacts You can find in our profile. |
