03-23-2015, 10:10 | #1 (permalink) |
Freak Poster Join Date: Aug 2013 Location: Italy, Sardinia Age: 32
Member: 2014547 Status: Offline Sonork: 100.1665176 Thanks Meter: 18 | SM-G900F imei repair problem [Solved] When i try to read info on the main tab i get this log: Platform: Samsung Android Selected port: COM12 Selected model: SM-G900F Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM7 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-G900F Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM7 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-G900F Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM7 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-G900F Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Last edited by Octopus box; 03-23-2015 at 16:29. |
03-23-2015, 10:17 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Hello. Do the next: 1. Install the latest Software version (Software). 2. Re-install the latest drivers (http://octoplusbox.com/files/drivers...ile_Phones.exe). 3. Disconnect all other devices from PC. 4. Re-boot the PC 5. Re-start the phone. 6. Configure the phone correctly: 6.1. Disconnect USB cable from phone. 6.2. Go to Menu->Settings->More->About Device. 6.3. Tap on "Build number" 7 times to enable developer options. 6.4. Go to Menu->Settings->More->Developer options. 6.5. Turn on "USB Debugging" option. 6.6. Go to dial window. 6.7. Enter "*#0808#" number. 6.8. Select "DM+Modem+ADB". 6.9. Press Home button. 6.10. Go to dial window. 6.11. Restart phone. 6.12. Press "Read Info" in the "Main" tab in the Software. 7. When phone's info will be read out full and correctly from the "Main" tab in the Software, make Wipe Security and only then write IMEI Certificate. Also, note: to make Wipe Security, You should connect the phone directly to PC motherboard USB port, don't connect the phone to Box USB port and don't use any USB hubs, this is important. |
03-23-2015, 10:23 | #3 (permalink) |
Member: 2014547 Status: Offline Sonork: 100.1665176 Thanks Meter: 18 | I did all of that procedure, i think my issue may come because of android versione 5.0 lollipop on the phone? im trying right now to dl 4.4.2 firmware |
03-23-2015, 10:27 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Yes, of course. If here is Android 5.0.x firmware in your device, to connect the phone via modem COM port, You should downgrade it to Android 4.4.x version. |
03-23-2015, 11:00 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Maybe firmware is not suitable. Try to write other firmwares. |
03-23-2015, 14:33 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Yes, all Certificates files, which we have, are present in the Support Area (press "Go to Support" button at "Support & Options" tab in the Software) in the folder "Samsung/FOR UNLOCK ANDREPAIR/Certificates/". |
03-23-2015, 14:41 | #12 (permalink) |
Member: 2014547 Status: Offline Sonork: 100.1665176 Thanks Meter: 18 | Ok, tried several certs from the support area, i get ever Writing Certificate Failed Platform: Samsung Android Selected port: COM15 Selected model: SM-G900F Selected file: C:\Users\ND\Downloads\Cert-SM-G900F_352558068272500.cert Detected phone model: SM-G900F Firmware compiled date: Thu Jul 3 14:08:46 KST 2014 PDA version: G900FXXU1ANG2 CSC version: G900FTSI1ANG1 SW version: G900FXXU1ANG2 Phone IMEI: 352558068671891 Phone SN: RF8F31M1CZZ Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: SM-G900F Selected file: C:\Users\ND\Downloads\Cert-SM-G900F_352558067456427_00000000000.cert Detected phone model: SM-G900F Firmware compiled date: Thu Jul 3 14:08:46 KST 2014 PDA version: G900FXXU1ANG2 CSC version: G900FTSI1ANG1 SW version: G900FXXU1ANG2 Phone IMEI: 352558068671891 Phone SN: RF8F31M1CZZ Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: SM-G900F Selected file: C:\Users\ND\Downloads\Cert-SM-G900F_352558067456393.cert Detected phone model: SM-G900F Firmware compiled date: Thu Jul 3 14:08:46 KST 2014 PDA version: G900FXXU1ANG2 CSC version: G900FTSI1ANG1 SW version: G900FXXU1ANG2 Phone IMEI: 352558068671891 Phone SN: RF8F31M1CZZ Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: SM-G900F Selected file: C:\Users\ND\Downloads\Cert-SM-G900F_352558067456393_00000000000.cert Detected phone model: SM-G900F Firmware compiled date: Thu Jul 3 14:08:46 KST 2014 PDA version: G900FXXU1ANG2 CSC version: G900FTSI1ANG1 SW version: G900FXXU1ANG2 Phone IMEI: 352558068671891 Phone SN: RF8F31M1CZZ Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Writing Certificate failed |
03-23-2015, 14:53 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Of course, failed. As You can see from your Software log, You have not wipeed Security before to write IMEI certificate - phone's IMEI should be Unknown. Also, use the latest Software version (Software). |
03-23-2015, 15:02 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | In some cases, is necessary to repeat the "Wipe Security" operation several times or re-flash the phone. Try to do the next: 1. Fully charge phone's battery. 2. Make Factory data reset and wipe cache partition. 3. Root the phone and make Wipe Security several times and check, whether IMEI becomes "Unknown". Also try to re-flash the phone with different firmwares and make Wipe Security. 4. When the IMEI becomes "Unknown", Write Certificate. Also, look here: http://forum.gsmhosting.com/vbb/f684.../#post10681731, http://forum.gsmhosting.com/vbb/f684.../#post10705160, http://forum.gsmhosting.com/vbb/f684.../#post10708907. Also, try to make Repair EFS and check, whether IMEI becomes "Unknown". Post here full Software log with all of your actions. |
