04-29-2021, 16:57 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Ports***** UK Age: 44
Member: 126675 Status: Offline Thanks Meter: 13 | Samsung S6 G920F G920FXXS6ETI6 unlock problem [Answered] Platform: Samsung Android Selected port: COM13 Selected model: SM-G920F Operation: Read Codes - General Proper android device not found. Make sure that "USB debug" option on the device is turned on. Read codes failed Performed by 3.0.2.7 Software version. Welcome to Octoplus Box Samsung software version 3.0.2.7 Card S/N : 100005356 ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Work ID: 0000000000F086F7 Platform: Samsung Android Selected port: COM15 Selected model: SM-G920F Performed by 3.0.2.7 Software version. ----------------------------------------------------------------------------------- Work ID: 0000000000F087F2 Platform: Samsung Android Selected port: COM13 Selected model: SM-G920F Operation: Read Codes - General Proper android device not found. Make sure that "USB debug" option on the device is turned on. Read codes failed Performed by 3.0.2.7 Software version. ----------------------------------------------------------------------------------- Work ID: 0000000000F0887D Platform: Samsung Android Selected port: COM14 Selected model: SM-G920F Operation: Unlock Proper android device not found. Make sure that "USB debug" option on the device is turned on. Phone is successfully unlocked Performed by 3.0.2.7 Software version. ----------------------------------------------------------------------------------- Work ID: 0000000000F0889E Platform: Samsung Android Selected port: COM14 Selected model: SM-G920F Operation: Read Codes - General Proper android device not found. Make sure that "USB debug" option on the device is turned on. Read codes failed Performed by 3.0.2.7 Software version. ----------------------------------------------------------------------------------- Work ID: 0000000000F088C5 Platform: Samsung Android Selected port: COM14 Selected model: SM-G920F Operation: Unlock Searching for a phone. Please wait... Found phone on COM14 Reading info... Detected phone model: SM-G920F HW Version: O2U PDA version: G920FXXS6ETJ6 CSC version: G920FTEF6ETI1 CP version: G920FXXU6ERF5 Phone SN: R58HC1RBC6V Phone IMEI: 354314-08-574875-1 Unlocking phone... Fast Unlock method is not supported for current security settings in your phone! Try to downgrade firmware! Phone unlocking failed Performed by 3.0.2.7 Software version. |
04-30-2021, 07:28 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Unfortunately, Fast Unlock method is not supported for current security settings in your phone. Does your phone ask for Unlock code? Last edited by Octopus support; 04-30-2021 at 08:26. |
