09-16-2016, 02:54 | #1 (permalink) |
Freak Poster Join Date: Dec 2014 Location: US
Member: 2306078 Status: Offline Sonork: 1660961 Thanks Meter: 19 | SM-G530A FRP won't work [Solved] Hi use octopus box to do FRP for SM-G530A Everything is smooth, the phone restart then Google account is still there, it did not remove . I try 3 times , but the same problem. Please help . Last edited by Octopus box; 09-17-2016 at 07:35. |
09-16-2016, 08:30 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. In the latest firmware versions Samsung close security hole and You can't perform Reset FRP on new version of firmwares. You can try to downgrade phone's firmware (write older by release date version of firmware), but on your own risk, after repeat Reset FRP operation. Also, post here the result. |
09-16-2016, 19:29 | #3 (permalink) |
Member: 2306078 Status: Offline Sonork: 1660961 Thanks Meter: 19 | Work perfect, i did downgrade to OI7 then work well Welcome to Octoplus/Octopus Box Samsung software version 2.3.6 ----------------------------------------------------------------------------------- To connect SM-G530A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G530A To put SM-G530A into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Reset operation completed! Performed by 2.3.6 software version Work perfect, i did downgrade to OI7 then work well Thank you |
