04-19-2015, 18:12 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please enable USB Debugging option, connect the phone directly to PC and perform "Read Info" operation from "Android/EFS manager" tab of the Software. Post here full Software log of the operation. |
04-23-2015, 12:04 | #3 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Lahore
Member: 392149 Status: Offline Thanks Meter: 199 | Quote:
To connect SC-01F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SC-01F Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SC-01F Firmware compiled date: Wed Sep 25 21:38:26 KST 2013 PDA version: SC01FOMUBMIF CSC version: SC01FDCMBMIF SW version: SC01FOMUBMIF Phone IMEI: 357351052635329 Phone SN: R38F414XD4E Android version: 4.3 (JSS15J) Platform: Samsung Android Selected port: COM8 Selected model: SC-01F Detected phone model: SC-01F Firmware compiled date: Wed Sep 25 21:38:26 KST 2013 PDA version: SC01FOMUBMIF CSC version: SC01FDCMBMIF SW version: SC01FOMUBMIF Phone IMEI: 357351052635329 Phone SN: R38F414XD4E Android version: 4.3 (JSS15J) Reading info... Phone was not found on the selected port! | |
04-23-2015, 12:12 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Re-install the latest drivers (http://octoplusbox.com/files/drivers...ile_Phones.exe), install the latest Software version (if You don't use the latest), and connect the phone again. To connect SC-01F, perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" button at the "Main" tab in the software. |
04-23-2015, 12:17 | #5 (permalink) | |
04-23-2015, 12:37 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to make Factory data reset, wipe cache partition, re-flash the phone with the firmware from the Support Area and try again. |
04-24-2015, 08:31 | #7 (permalink) |
Member: 392149 Status: Offline Thanks Meter: 199 | Bro not work try to factory reset or wipe cache also flash with octopus this file SC01FOMUFNF6_SC01FDCMFNF6_DCM_Android_4.4.2.oct not work any code *#0808# or *#9090# what can i do? |
04-24-2015, 10:42 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Currently no other way to enable Diag mode. Try to write different firmwares and check, whether *#0808#, *#9090# codes are working. |
