11-20-2014, 15:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2012 Location: bahrain.
Member: 1742913 Status: Offline Sonork: 100.1604070 Thanks Meter: 328 | sm-g7102 emergency call only [Solved] here is my repire log Welcome to Octoplus/Octopus Box Samsung software version 1.7.5 ----------------------------------------------------------------------------------- To connect GT-I9100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G7102 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM792 Selected model: SM-G7102 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G7102 Firmware compiled date: Mon Jul 21 20:41:55 KST 2014 PDA version: G7102XXUBNG8 CSC version: G7102OLBBNG3 SW version: G7102DXUBNG1 Phone IMEI: 352310061266638 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Jun 03 2014 Firmware compiled time: 00:00:00 Firmware released date: Jul 12 2014 Firmware released time: 22:44:26 SW Version: M8626A-AAAANAZM-1.0.4061 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-G7102-352310061266638-20-11-2014_14-27- 09-.qcn file Checking Root: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM792 Selected model: SM-G7102 Reading info... Mode: Normal Firmware compiled date: Jun 03 2014 Firmware compiled time: 00:00:00 Firmware released date: Jul 12 2014 Firmware released time: 22:44:26 SW Version: M8626A-AAAANAZM-1.0.4061 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes Last edited by Octopus box; 11-21-2014 at 15:36. |
11-20-2014, 16:36 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to do exactly the next: 1. Make Factory data reset and wipe cache partition. 2. Write another service's IMEI A and B. 3. Make Rapair NVM. 4. Write this QCN: https://drive.google.com/open?id=0Bw...bzg&authuser=0. 5. Re-start the phone, insert SIM card, wait 3-5 minutes and try to find and select network manually. 6. Write here the result. Also, look here: http://forum.gsmhosting.com/vbb/f684...olved-1878057/, http://forum.gsmhosting.com/vbb/f684...olved-1878213/. |
11-20-2014, 17:42 | #3 (permalink) |
Member: 1742913 Status: Offline Sonork: 100.1604070 Thanks Meter: 328 | followed ur post. process done. when i select network manually its showing providers. but could not register network. here is log Welcome to Octoplus/Octopus Box Samsung software version 1.7.5 ----------------------------------------------------------------------------------- To connect SM-G7102 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM792 Selected model: SM-G7102 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G7102 Firmware compiled date: Mon Jul 21 20:41:55 KST 2014 PDA version: G7102XXUBNG8 CSC version: G7102OLBBNG3 SW version: G7102DXUBNG1 Phone IMEI: 352310061266653 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Old IMEI: 352310-06-126665-3 New IMEI: 352310-06-126662-0 Repairing IMEI A... Phone will restart now IMEI successfully repaired. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM792 Selected model: SM-G7102 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G7102 Firmware compiled date: Mon Jul 21 20:41:55 KST 2014 PDA version: G7102XXUBNG8 CSC version: G7102OLBBNG3 SW version: G7102DXUBNG1 Phone IMEI: 352310061266620 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Old IMEI: 352310-06-126662-0 New IMEI: 352310-06-126668-7 Repairing IMEI B... Phone will restart now IMEI successfully repaired. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM792 Selected model: SM-G7102 Mode: Normal Phone model: SM-G7102 Firmware compiled date: Jun 03 2014 Firmware compiled time: 00:00:00 Firmware released date: Jul 12 2014 Firmware released time: 22:44:26 Phone IMEI: 352310-06-126662-0 SW version: M8626A-AAAANAZM-1.0.4061 Creating NVM backup Reading NVM done! Repairing NVM for SM-G7102 phone... NVM repair completed successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM792 Selected model: SM-G7102 Reading info... Mode: Normal Firmware compiled date: Jun 03 2014 Firmware compiled time: 00:00:00 Firmware released date: Jul 12 2014 Firmware released time: 22:44:26 SW Version: M8626A-AAAANAZM-1.0.4061 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes |
11-20-2014, 18:28 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Have You re-flashed the phone with the special formware "SM-G7102_for_Unlock_and_Repair_IMEI_4.4.2.oct" from the Support Area before to perform actions 1-5? If not - re-flash, then perform all the steps 1-5 again and say the result. |
11-20-2014, 22:14 | #5 (permalink) |
Freak Poster Join Date: May 2013 Location: Turkey
Member: 1941192 Status: Offline Thanks Meter: 57 | This type of cell is sometimes not only the entrance to the SIM card number 2 works Try it |
The Following User Says Thank You to mestoo1 For This Useful Post: |
11-21-2014, 15:27 | #6 (permalink) |
Member: 1742913 Status: Offline Sonork: 100.1604070 Thanks Meter: 328 | i followed this method 1 update special firmware in support 2 root phone 3 factory reset, and wipe 4 repire imei A B 5 repire nvm 6 write qcn done. network sucsess. thanks |
