10-25-2015, 16:59 | #1 (permalink) |
Product Manager Join Date: Mar 2011 Location: kuwait Age: 32
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Samsung SM-G530H Write Flash Done With Octopus Code: Welcome to Octoplus/Octopus Box Samsung software version 2.0.7 ----------------------------------------------------------------------------------- To connect GT-I8262 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G530H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. Selected firmware file: g530hxcu1boh3_g530hoxe1boi2_cac_android_ 5.0.2.oct Please put the phone into Download Mode and connect USB cable. To put SM-G530H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing QSEE section... QSEE section has been written successfully. Writing QHEE section... QHEE section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing sec section... sec section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. g530hxcu1boh3_g530hoxe1boi2_cac_android_5.0.2.oct Thanks Octopus Odin All Version Write Flash error BR Dipankor-ctg |
The Following 4 Users Say Thank You to Dipankor-ctg For This Useful Post: |
10-26-2015, 05:29 | #2 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | my problem 1st time monkey test Write Flash Done Problem Solve But Imei Not Show Incoming Outgoing call okay but *#06# Not Work Can You Any Solution BR Dipankor-ctg |
