01-10-2017, 09:54 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 57
Member: 137980 Status: Offline Thanks Meter: 168 | sm-a510f frp now set restart ----------------------------------------------------------------------------------- To connect SM-G930W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM40 Selected model: SM-A510F Connecting to server... Connecting to server...Ok! Checking resource files... Downloading resources... All necessary resource files have been downloaded successfully. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Boot section... Boot section has been written successfully. Searching for a phone (waiting for ADB device)... sm-a510f frp now set restart now set restart on logo what file i flash?// for ok |
01-10-2017, 10:21 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,415 | Hello. Removal of FRP lock requires writing of "boot.img" partition of combination firmware. "boot.img" from Combination firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). To remove FRP lock You should try to manually write "boot.img" of different Combination firmwares and when You manage to find the one, that fits current firmware of the phone - perform "Reset FRP" operation. Press "No" when Software will ask You whether to write "boot.img" during the operation. |
