04-15-2015, 20:01 | #1 (permalink) |
Freak Poster Join Date: May 2009 Location: bangladesh
Member: 1022144 Status: Offline Sonork: Love in Bangladesh Thanks Meter: 139 | samsung I9300 firmware not write ! Platform: Samsung Android Selected port: COM1 Selected model: GT-I9300 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Rebooting phone failed. Please put the phone into Download Mode and connect USB cable. To put GT-I9300 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Please put the phone into Download Mode and connect USB cable. To put GT-I9300 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing SYSTEM section... |
04-15-2015, 20:23 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Fully charge phone's battery by using external chrger and try to perform "Write Firmware" operation again. Try to write different firmwares. If problem will remain the same, then, most likely, your phone has HW problem. Last edited by Octopus box; 04-16-2015 at 06:17. |
