04-15-2015, 08:10 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Indonesia Raya
Member: 636569 Status: Offline Thanks Meter: 192 | Samsung S4 E300K unlock succes but? Welcome to Octoplus/Octopus Box Samsung software version 1.9.2 ----------------------------------------------------------------------------------- To connect GT-P3100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SHV-E300K phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SHV-E300K Port is busy Searching for a phone. Please wait... Phone found. Firmware compiled date: Tue Jan 14 17:06:27 KST 2014 PDA version: E300KKKUENA2 CSC version: E300KKTTEML1 SW version: E300KKKUANA2 Phone IMEI: 3559990xxxxx Android version: 4.3 (JSS15J) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SHV-E300K Detected phone model: SHV-E300K Firmware compiled date: Tue Jan 14 17:06:27 KST 2014 PDA version: E300KKKUENA2 CSC version: E300KKTTEML1 SW version: E300KKKUANA2 Phone IMEI: 3559990xxxxxx Phone SN: R33D60DPS2 Android version: 4.3 (JSS15J) Checking Root: Phone is Rooted. Repairing network. Please wait, this can take some time... Network is successfully repaired. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SHV-E300K Port is busy Searching for a phone. Please wait... Phone found. Firmware compiled date: Tue Jan 14 17:06:27 KST 2014 PDA version: E300KKKUENA2 CSC version: E300KKTTEML1 SW version: E300KKKUANA2 Phone IMEI: 35599905xxxxxx Android version: 4.3 (JSS15J) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SHV-E300K Detected phone model: SHV-E300K Firmware compiled date: Tue Jan 14 17:06:27 KST 2014 PDA version: E300KKKUENA2 CSC version: E300KKTTEML1 SW version: E300KKKUANA2 Phone IMEI: 355999xxxxxx Phone SN: R33D60DPS2 Android version: 4.3 (JSS15J) Checking Root: Phone is Rooted. Reading security backup, please wait... Unlocking phone. This can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
04-15-2015, 08:19 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Insert SIM card, wait 5-7 minutes and try to find and select network manually. If this will not help, do the next: 1. Write firmware from the Support Area. 2. Make Repair Network. |
04-17-2015, 09:58 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Post here full Software log with these operations. Also, try to use different SIM cards and say the result. Last edited by Octopus box; 04-17-2015 at 10:07. |
04-17-2015, 10:03 | #7 (permalink) |
Member: 636569 Status: Offline Thanks Meter: 192 | Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\17-04-2015_14-31-08.log" created (04/17/2015 2:31:11 PM). ERROR : 04/17/2015 2:31:12 PM > Access violation at address 00948A28 in module 'OctoplusSamsung.exe'. Read of address 00000004 INFO : 04/17/2015 2:31:12 PM > Set up system language English (file: English.ini) INFO : 04/17/2015 2:31:12 PM > Welcome to Octoplus/Octopus Box Samsung software version 1.9.2 INFO : 04/17/2015 2:31:12 PM > ----------------------------------------------------------------------------------- INFO : 04/17/2015 2:31:12 PM > To connect SHV-E300K phone you have to perform the following steps: INFO : 04/17/2015 2:31:12 PM > 1. Disconnect USB cable from phone. INFO : 04/17/2015 2:31:12 PM > 2. Go to Menu->Settings->More->About Device. INFO : 04/17/2015 2:31:12 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 04/17/2015 2:31:12 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 04/17/2015 2:31:12 PM > 5. Turn on "USB