samsung s9 G960F REPAIR NETWORK [Answered] samsung s9 G960F REPAIR NETWORK BUT NOT SUCESS Welcome to Octoplus Box Samsung software version 2.7.9 ----------------------------------------------------------------------------------- Connecting to server... Could not connect to the server! Your IP is in black list! Performed by 2.7.9 Software version. ----------------------------------------------------------------------------------- Connecting to server... Username: 9cw9og5 Authorizing... Checking balance... Your balance: 100 credits. Performed by 2.7.9 Software version. ----------------------------------------------------------------------------------- To connect SM-A500G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM71 Selected model: SM-G960F Operation: Repair Network Proper android device not found. Make sure that "USB debug" option on the device is turned on. Repairing network failed. Performed by 2.7.9 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM71 Selected model: SM-G960F Operation: Repair Network Detected phone model: SM-G960F Firmware compiled date: Fri Oct 5 09:25:48 KST 2018 PDA version: G960FXXU2BRJ3 CSC version: G960FODX2BRJ2 SW version: G960FXXU2BRJ1 Phone SN: RZ8K21KV11V Android version: 8.0.0 (R16NW) Sales code: DTM Country: Germany HW platform: exynos5 HW Chip: exynos9810 HW Modem: SHANNON360 Security patch level: 2018-10-01 Warranty Void: 1 SIM 1 status: absent SIM 2 status: absent Codename: starltexx Checking Root: Phone is Rooted. ----------------------------------------------------------------------------------- Connecting to server .. Username: 9cw9og5 Connect to server successfull. Checking smart card... Smart card successfully checked. Your balance: 100 credits. Checking operation...OK ----------------------------------------------------------------------------------- Repairing network. Please wait, this can take some time...OK Searching for a phone. Please wait...OK Uploading service app..OK Installing service app...OK Please press "Allow" button on the phone when superuser dialog appears! Network will be available in 50 seconds after phone reboot! Network is successfully repaired. Performed by 2.7.9 Software version. ----------------------------------------------------------------------------------- ---------------------------------- STILL IMEI STATUS :NG NOT OK |
Hello. Please, download and isntall latest test Software version from the Support Area, then try to do next: Root your phone manually: Attention: You need to root your device with TWRP method. If You will use any other root methods ( including via dongles, other products, etc) result will be negative, such methods may not work properly and You will get NG result as well. |
Selected port: COM71 Selected model: SM-G960F Operation: Repair Network Detected phone model: SM-G960F Firmware compiled date: Fri Oct 5 09:25:48 KST 2018 PDA version: G960FXXU2BRJ3 CSC version: G960FOVF2BRJ1 SW version: G960FXXU2BRJ1 Phone SN: RZ8K21KV11V Android version: 8.0.0 (R16NW) Sales code: VD2 Country: Germany HW platform: exynos5 HW Chip: exynos9810 HW Modem: SHANNON360 Security patch level: 2018-10-01 Warranty Void: 0 SIM 1 status: ready SIM 2 status: absent Codename: starltexx Checking Root: Phone is Rooted. Connecting to server .. Username: 9cw9og5 Connect to server successfull. Checking smart card... Smart card successfully checked. Your balance: 100 credits. Checking operation...OK ----------------------------------------------------------------------------------- Repairing network. Please wait, this can take some time...OK Searching for a phone. Please wait...OK Uploading service app..OK Installing service app...OK Please press "Allow" button on the phone when superuser dialog appears! Network will be available in 50 seconds after phone reboot! Network is successfully repaired. Performed by 2.7.9 Software version. same problem no network after flash the file which downloaded in support area, ATL-G960FXXU2BRJ3-20181023155706 i root the phone manually but not success. anyother solution . note octonetwork icon came in phone app. |
What method You are using to root your device?! |
Also, make sure that You performed this step: Please press "Allow" button on the phone when superuser dialog appears! It's important wiothout that Repair Network may work not properly! |
how come I don't get out of it repairs network? https://i.ibb.co/pWSjY2P/Annotazione...-12-120340.jpg |
aLLOW options not shown on the phone but only superuser grant option coming and ask press to grant the root . what wrong im doing please guide me clearly. |
Unfortunately, "patch cert" Repair Network operation isn't supported for that device. You can check all infomation here, look attentive for the list of supported models and operations Octoplus Samsung 2.7.9 Update |
It was added in test mode, that option will be disabled in next update. |
Disable Rmm And use magisk to root it Use search |
@Medofficiel Hello. Please post here successful log of Repair Network operation, we will check it. |
