04-24-2016, 12:12 | #1 (permalink) |
No Life Poster Join Date: Nov 2011 Location: INDIA
Member: 1697041 Status: Offline Sonork: 1609691 Thanks Meter: 67 | samsung s4 l720 not flash ----------------------------------------------------------------------------------- To connect SPH-L720 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: L720VPUAMDC_L720SPTAMDC_L720VPUAMDC_HOME.oct Operation was canceled Please put the phone into Download Mode and connect USB cable. To put SPH-L720 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed Performed by 2.2.5 software version |
