04-17-2015, 19:14 | #1 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 618626 Status: Offline Sonork: 100.1592779 Thanks Meter: 61 | SM-C101 Network problem I Am Unable To Repair Sm-c101 "Network Problem" It Is Giving "Emergency Call Only" With Sim Card Inserted Too... Phone Imei And Baseband Is Ok But Getting "IMEI CERTI: FAIL" On Dialing *#0011#... Process Done : Flashed With Firmware Downloaded From Support Area "SM-C101_for_Unlock_and_Repair_IMEI.oct" And Tried To Write Service IMEI After Wiping Data And Cache From Recovery But Always Getting Error On Writing IMEI.. Code: Welcome to Octoplus/Octopus Box Samsung software version 1.8.8 ----------------------------------------------------------------------------------- To connect SM-C101 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: SM-C101_for_Unlock_and_Repair_IMEI.oct Please put the phone into Download Mode and connect USB cable. To put SM-C101 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing TZSW section... TZSW section has been written successfully. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-C101 Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-C101 Firmware compiled date: Thu Jul 4 21:16:21 KST 2013 PDA version: C101XWUAMG1 CSC version: C101OJVAMG2 SW version: C101XXUAMG2 Phone IMEI: 356985053710507 Phone SN: CN1D802HXHP Android version: 4.2.2 (JDQ39) Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-C101-Unknown17-04-2015_22-43-14-.asec file Cheking security type... Old security type is detected Executing exploit... Write IMEI failed Waiting For Help... Last edited by Octopus box; 04-18-2015 at 07:05. |
04-17-2015, 19:59 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Reflash the phone with 4.4.2 firmware and repeat "Repair IMEI" operation. Try to write Cert file from the Support Area. |
04-18-2015, 12:53 | #3 (permalink) | |
Member: 618626 Status: Offline Sonork: 100.1592779 Thanks Meter: 61 | Quote:
Code: Welcome to Octoplus/Octopus Box Samsung software version 1.8.8 ----------------------------------------------------------------------------------- To connect SGH-I747 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#7284#" number. 12. Set "UART" to "PDA" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-C101 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: C101XWUANA1_C101OJVANA2 _LYS_United_Arab_Emirates_Android_4.4.2.oct Please put the phone into Download Mode and connect USB cable. To put SM-C101 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on File has been created for a different phone model. Selected firmware file: C101XWUANA1_C101OJVANA2 _LYS_United_Arab_Emirates_Android_4.4.2.oct Please put the phone into Download Mode and connect USB cable. To put SM-C101 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on File has been created for a different phone model. | |
04-27-2015, 17:05 | #5 (permalink) | |
Code: Welcome to Octoplus/Octopus Box Samsung software version 1.9.3 ----------------------------------------------------------------------------------- To connect SGH-I747M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "PDA" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+Modem+ADB". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "UART" value. 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-C101 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: C101XWUANA1_C101OJVANA2 _LYS_United_Arab_Emirates_Android_4.4.2.oct Please put the phone into Download Mode and connect USB cable. To put SM-C101 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CAMERAISP section... CAMERAISP section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-C101 Detected phone model: SM-C101 Firmware compiled date: Tue Jan 14 21:21:02 KST 2014 PDA version: C101XWUANA1 CSC version: C101OJVANA2 SW version: C101XXUAMK4 Phone IMEI: 004999010640000 Phone SN: CN1D802HXHP Android version: 4.2.2 (JDQ39) Reading security backup, please wait... Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Write IMEI failed | |
04-27-2015, 17:20 | #6 (permalink) |
