01-07-2017, 09:59 | #1 (permalink) |
No Life Poster Join Date: Sep 2010 Location: PNG Papua New Guinea
Member: 1395476 Status: Offline Sonork: Men7896 Thanks Meter: 52 | Samsung G532F/M frp reset procedure Hihi. This is the exact step by step for G532 frp reset by octoplus box. First download the combination files from support check the tar and advance box on the upper right of octoplus exe. press the flash button then a box shall pop up(for advance) only check the boot.img box then press ok. after flash the phone shall ask for pin or security code. Hrad reset the device. now connect the device to pc will shows the usb debug option on your phone. check the usb debug option then press frp reset. follow instruction,but after reset the phone still will show setup phone again. press the home or back button,phone shall shows font screen use finger slide from the screen top shall show the setting option. from setting turn on the oem unlock then factory reset. Job done. If want to play safe can flash the stock rom. Also for me I use 2 box for the process. Octoplus for combination boot.img and z3x for frp. But I think octoplus shall able to complete the job. p/s.if the device boot loop.just reflash with stock rom and redo again. Good luck Regards Please press thanks if this article is helpful.tq Last edited by Octopus box; 01-07-2017 at 15:18. |
The Following 6 Users Say Thank You to Men7896 For This Useful Post: |
