![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2011 Location: Honduras
Member: 1488173 Status: Offline Thanks Meter: 194 ![]() | SM-G715U1 Unlock MDM Question [Answered] https://www.youtube.com/watch?v=x9d96lOZWLQ i already wipe phone and repeat the process 3 times and the same result, please give me a solution or make refund. Thank you. |
![]() | #2 (permalink) |
Member: 1488173 Status: Offline Thanks Meter: 194 ![]() | Hre is the operation log: Welcome to Octoplus Samsung Software v.4.3.0.3 Work ID: 0000000001EBA767 Starting Unlock MDM (Mar.2024) Selected model: SM-G715U1 Make factory data reset and connect the phone on first page of activation stage to PC via USB. Phone must be in Setup Wizard mode Connect powered-on device to PC! Searching modem port... OK Input IMEI: 352744116039535 Input SN: R58R84M9G4D Connecting to server... Username: LuisPando Your balance: 100 credits Sending device information.. OK Choose unlock method! QR code method choosen! Please check device using this QR before unlocking! Follow these steps : 1. In Android Setup Wizard mode tap on the blank space 6 times. 2. Scan this QR code to install MDM Guard service on your device. 3. Connect to Wi-Fi. 4. Follow the instructions on the screen. 5. Allow USB debugging mode when prompt appears on the screen. Searching ADB devices... Press "OK" button on the device to allow USB debugging OK QR Code is scanned Reading info... Detected model: SM-G715U1 Fingerprint: samsung/xcoverproue/xcoverpro:13/TP1A.220624.014/G715U1UESKEXB1:user/release-keys Firmware compiled date: Fri Feb 2 14:39:02 KST 2024 PDA version: G715U1UESKEXB1 CSC version: G715U1OYMKEXB1 SW version: G715U1UESKEXB1 Build number: QB25894504 Phone SN: R58R84M9G4D Android version: 13 (TP1A.220624.014) Sales code: XAA Carrier Id: XAA Country: USA HW platform: exynos9611 HW Chip: universal9611 HW Modem: REV0.3 Security patch level: 2024-02-01 Warranty Void: 0 Codename: xcoverproue SIM 1 status: ABSENT SIM 2 status: ABSENT Modem board: SHANNON337 Starting exploit... Activating service... Method #1 currently not supported for this device! Using bypass method #3 Attention! Sometimes when unlocking or after rebooting the device, a MDM lock may appear. MDM Guard service will turn off the screen and the MDM lock will disappear. MDM Guard service was activated. Complete the Setup Wizard on the device. MDM Guard service will restrict OTA updates on your device to prevent relock. Unlock MDM (Mar.2024) done Execution time 5 minute(s) 24 second(s) Performed by 4.3.0.3 Software version. |
![]() | #3 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,163 | Hello. Some devices require a repeat operation. Sometimes it takes 4-5 times. It depends on the device model, lock type, and software build number. That is why if the SN, IMEI and username are the same, you can make this device free. Perform a Factory Reset and repeat the operation again. Do a factory reset and immediately start the Unlock MDM operation. Then post here results and we'll check it. |
The Following User Says Thank You to Octopus support For This Useful Post: |
![]() | #4 (permalink) | |
Member: 1488173 Status: Offline Thanks Meter: 194 ![]() | Quote:
![]() | #6 (permalink) | |
https://www.youtube.com/shorts/yiljNBS0wQk Thank you. | |
![]() | #7 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Oct 2009 Location: Romania, Bucharest
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,442 | Hello. Just do a Factory Reset and immediately start the Unlock MDM operation with latest software version 4.3.0.7, post here result. Note: If the SN, IMEI and username are the same, you can make this device free. |
