01-19-2014, 15:49 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | Samsung n7100 imei null how to repair? I have done of i9300 with corrupt imei (though is not "null/null" but the imei started with 004....... and it has yellow on the screen too) with these procedure down; 1) repair efs. 2) root phone with the root file from support area. 3) IME A fix. 4) repair network. Now I want to know whether it will work on the N7100 with imei null/null or do I need to do extra thing. |
01-19-2014, 19:23 | #2 (permalink) | |
Member: 576282 Status: Offline Thanks Meter: 145 | Quote:
is it there no hope? | |
01-19-2014, 20:39 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ lionfinger2007 Hello. At first, please make "Read info" at "Android / EFS manager" tab in Software and post here full Software log with phone's info, we will look and try to advise You what to do the next. |
01-20-2014, 09:56 | #5 (permalink) | |
Sir here is the info below; Welcome to Octoplus/Octopus Box Samsung software version 1.4.5 ----------------------------------------------------------------------------------- To connect GT-N7100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" radio button to "MODEM" value. 12. Set "USB" radio button to "PDA" value 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: GT-N7100 Reading info, please wait... Detected phone model: GT-N7100 Firmware compiled date: Mon Oct 29 22:33:32 KST 2012 PDA version: N7100XXDLJ2 CSC version: N7100OXADLJ2 SW version: Unknown Phone IMEI: Unknown Android version: 4.1.2 (JZO54K) | |
01-20-2014, 10:02 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As I see from this log, modem part is damaged in your device: Quote:
At first, try to re-flash the device with different firmwares and check whether modem is correct (not Unknown) and only then perform "Repair EFS" and "Repair IMEI" operations. | |
01-21-2014, 08:12 | #7 (permalink) | |
Now I have flashed the phone with android 4.3 and if I repair efs, the yellow written will not show again but the sw version is still unkown and the imei is still null/null. Any other thing I will do on it? | |
01-21-2014, 08:20 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
Please re-flash the device with different firmwares (not only with one) and check whether modem is correct. If after of writing all firmwares, phone's modem part is still "Unknown" - most likely, this is HW problem. | |
