04-07-2016, 20:16 | #1 (permalink) |
Freak Poster Join Date: Mar 2012 Location: International
Member: 1728527 Status: Offline Sonork: 100.1668555 Thanks Meter: 67 | Samsung SM-A500F Error While Searching For Networks When Sim Card Inserted Device Having NO SERVICE Unable to Search Network Manually - When Click Manual Search There is One Notification - Error While Searching Networks Unable to Change NETWORK TYPE in Settings - When Chosen GSM Only it Goes to Default Settings in About Device Shows Radio OFF When Dial 112 ( Emergency Number ) Dial Shows " Emergency call - Turning Radio ON " Nothing Happens Later Searched Serial Number in Database & Flashed With Stock 1 - A500FXXU1ANJ9_A500FOLB1ANK1_A500FXXU1ANJ9_HOME.tar 2 - A500FXXU1BOJ5_A500FOLB1BOK1_A500FXXU1BOJ5_HOME.tar Second one is Android 5.0.2 , Which is The Latest Available Stock ROM Phone Rooted With CF Auto Root Back Up - QCN , EFS , NVM , SEC ( CERT NOT READABLE ) Then Tried Write Default EFS , Reset EFS , Repair ...etc ... After Everything - IMEI Gone Null Again Flashed Stock - Write Back up - IMEI Came Back Finally Tried WRITE CERT Write - From Support Site IMEI Changed According to New CERT File - But no use Same Error A Video Uploaded , Also All Backup File Which is Readed From the Device Before i Start Working https://www.youtube.com/watch?v=4IU2L719JlQ Download Back up - BACKUP-SM-A500F Code: Welcome to Octoplus/Octopus Box Samsung software version 2.2.3 ----------------------------------------------------------------------------------- To connect SM-A500F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM35 Selected model: SM-A500F Mode: Normal Phone model: SM-A500F Firmware compiled date: Oct 15 2015 Firmware compiled time: 00:00:00 Firmware released date: Oct 30 2015 Firmware released time: 21:00:14 Phone IMEI: 356318-06-874830-6 SW version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1.31568.1 Performed by 2.2.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM35 Selected model: SM-A500F Mode: Normal Phone model: SM-A500F Firmware compiled date: Oct 15 2015 Firmware compiled time: 00:00:00 Firmware released date: Oct 30 2015 Firmware released time: 21:00:14 Phone IMEI: 356318-06-874830-6 SW version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1.31568.1 Reading NVM... Reading NVM done! Performed by 2.2.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM35 Selected model: SM-A500F Mode: Normal Phone model: SM-A500F Firmware compiled date: Oct 15 2015 Firmware compiled time: 00:00:00 Firmware released date: Oct 30 2015 Firmware released time: 21:00:14 Phone IMEI: 356318-06-874830-6 SW version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1.31568.1 Performed by 2.2.3 software version ----------------------------------------------------------------------------------- To connect SM-A500F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-A500F Mode: Normal Phone model: SM-A500F Firmware compiled date: Oct 15 2015 Firmware compiled time: 00:00:00 Firmware released date: Oct 30 2015 Firmware released time: 21:00:14 Phone IMEI: 356318-06-874830-6 SW version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1.31568.1 Creating NVM backup Reading NVM done! Repairing NVM for SM-A500F phone... NVM repair completed successfully To finish the operation, please restart the phone via phone's menu. Performed by 2.2.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-A500F ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-A500F Firmware compiled date: Sat Oct 31 04:10:55 KST 2015 PDA version: A500FXXU1BOJ5 CSC version: A500FOLB1BOK1 SW version: A500FXXU1BOJ5 Phone SN: RF8G91C1YPP Android version: 5.0.2 (LRX22G) Reading info... Mode: Normal Firmware compiled date: Oct 15 2015 Firmware compiled time: 00:00:00 Firmware released date: Oct 30 2015 Firmware released time: 21:00:14 SW Version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1.31568.1 Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-A500F-07-04-2016_23-04-40-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-A500F-07-04-2016_23-04-41-.asec file Wiping EFS... Performed by 2.2.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-A500F Selected file: F:\samsung\SM-A500F\Octopus\Cert-SM-A500F_ 356316062038146.cert Select Certificate2... Selected file: F:\samsung\SM-A500F\Octopus\Cert-SM-A500F_ 356317062038144.cert ADB server killed. Detected phone model: SM-A500F Firmware compiled date: Sat Oct 31 04:10:55 KST 2015 PDA version: A500FXXU1BOJ5 CSC version: A500FOLB1BOK1 SW version: A500FXXU1BOJ5 Phone SN: RF8G91C1YPP Android version: 5.0.2 (LRX22G) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Please Reset MSL first! Writing Certificate failed Performed by 2.2.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-A500F Detected phone model: SM-A500F Firmware compiled date: Sat Oct 31 04:10:55 KST 2015 PDA version: A500FXXU1BOJ5 CSC version: A500FOLB1BOK1 SW version: A500FXXU1BOJ5 Phone SN: RF8G91C1YPP Android version: 5.0.2 (LRX22G) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-A500F-07-04-2016_23-09-06 file Reseting MSL... MSL reset successfully. Please, restart the phone to apply changes Performed by 2.2.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-A500F Selected file: F:\samsung\SM-A500F\Octopus\Cert-SM-A500F_ 356316062038146.cert Select Certificate2... Selected file: F:\samsung\SM-A500F\Octopus\Cert-SM-A500F_ 356317062038144.cert Detected phone model: SM-A500F Firmware compiled date: Sat Oct 31 04:10:55 KST 2015 PDA version: A500FXXU1BOJ5 CSC version: A500FOLB1BOK1 SW version: A500FXXU1BOJ5 Phone SN: RF8G91C1YPP Android version: 5.0.2 (LRX22G) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.2.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-A500F Reading info... Mode: Normal Firmware compiled date: Oct 15 2015 Firmware compiled time: 00:00:00 Firmware released date: Oct 30 2015 Firmware released time: 21:00:14 SW Version: MPSS.DPM.1.0.c7.1-00098-M8916EAAAANVZM- 1.19727.1.31568.1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes Performed by 2.2.3 software version Watch This Video To get More Details About This Actual Problem https://www.youtube.com/watch?v=4IU2L719JlQ I Hope Octopus Team Can Find A Solution For This Trouble |
04-08-2016, 10:42 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Hello. Please read out QCN from another SM-A500F, which works correctly in your region and try to write it into your phone. |