Debugging" option. INFO : 04/17/2015 2:31:24 PM > Selected firmware file: E300KKKUFNL3_E300KKTTFNL3_KTF_Android_4.4.2.oct WARN : 04/17/2015 2:31:31 PM > Please put the phone into Download Mode and connect USB cable. WARN : 04/17/2015 2:31:31 PM > To put SHV-E300K into Download Mode, You have to perform the following steps: WARN : 04/17/2015 2:31:31 PM > 1. Reconnect the battery. WARN : 04/17/2015 2:31:31 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 04/17/2015 2:31:31 PM > 3. When phone turns on, press "Volume+" key. INFO : 04/17/2015 2:31:31 PM > Found phone on INFO : 04/17/2015 2:31:31 PM > Firmware write started. INFO : 04/17/2015 2:31:31 PM > Writing BOOTLOADER section... INFO : 04/17/2015 2:31:33 PM > BOOTLOADER section has been written successfully. INFO : 04/17/2015 2:31:33 PM > Writing BOOT section... INFO : 04/17/2015 2:31:36 PM > BOOT section has been written successfully. INFO : 04/17/2015 2:31:36 PM > Writing RECOVERY section... INFO : 04/17/2015 2:31:38 PM > RECOVERY section has been written successfully. INFO : 04/17/2015 2:31:38 PM > Writing SYSTEM section... INFO : 04/17/2015 2:38:37 PM > SYSTEM section has been written successfully. INFO : 04/17/2015 2:38:37 PM > Writing CACHE section... INFO : 04/17/2015 2:38:47 PM > CACHE section has been written successfully. INFO : 04/17/2015 2:38:47 PM > Writing HIDDEN section... INFO : 04/17/2015 2:38:50 PM > HIDDEN section has been written successfully. INFO : 04/17/2015 2:38:50 PM > Writing RADIO section... INFO : 04/17/2015 2:38:53 PM > RADIO section has been written successfully. INFO : 04/17/2015 2:38:53 PM > Firmware writing successfully completed. INFO : 04/17/2015 2:54:09 PM > ----------------------------------------------------------------------------------- INFO : 04/17/2015 2:54:09 PM > Platform: Samsung Android INFO : 04/17/2015 2:54:09 PM > Selected port: COM3 INFO : 04/17/2015 2:54:09 PM > Selected model: SHV-E300K INFO : 04/17/2015 2:54:09 PM > Reading info, please wait... INFO : 04/17/2015 2:54:11 PM > Detected phone model: SHV-E300K INFO : 04/17/2015 2:54:11 PM > Firmware compiled date: Fri Dec 26 12:45:15 KST 2014 INFO : 04/17/2015 2:54:12 PM > PDA version: E300KKKUFNL3 INFO : 04/17/2015 2:54:12 PM > CSC version: E300KKTTFNL3 INFO : 04/17/2015 2:54:13 PM > SW version: E300KKKUANI1 INFO : 04/17/2015 2:54:14 PM > Phone IMEI: 355999052xxxxxx INFO : 04/17/2015 2:54:14 PM > Phone SN: R33D60DPS2 INFO : 04/17/2015 2:54:14 PM > Android version: 4.4.2 (KOT49H) INFO : 04/17/2015 2:54:22 PM > ----------------------------------------------------------------------------------- INFO : 04/17/2015 2:54:22 PM > Platform: Samsung Android INFO : 04/17/2015 2:54:22 PM > Selected port: COM3 INFO : 04/17/2015 2:54:23 PM > Selected model: SHV-E300K INFO : 04/17/2015 2:54:24 PM > Detected phone model: SHV-E300K INFO : 04/17/2015 2:54:24 PM > Firmware compiled date: Fri Dec 26 12:45:15 KST 2014 INFO : 04/17/2015 2:54:25 PM > PDA version: E300KKKUFNL3 INFO : 04/17/2015 2:54:25 PM > CSC version: E300KKTTFNL3 INFO : 04/17/2015 2:54:26 PM > SW version: E300KKKUANI1 INFO : 04/17/2015 2:54:27 PM > Phone IMEI: 355999052xxxxxx INFO : 04/17/2015 2:54:28 PM > Phone SN: R33D60DPS2 INFO : 04/17/2015 2:54:28 PM > Android version: 4.4.2 (KOT49H) INFO : 04/17/2015 2:54:28 PM > Checking Root: INFO : 04/17/2015 2:54:29 PM > Phone is not Rooted. Rooting phone... ERROR : 04/17/2015 2:54:30 PM > Repairing network failed. INFO : 04/17/2015 