04-23-2016, 06:30 | #1 (permalink) |
Freak Poster Join Date: Sep 2010 Location: Pune, MH, India
Member: 1398382 Status: Offline Thanks Meter: 57 | Samsung Galaxy S7 Edge SM-G935F Unlock Successfull Done by Octopus Root With This File, Before Root with this file make sure that your built same as root file. https://androidmtk.com/root-samsung-...-edge-sm-g935f photo uploading Regards, Yunus Shaikh Last edited by Octopus box; 04-23-2016 at 12:10. |
The Following 4 Users Say Thank You to sidrasystems1 For This Useful Post: |
06-07-2016, 14:14 | #5 (permalink) | |
No Life Poster Join Date: May 2014 Location: Nigeria
Member: 2192386 Status: Offline Thanks Meter: 50 | Quote:
The Following User Says Thank You to adebayo0437 For This Useful Post: |
06-07-2016, 14:21 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to perform "Read Codes" operation instead of an "Unlock". Post here result and full Software log of performed operations. |
06-07-2016, 14:47 | #7 (permalink) | |
INFO : 6/7/2016 1:16:46 PM > To connect SM-G935F phone you have to perform the following steps: INFO : 6/7/2016 1:16:46 PM > 1. Disconnect USB cable from phone. INFO : 6/7/2016 1:16:46 PM > 2. Go to Menu->Settings->More->About Device. INFO : 6/7/2016 1:16:46 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 6/7/2016 1:16:46 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 6/7/2016 1:16:46 PM > 5. Turn on "USB Debugging" option. INFO : 6/7/2016 1:16:47 PM > ----------------------------------------------------------------------------------- INFO : 6/7/2016 1:16:49 PM > Platform: Samsung Android INFO : 6/7/2016 1:16:49 PM > Selected port: COM118 INFO : 6/7/2016 1:16:49 PM > Selected model: SM-G935F INFO : 6/7/2016 1:16:49 PM > Reading info, please wait... INFO : 6/7/2016 1:16:52 PM > Detected phone model: SM-G935F INFO : 6/7/2016 1:16:53 PM > Firmware compiled date: Fri May 27 13:39:54 KST 2016 INFO : 6/7/2016 1:16:53 PM > PDA version: G935FXXU1APER INFO : 6/7/2016 1:16:53 PM > CSC version: G935FOJX1APE8 INFO : 6/7/2016 1:16:53 PM > SW version: G935FXXU1APEQ INFO : 6/7/2016 1:16:53 PM > Phone SN: RZ8H50H3RSB INFO : 6/7/2016 1:16:53 PM > Android version: 6.0.1 (MMB29K) INFO : 6/7/2016 1:16:53 PM > Country: TURKEY INFO : 6/7/2016 1:16:53 PM > HW platform: exynos5 INFO : 6/7/2016 1:16:53 PM > HW Chip: exynos8890 INFO : 6/7/2016 1:16:53 PM > HW Modem: SHANNON335 INFO : 6/7/2016 1:16:53 PM > Codename: hero2ltexx INFO : 6/7/2016 1:16:59 PM > Performed by 2.2.7 software version INFO : 6/7/2016 1:17:00 PM > ----------------------------------------------------------------------------------- INFO : 6/7/2016 1:17:02 PM > Platform: Samsung Android INFO : 6/7/2016 1:17:02 PM > Selected port: COM118 INFO : 6/7/2016 1:17:02 PM > Selected model: SM-G935F INFO : 6/7/2016 1:17:04 PM > Detected phone model: SM-G935F INFO : 6/7/2016 1:17:04 PM > Firmware compiled date: Fri May 27 13:39:54 KST 2016 INFO : 6/7/2016 1:17:04 PM > PDA version: G935FXXU1APER INFO : 6/7/2016 1:17:04 PM > CSC version: G935FOJX1APE8 INFO : 6/7/2016 1:17:04 PM > SW version: G935FXXU1APEQ INFO : 6/7/2016 1:17:05 PM > Phone SN: RZ8H50H3RSB INFO : 6/7/2016 1:17:05 PM > Android version: 6.0.1 (MMB29K) INFO : 6/7/2016 1:17:05 PM > Country: TURKEY INFO : 6/7/2016 1:17:05 PM > HW platform: exynos5 INFO : 6/7/2016 1:17:05 PM > HW Chip: exynos8890 INFO : 6/7/2016 1:17:05 PM > HW Modem: SHANNON335 INFO : 6/7/2016 1:17:05 PM > Codename: hero2ltexx INFO : 6/7/2016 1:17:05 PM > Checking Root: INFO : 6/7/2016 1:17:05 PM > Phone is Rooted. INFO : 6/7/2016 1:17:05 PM > Reading security backup, please wait... INFO : 6/7/2016 1:17:39 PM > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G935F-Unknown07-06-2016_13-17-02-.asec file INFO : 6/7/2016 1:17:39 PM > Initializing exploit... INFO : 6/7/2016 1:17:48 PM > Executing exploit... INFO : 6/7/2016 1:18:04 PM > Exploit has been executed successfully INFO : 6/7/2016 1:18:04 PM > Reading phone unlock codes. It can take some time, please wait... ERROR : 6/7/2016 1:21:31 PM > Can't find code! INFO : 6/7/2016 1:21:31 PM > Work time: 0:03:20 INFO : 6/7/2016 1:21:31 PM > Performed by 2.2.7 software version INFO : 6/7/2016 1:21:45 PM > ---------------------------------------------------------------------- read codes not working | |
06-07-2016, 15:11 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to do the next: 1. Make "DRK fix". 2. Reflash the phone. 3. Root the phone. 4. Try to perform "Read Codes"/"Unlock" operation again. Post here result and full Software log of your actions. |
11-03-2016, 16:58 | #12 (permalink) | ||
Freak Poster Join Date: Apr 2009 Location: Salvador - BA - Brazil Age: 37
Member: 1010981 Status: Offline Sonork: 100.1614537 Thanks Meter: 47 | I have same problem !! Quote:
11-03-2016, 17:08 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please try to perform "Fast Unlock" operation on different available COM ports, with enabled "Manual select" option. If problem will remain the same - re-install Samsung USB driver, restart PC, then try to perform "Fast Unlock" operation again. |
11-04-2016, 08:50 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Such problem can be caused by new firmware, which has your phone. To restore the phone to its initial condition You need to write Security backup, created during "Unlock" operation, back into the phone. To process the phone try to write older (by release date) firmware, then repeat "Unlock" operation. |
