02-09-2016, 12:49 | #1 (permalink) |
Crazy Poster Join Date: Apr 2014
Member: 2163236 Status: Offline Sonork: 1654485:mique Thanks Meter: 0 | Samsung S5 SM-G900T IMEI Null Solution? Platform: Samsung Android Selected port: COM12 Selected model: SM-G900T Reading info, please wait... Detected phone model: SM-G900T Firmware compiled date: Mon Jul 20 17:03:00 KST 2015 PDA version: G900TUVU1FOG6 CSC version: G900TTMB1FOG6 SW version: Unknown Phone SN: RV8F4162WBX Android version: 5.1.1 (LMY47X) Tried to root also not working |
02-09-2016, 13:47 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Hello. As You can see from Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). Then (when phone's modem part will be correct) perform "Wipe Security" and "Write Cert" operations. It is not possible to repair IMEI, if phone's modem part is damaged. If after writing of all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem. | |
02-09-2016, 14:29 | #4 (permalink) |
Member: 2163236 Status: Offline Sonork: 1654485:mique Thanks Meter: 0 | I noticed that happened when I tried to repair the No network by flashing with QCN files downloaded on the support page, since then it will show no phone detected whenever i tried to repair security or re-write qcn |
02-09-2016, 15:09 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Which QCN file You've wrote exactly? Please post here full Software log of all operations, which You've performed with the phone. |
02-09-2016, 17:28 | #6 (permalink) |
Member: 2163236 Status: Offline Sonork: 1654485:mique Thanks Meter: 0 | ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM24 Selected model: SM-G900T Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900T Firmware compiled date: Mon Jul 20 17:03:00 KST 2015 PDA version: G900TUVU1FOG6 CSC version: G900TTMB1FOG6 SW version: Unknown Phone SN: RV8F4162WBX Android version: 5.1.1 (LMY47X) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM24 Selected model: SM-G900T Reading info... Phone was not found on the selected port! Writing QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM24 Selected model: SM-G900T Detected phone model: SM-G900T Firmware compiled date: Mon Jul 20 17:03:00 KST 2015 PDA version: G900TUVU1FOG6 CSC version: G900TTMB1FOG6 SW version: Unknown Phone SN: RV8F4162WBX Android version: 5.1.1 (LMY47X) Reading info... Phone was not found on the selected port! |
02-09-2016, 18:08 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | From Software log we can see that "Write QCN" operation was not performed. To solve the problem with null IMEI and baseband - try re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). If after writing of all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem. |
02-09-2016, 21:54 | #11 (permalink) |
Freak Poster Join Date: May 2014 Location: from JORD . work in usa .
Member: 2179929 Status: Offline Thanks Meter: 34 | flash this rom sir https://www.androidfilehost.com/?fid=95916177934532225 |
The Following User Says Thank You to r.o0y For This Useful Post: |