Member: 618626 Status: Offline Sonork: 100.1592779 Thanks Meter: 61 | Phone Imei Successfully repaired with service imei... Code: Platform: Samsung Android Selected port: COM1 Selected model: SM-C101 Detected phone model: SM-C101 Firmware compiled date: Tue Jan 14 21:21:02 KST 2014 PDA version: C101XWUANA1 CSC version: C101OJVANA2 SW version: C101XXUAMK4 Phone IMEI: 004999010640000 Phone SN: CN1D802HXHP Android version: 4.2.2 (JDQ39) Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-C101-Unknown27-04-2015_21-10-45-.asec file Cheking security type... Old security type is detected Executing exploit... Exploit has been executed successfully Old IMEI: 004999-01-064000-0 New IMEI: 356985-05-000994-5 Repairing IMEI ... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Note : Imei Was Successfully Repaired Previously With "Emergency Call Only" Error But Its Damaged again and now i am unable to fix it.. |
04-27-2015, 19:19 | #8 (permalink) |
Member: 618626 Status: Offline Sonork: 100.1592779 Thanks Meter: 61 | Certificate write successfull after wipe data and cache VIA recovery.. But Imei Still "004999xxxxxxxxxx"... Code: Platform: Samsung Android Selected port: COM1 Selected model: SM-C101 Selected file: D:\Samsung\Flash Files\C-Series\C101\certs\Cert-SM- C101_356985051316612.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-C101 Firmware compiled date: Tue Jan 14 21:21:02 KST 2014 PDA version: C101XWUANA1 CSC version: C101OJVANA2 SW version: C101XXUAMK4 Phone IMEI: 004999010640000 Phone SN: CN1D802HXHP Android version: 4.2.2 (JDQ39) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully Checking for compatible Certificate and phone... Certificate is correct Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes |
04-28-2015, 07:17 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Do the next: 1. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 2. Run the Software. 3. Take out SIM and SD cards from the device. 4. Root the device. 5. Write IMEI Certificate again. 6. Make Write Cert again. 7. Close the Software. 8. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here the link, we will research, where can be the problem with your device. |
04-28-2015, 15:00 | #10 (permalink) | |
04-28-2015, 15:43 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Reflash the phone with "C101XXUBNK2_C101OJVBNL1_LYS_Android_4.4.2" firmware from the Support Area and repeat "Write Cert" operation. |
04-28-2015, 18:40 | #12 (permalink) | |
Code: Welcome to Octoplus/Octopus Box Samsung software version 1.9.3 ----------------------------------------------------------------------------------- To connect SM-C101 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: C101XXUBNK2_C101OJVBNL1_LYS_Android_ 4.4.2.oct Please put the phone into Download Mode and connect USB cable. To put SM-C101 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CAMERAISP section... CAMERAISP section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- To connect SM-C101 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM198 Selected model: SM-C101 Selected file: D:\Samsung\Flash Files\C-Series\C101\certs\Cert-SM- C101_356985051316612.cert ADB server killed. Detected phone model: SM-C101 Firmware compiled date: Mon Nov 24 14:51:53 KST 2014 PDA version: C101XXUBNK2 CSC version: C101OJVBNL1 SW version: C101XXUBNK1 Phone IMEI: 004999010640000 Phone SN: CN1D802HXHP Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully Checking for compatible Certificate and phone... Certificate is correct Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes | |
04-28-2015, 18:46 | #13 (permalink) |
Member: 618626 Status: Offline Sonork: 100.1592779 Thanks Meter: 61 | Also Tried Writing Service Imei On "4.4.2" Version Operation As Usual Successful But Imei Still Damage.. Code: Platform: Samsung Android Selected port: COM198 Selected model: SM-C101 Detected phone model: SM-C101 Firmware compiled date: Mon Nov 24 14:51:53 KST 2014 PDA version: C101XXUBNK2 CSC version: C101OJVBNL1 SW version: C101XXUBNK1 Phone IMEI: 004999010640000 Phone SN: CN1D802HXHP Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-C101-Unknown28-04-2015_22-41-30-.asec file Cheking security type... Old security type is detected Executing exploit... Exploit has been executed successfully Old IMEI: 004999-01-064000-0 New IMEI: 356985-05-000994-5 Repairing IMEI ... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
