04-18-2015, 11:46 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Samsung N910c unlock help need [Solved] because i try a lot of times. every time fail is is makes angry me. 1.which model select for wipe? 2.which cert is tested and working? 3.where working qcn of N910c 4. DM+Modem+ADB after select show usb not recognised help or guide me pls Last edited by Octopus box; 04-18-2015 at 12:41. |
04-18-2015, 12:10 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Kathmandu, Nepal
Member: 260236 Status: Offline Sonork: 100.1641081 Thanks Meter: 135 | 1. Select MTP+ADB 2. Use the Cert file for N910C itself (You can find it in support area) 3. No need to wipe but of course root is needed 4. Both usb and uart connection is needed for this operation. First connect it to usb, install the drivers and start the 'write cert' operation and as the s/w ask for uart connection connect it through. 5. QCN is not needed until you have already wiped it. *If you still got problems connect me through sonork. Regards. |
04-18-2015, 12:30 | #5 (permalink) | |
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Quote:
problem solved it is charming with lovely octopus 1. must need root 2.select mtp+adb 3.trick unknown source 4.untrick verify apps 5.no need wipe 6.select N910c and select new working cert from support 7.after asking software use urat and usb 8.no need qcn because i don't wipe the phone now happy also sure i will help you those are facing this model issue | |
The Following User Says Thank You to ..::Gsmideazone::.. For This Useful Post: |
04-18-2015, 12:40 | #6 (permalink) | |||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Quote:
