04-14-2015, 06:13 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Fully charge phone's battery, make Factory data reset and wipe cache partition and try to write firmware again. Connect the phone directly to PC motherboard USB port, don't use any USB hubs, this is important. Try to write another firmware. Try to write firmware on another PC. Post here the result. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
09-08-2015, 08:55 | #3 (permalink) | |
Insane Poster Join Date: Feb 2015 Location: In My MiNd
Member: 2344113 Status: Offline Sonork: 100.1668385 Thanks Meter: 40 | Trying to this method but phone dosent on to Recovery Mode Phone display show in this MMC: mmc_write fail Movinand Checksum Confirmation fail) Quote:
09-08-2015, 09:11 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Most likely your device has HW problem (problem with flash chip). |
04-01-2016, 10:51 | #6 (permalink) | |
Freak Poster Join Date: Dec 2014 Location: bahrain
Member: 2308999 Status: Offline Sonork: 100.1657583 Thanks Meter: 34 | Quote:
04-01-2016, 11:17 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You can try to make Factory data reset and Wipe cache partition form Recovery Mode if phone enters it. Otherwise - skip these actions. |
06-11-2016, 07:08 | #8 (permalink) |
Junior Member Join Date: Feb 2016 Location: Miracle Box
Member: 2533505 Status: Offline Thanks Meter: 2 | Selected model: SM-G530H To put SM-G530H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Operation was failed! Performed by 2.2.7 software version plz help |
06-11-2016, 11:39 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to re-install Samsung USB drivers. Try to use different USB ports of PC motherboard for connection. |
