04-12-2021, 11:39 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | SM-G610F FRP / Reactivation lock is successfully reseted Octoplus Samsung Code: Welcome to Octoplus Box Samsung software version 3.0.2.0 Card S/N : 00000E47 ----------------------------------------------------------------------------------- To connect GT-B7510 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090# or *#0808#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-B7510 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090# or *#0808#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-B7510 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090# or *#0808#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Work ID: 0000000000DD52F0 Platform: Samsung Android Selected port: COM1 Selected model: SM-G610F Operation: Reset FRP - ENG Root Searching for a phone. Please wait... Proper android device not found. Make sure that "USB debug" option on the device is turned on. Operation was failed! Performed by 3.0.2.0 Software version. ----------------------------------------------------------------------------------- Work ID: 0000000000DD5302 Platform: Samsung Android Selected port: COM1 Selected model: SM-G610F Operation: Reset FRP - ENG Root Searching for a phone. Please wait... Proper android device not found. Make sure that "USB debug" option on the device is turned on. Operation was failed! Performed by 3.0.2.0 Software version. ----------------------------------------------------------------------------------- Work ID: 0000000000DD53A2 Platform: Samsung Android Selected port: COM1 Selected model: SM-G610F Operation: Reset FRP - ENG Root Searching for a phone. Please wait... Proper android device not found. Make sure that "USB debug" option on the device is turned on. Operation was failed! Performed by 3.0.2.0 Software version. ----------------------------------------------------------------------------------- Work ID: 0000000000DD53C9 Platform: Samsung Android Selected port: COM1 Selected model: SM-G610F Operation: Reset FRP - ENG Root Searching for a phone. Please wait... Proper android device not found. Make sure that "USB debug" option on the device is turned on. Operation was failed! Performed by 3.0.2.0 Software version. ----------------------------------------------------------------------------------- Work ID: FFFFFFFFFFFFFFFF Platform: Samsung Android Selected port: COM1 Selected model: SM-G610F Operation: Reset FRP - UART EMMC Searching for UART interface.. COM3 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation...OK Searching for UART interface.. COM3 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock (1/4 attempt)..success FRP / Reactivation lock is successfully reseted! Performed by 3.0.2.0 Software version. |
The Following 3 Users Say Thank You to naveedullah0044 For This Useful Post: |
