05-06-2015, 04:12 | #4 (permalink) |
Junior Member Join Date: Oct 2007
Member: 610812 Status: Offline Thanks Meter: 3 | logre reparar un G800H Imei Null con este proceso utilizando el modelo I9192 el unico problema que veo es que no levanta seņal con ningun imei, hay algo mas que se tiene que hace? Dar en reparar y escribir el imei y serial del telefono... |
05-06-2015, 07:47 | #5 (permalink) |
Freak Poster Join Date: Apr 2015 Location: IN INDIA
Member: 2372600 Status: Offline Sonork: 100.1663659,ICQ-670897523 Thanks Meter: 49 | [QUOTE=Imei repair a G800H achieve Null with this process using the model I9192 the only problem I see is that it does not raise any IMEI signal, there is something more that you have to do? Give repairing and write the serial and IMEI of the phone ...[/QUOTE] HI, Unfortunately, SM-G800H is currently not supported. |
