06-30-2018, 03:03 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Location: POS
Member: 70629 Status: Offline Thanks Meter: 15 | SM-G890A (Android 7.0) Unlock question [Solved] ----------------------------------------------------------------------------------- To connect SM-G890A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-G890A Operation: Read Codes - Diag port Searching for a phone. Please wait... Found phone on COM739 Reading info... Read codes failed Performed by 2.6.9 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-G890A Operation: Read Codes - Diag port Searching for a phone. Please wait... Phone was not found on the selected port! Read codes failed Performed by 2.6.9 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-G890A Operation: Read Codes - Diag port Searching for a phone. Please wait... Phone was not found on the selected port! Read codes failed Performed by 2.6.9 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM738 Selected model: SM-G890A Operation: Unlock Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-G890A Firmware compiled date: Wed Jan 10 17:32:47 KST 2018 PDA version: G890AUCS7DRA2 CSC version: G890AATT7DRA2 SW version: G890AUCS7DRA2 Phone SN: R38G90G9ADW Android version: 7.0 (NRD90M) Sales code: ATT Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2018-01-01 SIM 1 status: absent Codename: marinelteuc Checking Root: Phone is not Rooted. Phone unlocking failed Performed by 2.6.9 Software version. Last edited by Octopus box; 06-30-2018 at 09:51. |
06-30-2018, 09:08 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Hello. As I see from your Software log: "Phone is not Rooted". Please root the device and repeat the operation. Last edited by Octopus box; 06-30-2018 at 09:51. |
05-28-2019, 23:04 | #3 (permalink) |
Freak Poster Join Date: Jul 2005 Location: MANASSAS VA USA Age: 37
Member: 164003 Status: Offline Thanks Meter: 25 | DONE READ CODE FLASH OR TAR FROM SUPPORT THEN LOOK FOR G890AUCU7ARA1_ENG_modem.tar.md5 Welcome to Octoplus Box Samsung software version 2.8.0.1 ----------------------------------------------------------------------------------- To connect SM-G890A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G890A Operation: Read Codes - Diag port Searching for a phone. Please wait... Found phone on COM41 Reading info... Detected phone model: SM-G890A HW Version: ATT PDA version: G890AUCS7DRA2 CSC version: G890AATT7DRA2 CP version: G890AUCS7DRA2 Phone SN: R38G80Z8HCJ Phone IMEI: 352130-07-188085-9 Searching for USB diagnostic port...failed No diagnostic ports found! Type *#0808# and select "DM+ACM+ADB"! Read codes failed Performed by 2.8.0.1 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM41 Selected model: SM-G890A Operation: Read Codes - Diag port Searching for a phone. Please wait... Found phone on COM42 Reading info... Detected phone model: SM-G890A HW Version: ATT PDA version: G890AUCS7DRA2 CSC version: G890AATT7DRA2 CP version: G890AUCS7DRA2 Phone SN: R38G80Z**** Phone IMEI: 352130-**-******-9 Searching for USB diagnostic port...OK Connecting...OK Reading HWID... Could not read data (HWID)! Please write modem from proper Combination firmware and repeat Read Codes operation again! Read codes failed Performed by 2.8.0.1 Software version. Selected AP file: C:\Users\sherif\Desktop\Software\Samsung\G890A \G890AUCU7ARA1_ENG_modem_BoxWares.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G890A into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing RADIO section... RADIO section has been written successfully. Firmware writing successfully completed. Performed by 2.8.0.1 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G890A Operation: Read Codes - Diag port Searching for a phone. Please wait... Found phone on COM42 Reading info... Detected phone model: SM-G890A HW Version: ATT PDA version: G890AUCS7DRA2 CSC version: G890AATT7DRA2 CP version: G890AUCU7ARA1 Phone SN: R38G80Z8HCJ Phone IMEI: 352130-07-188085-9 Searching for USB diagnostic port...OK Connecting...OK Reading HWID...OK Reading NV Data...OK Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 06963714 NET LOCK unlock code: 46313081 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 Performed by 2.8.0.1 Software version. |
The Following 2 Users Say Thank You to sherif2025 For This Useful Post: |
05-28-2019, 23:05 | #4 (permalink) |
Member: 164003 Status: Offline Thanks Meter: 25 | ENG MODEM FILE https://shell.boxwares.com/Download.aspx?L=6179 |
The Following 3 Users Say Thank You to sherif2025 For This Useful Post: |
