04-18-2015, 00:57 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: JAM
Member: 1196714 Status: Offline Thanks Meter: 238 | SM-G900W8 Phone successfully unlocked! ----------------------------------------------------------------------------------- To connect SM-G900W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G900W8 Mode: Normal Phone model: SM-G900W8 Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: Jun 16 2014 Firmware released time: 10:11:32 Phone IMEI: 352308-06-15XXXX-X SW version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G900W8 ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900W8 Firmware compiled date: Mon Jun 16 11:51:09 KST 2014 PDA version: G900W8VLU1ANF3 CSC version: G900W8OYA1ANF3 SW version: G900W8VLU1ANF3 Phone IMEI: 3523080615XXXXX Phone SN: RV8F41MG4QH Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: Jun 16 2014 Firmware released time: 10:11:32 SW Version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G900W8-3523080615XXXXX-17-04-2015_18-45-34-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: Jun 16 2014 Firmware released time: 10:11:32 SW Version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G900W8 Selected file: D:\Documents\Samsung_FOR_UNLOCK_AND_REPAIR_Certifi cates\Cert\SM-G900F_3531100607XXXXX_R58F0SFT2T.cert Detected phone model: SM-G900W8 Firmware compiled date: Mon Jun 16 11:51:09 KST 2014 PDA version: G900W8VLU1ANF3 CSC version: G900W8OYA1ANF3 SW version: G900W8VLU1ANF3 Phone IMEI: Unknown Phone SN: RV8F41MG4QH Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes |
