09-16-2015, 15:55 | #17 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to write Cert file from the Support Area (reflash the phone if IMEI/Baseband will became null), then check, whether phone obtains Network correctly (try to find and select Network manually) and status of IMEI Certi. |
09-17-2015, 06:44 | #18 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Bangladesh Age: 42
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | i am trying several times with different cert file But its fail At 5.0.1 i root the phone and try to write cert it shows the error message so i downgrade the phone and here show the same message Code: Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Selected file: F:\Octopus Box\Flash File\Samsung\I9500\Cert-GT-I9500_ 352993050052646.cert ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9500 Firmware compiled date: Tue Oct 28 00:38:58 KST 2014 PDA version: I9500UBUGNJ1 CSC version: I9500UUBGNJ1 SW version: I9500UBUGNJ1 Phone IMEI: 357196053604596 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Checking Certificate failed Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Selected file: C:\Users\RC\Downloads\cert-gt-i9500_359169056627003 _r21f32ztt1.cert Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Reading info, please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Reading info, please wait... ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9500 Firmware compiled date: Tue Oct 28 00:38:58 KST 2014 PDA version: I9500UBUGNJ1 CSC version: I9500UUBGNJ1 SW version: I9500UBUGNJ1 Phone IMEI: 357196053604596 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Selected file: C:\Users\RC\Downloads\cert-gt-i9500_359169056627003 _r21f32ztt1.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9500 Firmware compiled date: Tue Oct 28 00:38:58 KST 2014 PDA version: I9500UBUGNJ1 CSC version: I9500UUBGNJ1 SW version: I9500UBUGNJ1 Phone IMEI: 357196053604596 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully Checking for compatible Certificate and phone... Certificate is not compatible Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Selected file: C:\Users\RC\Downloads\Cert-GT-I9500_ 357633056184606_RF1F30PX65.cert Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Selected file: C:\Users\RC\Downloads\Cert-GT-I9500_ 357633056184606_RF1F30PX65.cert ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9500 Firmware compiled date: Tue Oct 28 00:38:58 KST 2014 PDA version: I9500UBUGNJ1 CSC version: I9500UUBGNJ1 SW version: I9500UBUGNJ1 Phone IMEI: 357196053604596 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully Checking for compatible Certificate and phone... Certificate is not compatible Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Selected file: C:\Users\RC\Downloads\Cert-GT-I9500_ 357138052488191_RF1D46DB4A.cert Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Selected file: C:\Users\RC\Downloads\Cert-GT-I9500_ 357138052488191_RF1D46DB4A.cert Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Selected file: C:\Users\RC\Downloads\Cert-GT-I9500_ 357138052488191_RF1D46DB4A.cert Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9500 Firmware compiled date: Tue Oct 28 00:38:58 KST 2014 PDA version: I9500UBUGNJ1 CSC version: I9500UUBGNJ1 SW version: I9500UBUGNJ1 Phone IMEI: 357196053604596 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully Checking for compatible Certificate and phone... Certificate is not compatible Writing Certificate failed |
09-17-2015, 08:45 | #20 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please upload *.log and *.logx files of "Write Cert" operation and post here download link. We will check where can be the problem. |
09-17-2015, 10:03 | #21 (permalink) | |
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | Quote:
And also many many thanks for your Patience and Support log - Download - 4shared | |
09-17-2015, 10:29 | #22 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please try to perform "Write Cert" operation with latest Software version. If problem will remain - close the Software, upload latest *.log and *.logx files and post here download link. |
09-17-2015, 13:15 | #23 (permalink) | |
9500 log - Download - 4shared | |
09-17-2015, 15:18 | #24 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Archive, which You've uploaded, contains empty folder. Please upload *.log and *.logx files of "Write Cert" operation, performed with the latest Software version. |
