04-23-2016, 18:57 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: pakistan
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 429 | samsung sm-B310E not connect Welcome to Octoplus/Octopus Box Samsung software version 2.2.5 ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM81 Selected model: SM-B310E Selected port: USB To connect SM-B310E, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... Connecting canceled. Performed by 2.2.5 software version ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM81 Selected model: SM-B310E Selected port: USB To connect SM-B310E, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... Connecting canceled. Performed by 2.2.5 software version ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM81 Selected model: SM-B310E Selected port: USB To connect SM-B310E, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... |
04-24-2016, 10:01 | #2 (permalink) |
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 429 | octopus team why are you not reply now not supported SM-B310E ?? other box connect power off phone,insert battery press home button and insert cable then set is connect ok but i will try octopus not connect plz fix this problem Octopus team |
The Following User Says Thank You to Yasir Ali For This Useful Post: |
04-25-2016, 10:22 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Manually uninstall current drivers for the phone and install required drivers: http://octopusbox.com/files/drivers/...ile_Phones.exe http://octoplusbox.com/files/drivers/SCIUSB2SERIAL.zip http://octoplusbox.com/files/drivers...iver%20x86.zip After installation restart PC and try to perform the operation again. |
04-25-2016, 17:21 | #4 (permalink) |
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 429 | we done other device sir no uninstall driver require that octopus must be uninstall first driver?? i want information for unlock with octopus next time same mobile must be uninstall old driver and install driver you give ?? |
04-25-2016, 17:57 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Yes, the next time You'll have issues with connection of Spreadtrum devices, please install necessary drivers from previous post. |