3:11:22 PM > ----------------------------------------------------------------------------------- INFO : 04/17/2015 3:11:22 PM > Platform: Samsung Android INFO : 04/17/2015 3:11:22 PM > Selected port: COM3 INFO : 04/17/2015 3:11:22 PM > Selected model: SHV-E300K INFO : 04/17/2015 3:11:22 PM > Reading info, please wait... INFO : 04/17/2015 3:11:23 PM > ADB server killed. INFO : 04/17/2015 3:11:24 PM > Detected phone model: SHV-E300K INFO : 04/17/2015 3:11:24 PM > Firmware compiled date: Fri Dec 26 12:45:15 KST 2014 INFO : 04/17/2015 3:11:24 PM > PDA version: E300KKKUFNL3 INFO : 04/17/2015 3:11:25 PM > CSC version: E300KKTTFNL3 INFO : 04/17/2015 3:11:26 PM > SW version: E300KKKUANI1 INFO : 04/17/2015 3:11:27 PM > Phone IMEI: 35599905xxxxxxx INFO : 04/17/2015 3:11:27 PM > Phone SN: R33D60DPS2 INFO : 04/17/2015 3:11:27 PM > Android version: 4.4.2 (KOT49H) INFO : 04/17/2015 3:11:29 PM > ----------------------------------------------------------------------------------- INFO : 04/17/2015 3:11:29 PM > Platform: Samsung Android INFO : 04/17/2015 3:11:29 PM > Selected port: COM3 INFO : 04/17/2015 3:11:29 PM > Selected model: SHV-E300K INFO : 04/17/2015 3:11:31 PM > Detected phone model: SHV-E300K INFO : 04/17/2015 3:11:31 PM > Firmware compiled date: Fri Dec 26 12:45:15 KST 2014 INFO : 04/17/2015 3:11:31 PM > PDA version: E300KKKUFNL3 INFO : 04/17/2015 3:11:32 PM > CSC version: E300KKTTFNL3 INFO : 04/17/2015 3:11:32 PM > SW version: E300KKKUANI1 INFO : 04/17/2015 3:11:33 PM > Phone IMEI: 35599905xxxxxxxxx INFO : 04/17/2015 3:11:34 PM > Phone SN: R33D60DPS2 INFO : 04/17/2015 3:11:34 PM > Android version: 4.4.2 (KOT49H) INFO : 04/17/2015 3:11:34 PM > Checking Root: INFO : 04/17/2015 3:11:38 PM > Phone is Rooted. INFO : 04/17/2015 3:11:38 PM > Repairing network. Please wait, this can take some time... INFO : 04/17/2015 3:12:55 PM > Network is successfully repaired. INFO : 04/17/2015 3:15:03 PM > ----------------------------------------------------------------------------------- INFO : 04/17/2015 3:15:03 PM > Platform: Samsung Android INFO : 04/17/2015 3:15:03 PM > Selected port: COM3 INFO : 04/17/2015 3:15:03 PM > Selected model: SHV-E300K INFO : 04/17/2015 3:15:03 PM > Port is busy INFO : 04/17/2015 3:15:03 PM > Searching for a phone. Please wait... INFO : 04/17/2015 3:15:04 PM > Phone found. INFO : 04/17/2015 3:15:05 PM > Firmware compiled date: Fri Dec 26 12:45:15 KST 2014 INFO : 04/17/2015 3:15:05 PM > PDA version: E300KKKUFNL3 INFO : 04/17/2015 3:15:06 PM > CSC version: E300KKTTFNL3 INFO : 04/17/2015 3:15:06 PM > SW version: E300KKKUANI1 INFO : 04/17/2015 3:15:08 PM > Phone IMEI: 3559990xxxxxxxxx INFO : 04/17/2015 3:15:08 PM > Android version: 4.4.2 (KOT49H) Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\17-04-2015_14-31-08.log" closed (04/17/2015 3:34:40 PM). |
04-17-2015, 10:07 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to use different SIM cards and say the result. Also, read out Security backup and post it here, we will try to write it into our devcie and check. |
04-17-2015, 13:10 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Security is correct and unlocked. Try to make Factory data reset, wipe cache partition and write different firmwares. After writing each firmware, make Repair Network, insert SIM card, wait 5-7 minutes and try to find and select network manually. Also try to use SIM cards of other operators and try to find and select network manually. |
